POV-Ray : Newsgroups : povray.general : Particles 101 Server Time
16 Aug 2025 17:08:49 EDT (-0400)
  Particles 101 (Message 1 to 7 of 7)
Subject: Particles 101
Date: 21 Mar 2002 17:32:34
Message: <3c9a5f82@news.povray.org>
global_settings{waffle on}
Okay, so I've made a start on my particle system, but would like a couple of
pointers (or even cheeky samples).  Here's what I've got so far...
Make Some Particles (on first frame):
    pos1=rand(...)
    velocity1=rand(...)
    force1=0
    mass1=1
do for each frame_number
    Load Particle Data (pos, velocity, force, mass, ...extras...)
    Draw The Particles
    Calculate New Positions
    Save Particle Data
next frame_number
Now this seems like a logical choice of steps, so I assume (?) my troubles
are with the calculations.  It must have taken even Him some time to get the
rules right...
The only interaction I'm looking at is the attraction due to each of the
other particles, with BigG being a guess for this system:
//newforce = oldforce + direction*(Universal Gravitation)
#declare force1 = force1 +
    vnormalize(pos2-pos1) * ((BigG * mass1 * mass2) / vlength(pos2-pos1)^2);
which should give me a nice force pulling the particle around, yes?  This is
where I kind of "made it up" to get something that looked like it works:
#declare velocity1 = velocity1+force1;  //first leap of faith
#declare pos1 = pos1+velocity1;  //second leap of faith
Now while this can create some quite nice animations, it seems heavily
dependent on correct settings for BigG with relation to ParticleCount and
mass.
So, is this to be expected?  Particles either achieve escape velocity
immediately, or clash together and head off together into the distance.
Any help greatfully received, although just putting all this down in words
seems to help sometimes too ;)
Mark Hanford
http://www.mrhanford.com/povray
Subject: Re: Particles 101
Date: 21 Mar 2002 22:38:37
Message: <3C9AA765.EEFD3B57@yahoo.com.au>
>     pos1=rand(...)
>     velocity1=rand(...)
>     force1=0
>     mass1=1
>     Draw The Particles
I tend to draw the particles last, but so long as you are consistent...
>     Save Particle Data
> next frame_number
> rules right...
I hope you set each particle's force to <0,0,0> before accumulating the
gravitational forces from the other particles. The total force should not
accumulate between time steps, it should be evaluated at each time step only.
Note that...
velocity = velocity + acceleration*timestep;
and...
acceleration = Force / mass;
Because you have mass = 1, this does not matter, but think of what should happen
when mass != 1.
Note too that the timestep should be small (really small) for a good simulation.
This may mean performing more than one set of position calculations per frame of
animation; for my mini solar system anim, I think I used eight itterations per
frame.
From the looks of it, you are only performing one itteration per frame, so you
might want to try more.
> mass.
Your BigG is scaling your force, so you should expect BigG to make a big
difference. And, the more particles you have, the more forces from neighbours
each individual particle will experience.
Note that BigG in Newtonian physics = 6.67 x 10-11 Nm2/kg2 regardless of the
number of bodies (particles) in the system. My tip is to stick to one BigG value
and adjust the mass of the particles.
Good luck with it. I'm sure others will be able to give you a better explaination
than myself.
MJL
Date: 21 Mar 2002 23:07:09
Message: <3c9aaded$1@news.povray.org>
You're using the (in)famous and forward Euler algorithm, which is very easy
to implement. This algorithm can become instable in some cases (like in your
case).
The following piece of code should make your system a bit more stable.
Increasing the steps per frame and decreasing the step size will make the
simulation slower, but more precise and stable. The damp factor eats away a
very small piece of the velocity at every time step. The more it eats away
(by lowering the damp factor), the more stable the system will be and the
faster the particles loose velocity.
/////////////// code snippet ///////////////
#declare stepsPerFrame = 100;
#declare stepSize = 0.01;
#declare dampFactor = 0.99;
#while (step < stepsPerFrame)
  #declare force1 = force1 + stepsize * vnormalize(pos2-pos1) * ((BigG *
  #declare velocity1 = velocity1 * dampFactor + force1;  //first leap of
faith
  #declare pos1 = pos1 + velocity1 * stepSize;  //second leap of faith
  #declare step = step + 1;
/////////////// end of code snippet ///////////////
Apache
http://geitenkaas.dns2go.com/experiments/
apa### [at] yahoocom
Date: 23 Mar 2002 10:02:40
Message: <3c9c9910$1@news.povray.org>
Consider:
http://www.geocities.com/pterandon/boids.html
Date: 25 Mar 2002 12:43:45
Message: <3c9f61d1$1@news.povray.org>
Thanks!  That looks like it might help in more than one place... I'll give
it a go.
Mark Hanford
"Mark Lewin" <m_j### [at] yahoocomau> wrote in message
news:3C9AA765.EEFD3B57@yahoo.com.au...
couple of
> >     pos1=rand(...)
> >     velocity1=rand(...)
> >     force1=0
> >     mass1=1
> >     Draw The Particles
> >     Save Particle Data
> > next frame_number
troubles
the
> > rules right...
only.
This is
> Note that...
> and...
happen
> when mass != 1.
simulation.
frame of
per
> frame.
you
and
> > mass.
neighbours
the
value
words
explaination
> than myself.
> MJL
Date: 25 Mar 2002 12:44:27
Message: <3c9f61fb@news.povray.org>
I'll try that damping, although at the moment, I think there are more
fundamental issues with my system...
Mark Hanford
"Apache" <apa### [at] yahoocom> wrote in message
news:3c9aaded$1@news.povray.org...
easy
your
> case).
a
> faith
> #end
> Apache
Date: 25 Mar 2002 12:45:02
Message: <3c9f621e$1@news.povray.org>
I saw that page - I did like what I saw, and it had some quite good examples
Mark Hanford
"Greg M. Johnson" <"gregj;-)56590\""@aol.c;-)om> wrote in message
news:3c9c9910$1@news.povray.org...
> Consider:
