POV-Ray : Newsgroups : povray.general : I'll try a signature again... Server Time
3 Nov 2026 08:04:04 EST (-0500)
  I'll try a signature again... (Message 1 to 18 of 18)
Subject: I'll try a signature again...
Date: 22 Mar 2002 09:00:43
Message: <3c9b390b@news.povray.org>
...since it seems a subject which never goes away and I've still lacked a
real one.  Plain as ever before for mine, and definitely not very unique.
Unveiled below where it ought to be.  (yeah, you can picture it already,
huh?)
sphere_sweep{b_spline 20<-2,-2,4>.1<-2,-1,4>.15<-1.5,1,4>.1<0,0,4>.1
<-2,0,4>.1<0,-1,4>.1<-2.5,-1,4>.1<-.5,-1,4>.1,<0,0,4>.1<1,-.5,4>.1
<0,-1,4>.1<-.5,-.5,4>.1<0,0,4>.1<1,-1,4>.1<1.5,-.25,4>.1<2,0,4>.1
<2,-.75,4>.1<1,-1,4>.1<1.5,1,4>.1<1.5,1,4>.1pigment{rgb 9}}//v3.5
Subject: Re: I'll try a signature again...
Date: 22 Mar 2002 09:49:52
Message: <3C9B4491.8EE6E977@gmx.de>
> huh?)
I think i have to show my version sometime too so here it is.
Disclaimer: the use of 'internal' in scenes is officially deprecated so if
Thorsten is mean it will look totally different in the next beta. ;-)
#macro X()function{#end#local Y=X()internal(35)}#local Z=X()internal(36)
}isosurface{X()-Y(Z(y,2*z,x,1),Z(y,x,z,.3),z,.8)}max_gradient 99 rotate<
99,40>pigment{slope x color_map{[0rgb 9*x][1rgb 9*z]}}translate 3*z}//CH
Date: 22 Mar 2002 10:20:32
Message: <dpim9u0acvfcvk0a3jmgi715arcihd9pib@4ax.com>
On Fri, 22 Mar 2002 15:49:53 +0100, Christoph Hormann <chr### [at] gmxde>
I couldn't resist :-)
One space saved and more obfuscated coding :-)
#macro i()function{internal(#end#macro _(Y,Z,k,c)isosurface{function{-Y(
Z(y,2*z,x,1),Z(y,x,z,.3),z,.8)}max_gradient k rotate<k,40>pigment{slope
x color_map{[0c*x][1c*z]}}translate#end _(i()35)}i()36)}99rgb 9)3*z}//CH
btw: I think it could be enough space to not use internal token and build in
real equation :-)
ABX
Date: 22 Mar 2002 11:04:36
Message: <3C9B5614.B8629034@gmx.de>
Nice, but you have to admit that 1 space is really not much.  And it's
only achieved by placing a necessary whitespace at the line break.
The same macro modification shortens my version too:
isosurface{#macro X()function{internal(#end#local Y=X()35)}#local Z=X()
36)}function{-Y(Z(y,2*z,x,1),Z(y,x,z,.3),z,.8)}max_gradient 99 rotate<99
,40>pigment{slope x color_map{[0rgb 9*x][1rgb 9*z]}}translate 3*z}//C.H.
NTL yours is really more obfuscated.
I somehow liked the
in my first version though (it's not only obfuscated but also misleading).
> real equation :-)
I doubt this would fit in 4 lines, but it would definitely look
interesting...
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 22 Mar 2002 11:12:57
Message: <3c9b5808@news.povray.org>
  Couldn't resist:
sphere_sweep{b_spline 20<-2,-2>.1<-2,-1>.15<-1.5,1>.1,0,.1x*-2,.1,-y.1<
-2.5,-1>.1<-.5,-1>.1,0,.1<1,-.5>.1,-y.1<-.5,-.5>.1,0,.1x-y.1<1.5,-.25>.1
x*2,.1<2,-.75>.1x-y.1<1.5,1>.1<1.5,1>.1pigment{rgb 9}translate z*4}//v3.5
Date: 22 Mar 2002 13:36:35
Message: <3c9b79b3$1@news.povray.org>
Well, I changed this a lot, and it isn't exactly what I wanted, but it's
pretty tight for what it does (I think).  Although, somebody more familiar
with the code might do it better. Note that mine can be rotate 180° and
still read the same.
Cheers!
Chip Shults
#macro B(a,b)sphere{<a,b,13>.5pigment{agate}finish{phong.3}}#end#macro
N(a,c)
#local k=1;#while(k<7)#if(mod(c,2))B(k,a)B(-k,-a)#end#local
c=int(c/2);#local
k=k+1;#end#end light_source{0rgb
1}N(1,61)N(0,37)N(-1,55)N(-2,4)N(-3,4)N(3,1)
Date: 22 Mar 2002 16:22:08
Message: <3c9ba080$1@news.povray.org>
For some reason my settings were wrapping it at 76 characters... looks like
junk.  I have corrected that.
Cheers!
Chip Shults
#macro B(a,b)sphere{<a,b,13>.5pigment{agate}finish{phong.3}}#end#macro N(a,c)
#local k=1;#while(k<7)#if(mod(c,2))B(k,a)B(-k,-a)#end#local  c=int(c/2);#local
k=k+1;#end#end light_source{0rgb 1}N(1,61)N(0,37)N(-1,55)N(-2,4)N(-3,4)N(3,1)
Date: 22 Mar 2002 20:33:08
Message: <3c9bdb53@news.povray.org>
#macro B(a,b)sphere{<a,b,13>.5pigment{agate}finish{phong.3}}#end#macro N(c,k,
a)#if(k<7)#if(mod(c,2))B(k,a)B(-k,-a)#end N(int(c/2)k+1a)#end#end light_source
{0rgb 1}N(61,1,1)N(37,1,0)N(55,1,-1)N(4,1,-2)N(4,1,-3)N(1,1,3)
Date: 22 Mar 2002 20:57:52
Message: <3c9be120$1@news.povray.org>
Very nice recursive call!  Also, I see that the middle term of each call is
1, so that could also be pulled out, true?
Cheers!
Chip Shults
Date: 22 Mar 2002 21:00:49
Message: <3c9be1d1$1@news.povray.org>
Ah ah, very neat means of creating the variable- no #declare or #local- my
hat is off to you.
Cheers!
Chip Shults
Date: 22 Mar 2002 22:03:18
Message: <3c9bf076@news.povray.org>
  Let me assure you that I tried to think every possible trick I know of
in order to get rid of that repeating 1, but I couldn't come up with anything
which would have made the code shorter.
  If POV-Ray supported default values for macro parameters then it would
have been possible, but...
Date: 22 Mar 2002 22:06:10
Message: <3c9bf122@news.povray.org>
> hat is off to you.
  It's a "classic" trick. (Not really "classic" in the true sense of the
word because this type of tricks have existed for so short time in this
context, but "classic" in the sense that it's one of the things to look at
to see if a loop could be shortened by replacing it with a recursive macro.)
Date: 22 Mar 2002 22:11:18
Message: <3c9bf256@news.povray.org>
Had no idea that was legal code. Had to render it to believe it.
news:3c9b5808@news.povray.org...
>   Couldn't resist:
Date: 25 Mar 2002 04:23:47
Message: <q0rt9u84k9hkge99bhtu8h5mr2sv5hi3gu@4ax.com>
light_source{0#macro k(_)sphere{13*z+i*_.5pigment{agate}finish{phong.3}}#end
1}#macro _(s,i,g)#if(s)k(1)k(-1)_(s-1i+g,g)#end#end _(3x+3*y<2,-2>)_(2x,y)_(
2x-y,x)_(4x*3,-y)_(4<3,1>x)_(2x*6,-y)
additional note: I had to put one sphere twice becouse of floatting accuracy
problem in current (14) beta
ABX
Date: 25 Mar 2002 12:11:27
Message: <3c9f5a3f$1@news.povray.org>
Wow.
    I see some very clever things here, and they are probably the best tutorial
I could get into some of the features and allowances that the POV language has.
The algorithm is very, very clever also.  I am still unpuzzling parts of it.  I
will be a while thinking of a response to this; I can only hope it is 1% more
clever!
    Thank you both for this extremely complex and obfuscated work of art.  I'll
keep it.
Cheers!
Chip Shults
Date: 26 Mar 2002 04:54:42
Message: <2kf0au0p9ma7a5jm8l7jol6b96ctrcs2ea@4ax.com>
On Mon, 25 Mar 2002 12:11:31 -0500, "Sir Charles W. Shults III"
I used the same method I have used one thread earlier for blob. Rest of sig
are typical obfuscated pov-sig-tricks. And just a little experience.
As next excersise try to unpuzzle and understand my sig. It shows my (imo
suggested in general) rules of obfuscated sig:
1. diversity of shape
  - one disc in sig, infinity planes on image
  - linear spheresweep in sig, curved lines on image
2. diversity of string/data (ABX vs. "-+((1*(,1,/.-,*/(,&.323/'1" )
3. no warning
4. works with default values and dimensions (readable even in 160x120 no AA)
5. no more 4 lines
6. no more 80 (afaik 76/78 are even better) chars per line
Have I forgot something ?
ABX
Date: 26 Mar 2002 05:02:56
Message: <3ca04750$1@news.povray.org>
"W³odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:2kf0au0p9ma7a5jm8l7jol6b96ctrcs2ea@4ax.com...
> ABX
The sig?
Date: 26 Mar 2002 05:44:54
Message: <q7k0auc4b7spvotjccai5g85vddcul0h1l@4ax.com>
On Tue, 26 Mar 2002 10:02:56 -0000, "Tom Melly" <tom### [at] tomandlucouk> wrote:
> > ABX
> The sig?
I forgot to turn it on after beta 14 fix of bug. Fine now ?
ABX
disc{z,-z#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;5pigment{#local g=function(_){ceil(_)-_}function#local
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e)<O(),O()//35
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//ABX
