POV-Ray : Newsgroups : povray.general : I'll try a signature again... Server Time
14 Jul 2026 09:26:16 EDT (-0400)
  I'll try a signature again... (Message 1 to 10 of 18)
Subject: I'll try a signature again...
Date: 22 Mar 2002 09:00:43
Message: <3c9b390b@news.povray.org>
...since it seems a subject which never goes away and I've still lacked a
real one.  Plain as ever before for mine, and definitely not very unique.
Unveiled below where it ought to be.  (yeah, you can picture it already,
huh?)
sphere_sweep{b_spline 20<-2,-2,4>.1<-2,-1,4>.15<-1.5,1,4>.1<0,0,4>.1
<-2,0,4>.1<0,-1,4>.1<-2.5,-1,4>.1<-.5,-1,4>.1,<0,0,4>.1<1,-.5,4>.1
<0,-1,4>.1<-.5,-.5,4>.1<0,0,4>.1<1,-1,4>.1<1.5,-.25,4>.1<2,0,4>.1
<2,-.75,4>.1<1,-1,4>.1<1.5,1,4>.1<1.5,1,4>.1pigment{rgb 9}}//v3.5
Subject: Re: I'll try a signature again...
Date: 22 Mar 2002 09:49:52
Message: <3C9B4491.8EE6E977@gmx.de>
> huh?)
I think i have to show my version sometime too so here it is.
Disclaimer: the use of 'internal' in scenes is officially deprecated so if
Thorsten is mean it will look totally different in the next beta. ;-)
#macro X()function{#end#local Y=X()internal(35)}#local Z=X()internal(36)
}isosurface{X()-Y(Z(y,2*z,x,1),Z(y,x,z,.3),z,.8)}max_gradient 99 rotate<
99,40>pigment{slope x color_map{[0rgb 9*x][1rgb 9*z]}}translate 3*z}//CH
Date: 22 Mar 2002 10:20:32
Message: <dpim9u0acvfcvk0a3jmgi715arcihd9pib@4ax.com>
On Fri, 22 Mar 2002 15:49:53 +0100, Christoph Hormann <chr### [at] gmxde>
I couldn't resist :-)
One space saved and more obfuscated coding :-)
#macro i()function{internal(#end#macro _(Y,Z,k,c)isosurface{function{-Y(
Z(y,2*z,x,1),Z(y,x,z,.3),z,.8)}max_gradient k rotate<k,40>pigment{slope
x color_map{[0c*x][1c*z]}}translate#end _(i()35)}i()36)}99rgb 9)3*z}//CH
btw: I think it could be enough space to not use internal token and build in
real equation :-)
ABX
Date: 22 Mar 2002 11:04:36
Message: <3C9B5614.B8629034@gmx.de>
Nice, but you have to admit that 1 space is really not much.  And it's
only achieved by placing a necessary whitespace at the line break.
The same macro modification shortens my version too:
isosurface{#macro X()function{internal(#end#local Y=X()35)}#local Z=X()
36)}function{-Y(Z(y,2*z,x,1),Z(y,x,z,.3),z,.8)}max_gradient 99 rotate<99
,40>pigment{slope x color_map{[0rgb 9*x][1rgb 9*z]}}translate 3*z}//C.H.
NTL yours is really more obfuscated.
I somehow liked the
in my first version though (it's not only obfuscated but also misleading).
> real equation :-)
I doubt this would fit in 4 lines, but it would definitely look
interesting...
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 22 Mar 2002 11:12:57
Message: <3c9b5808@news.povray.org>
  Couldn't resist:
sphere_sweep{b_spline 20<-2,-2>.1<-2,-1>.15<-1.5,1>.1,0,.1x*-2,.1,-y.1<
-2.5,-1>.1<-.5,-1>.1,0,.1<1,-.5>.1,-y.1<-.5,-.5>.1,0,.1x-y.1<1.5,-.25>.1
x*2,.1<2,-.75>.1x-y.1<1.5,1>.1<1.5,1>.1pigment{rgb 9}translate z*4}//v3.5
Date: 22 Mar 2002 13:36:35
Message: <3c9b79b3$1@news.povray.org>
Well, I changed this a lot, and it isn't exactly what I wanted, but it's
pretty tight for what it does (I think).  Although, somebody more familiar
still read the same.
Cheers!
Chip Shults
#macro B(a,b)sphere{<a,b,13>.5pigment{agate}finish{phong.3}}#end#macro
N(a,c)
#local k=1;#while(k<7)#if(mod(c,2))B(k,a)B(-k,-a)#end#local
c=int(c/2);#local
k=k+1;#end#end light_source{0rgb
1}N(1,61)N(0,37)N(-1,55)N(-2,4)N(-3,4)N(3,1)
Date: 22 Mar 2002 16:22:08
Message: <3c9ba080$1@news.povray.org>
For some reason my settings were wrapping it at 76 characters... looks like
junk.  I have corrected that.
Cheers!
Chip Shults
#macro B(a,b)sphere{<a,b,13>.5pigment{agate}finish{phong.3}}#end#macro N(a,c)
#local k=1;#while(k<7)#if(mod(c,2))B(k,a)B(-k,-a)#end#local  c=int(c/2);#local
k=k+1;#end#end light_source{0rgb 1}N(1,61)N(0,37)N(-1,55)N(-2,4)N(-3,4)N(3,1)
Date: 22 Mar 2002 20:33:08
Message: <3c9bdb53@news.povray.org>
#macro B(a,b)sphere{<a,b,13>.5pigment{agate}finish{phong.3}}#end#macro N(c,k,
a)#if(k<7)#if(mod(c,2))B(k,a)B(-k,-a)#end N(int(c/2)k+1a)#end#end light_source
{0rgb 1}N(61,1,1)N(37,1,0)N(55,1,-1)N(4,1,-2)N(4,1,-3)N(1,1,3)
Date: 22 Mar 2002 20:57:52
Message: <3c9be120$1@news.povray.org>
Very nice recursive call!  Also, I see that the middle term of each call is
1, so that could also be pulled out, true?
Cheers!
Chip Shults
Date: 22 Mar 2002 21:00:49
Message: <3c9be1d1$1@news.povray.org>
Ah ah, very neat means of creating the variable- no #declare or #local- my
hat is off to you.
Cheers!
Chip Shults
