POV-Ray : Newsgroups : povray.general : Fast sky / clouds Server Time
3 Nov 2026 08:02:01 EST (-0500)
  Fast sky / clouds (Message 1 to 23 of 23)
Subject: Fast sky / clouds
Date: 19 Mar 2002 14:36:17
Message: <3c979331@news.povray.org>
Yet another of those stacked plane cloud methods!
On my website I've uploaded the code for the sky I'm using for my WIP desert
landscape image as seen in povray.binaries.images. I've gotten a request for
the code, and also saw a general request for stacked plane clouds here
recently.
My approach is not the most realistic maybe, but as it uses four planes
only, it renders very fast.
If you're interested, have a look at
http://rsj.mobilixnet.dk/3d/goodies/goodies.html
Please let me know what you think. :)
Rune
Rune's World:  http://rsj.mobilixnet.dk (updated Feb 16)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
POV-Ray Ring:  http://webring.povray.co.uk
Subject: Re: Fast sky / clouds
Date: 19 Mar 2002 15:31:20
Message: <3c97a018@news.povray.org>
Beside the excellent clouds, the techsphere looks very interesing!
regards
SY
Date: 19 Mar 2002 16:09:35
Message: <3C97A909.CF9743FD@gmx.de>
You're missing the
global_settings{assumed_gamma 1}!
I never thought of you as THAT kind a guy! ;-)
Otherwise fine enough to use, but I'd say some more
comment on how and why would be useful for POVers
who want to actually know what you're doing.
> recently.
Fast, yes, no too realistic, yes, but nice and good for beginners...
Tim Nikias
Date: 19 Mar 2002 16:20:16
Message: <3C97AB8F.2ACCF39B@gmx.de>
> recently.
Looks fairly good for only 4 layers.  And it looks quite a bit different
from the usual 1 layer texture clouds.
For me personally it usually does not matter that much whether the clouds
take 1 or 10 minutes to render...
Last updated 18 Mar. 2002 _____./\/^>_*_<^\/\.______
Date: 19 Mar 2002 16:38:47
Message: <3c97afe7$1@news.povray.org>
Thanks!
I sure hope so.
> whether the clouds take 1 or 10 minutes to render...
That matters very much for me, especially in this case where I need it for
an animation.
Rune
Date: 19 Mar 2002 16:38:49
Message: <3c97afe9@news.povray.org>
"Tim Nikias" wrote:
> You're missing the
Why? It looks awful when I use that setting.
Rune
Date: 19 Mar 2002 16:47:13
Message: <3c97b1e1@news.povray.org>
Of course it does.
First set assumed_gamma 1 THEN code textures (and lights). You'll have to mentally
re-build all your assumptions on colors and finishes, but it's definitely worth it.
BTW very nice sky, esp. since you used only 4 planes.
Jonathan.
"Rune" <run### [at] mobilixnetdk> ha scritto nel messaggio
news:3c97afe9@news.povray.org...
> "Tim Nikias" wrote:
> > You're missing the
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 19 Mar 2002 16:57:06
Message: <3c97b432@news.povray.org>
"JRG" wrote:
> Of course it does.
> You'll have to mentally re-build all your assumptions on
Nah, there must be more to it than that, maybe display_gamma must be set or
something.
When simply using assumed_gamma 1, the results I get are wrong. A white
pigment in shadow, which should be 10% white looks more like 60% white,
which is way too bright. When I don't specify any assumed_gamma it looks
like 10% white as it should. My monitor gamma is about 2.2, which is the
default.
Thanks!
Rune
Date: 19 Mar 2002 17:15:23
Message: <3C97B87B.150C66B7@gmx.de>
There is no complete shadow in your scene and with a light source of color
rgb 3 you should expect it being bright.
Date: 19 Mar 2002 17:20:51
Message: <3c97b9c3@news.povray.org>
> light source of color rgb 3 you should expect it being bright.
You seem to assume I'm talking about that cloud scene? I'm not. This is my
test scene:
// global_settings{assumed_gamma 1}
light_source {<1,2,-2>*100, rgb 1}
sphere {3*z, 1 pigment {rgb 1}}
Rune
Date: 19 Mar 2002 17:33:33
Message: <3c97bcbd@news.povray.org>
news:3c97b9c3@news.povray.org...
> test scene:
The default finishes (esp. ambient is way too high) do not match well with
assumed_gamma 1.
This worked for me:
global_settings {
    ambient_light 0
    assumed_gamma 1
#declare White_Texture =
        rgb 1}
    finish {
        ambient 0
        diffuse 0.75
        specular 0.65
        roughness 0.008
        reflection {0.03,1 falloff 5}
    normal {
        bumps 0.05 scale 1}
sphere {
    3*y+5*z,3
        White_Texture scale 0.08}
plane {y,0
    pigment {rgb 0}
    finish {ambient 0
        diffuse 0.8  specular 0.5 roughness 0.01 reflection 0.2
light_source {
    <0,140,0>
    rgb 1
    area_light 30*x,30*z,5,5 adaptive 0 jitter circular orient
    fade_power 2
    fade_distance 100
light_source {
    <-30,80,-99>
    rgb 1
    area_light 10*x,10*y,5,5 adaptive 0 jitter circular orient
    fade_power 2
    fade_distance 120
light_source {
    <0,50,99>
    rgb 0.8
    fade_power 2
    fade_distance 100
#version 3.1;
    location <0,25,-40>
    right image_width/image_height*x
    look_at 5*y
    angle 20
    rotate 5*y
Date: 19 Mar 2002 18:01:31
Message: <3c97c34b$1@news.povray.org>
I fully agree. What's the catch in using gamma 1?  I have read about these
things but I don't see any benefit of stepping away from 2.2
Thanks for sharing the cloud code Rune!  :o)
Hugo
Date: 19 Mar 2002 18:01:56
Message: <3C97C3C4.DBD5A99C@LuxLab.com>
The result is right, you just expect something else. Remember
that the monitor distorts your perception of the true relations
in the scene. Without assumed_gamma you are seeing a distorted
image.
When using assumed_gamma 1, one tends to build scenes with fixed
contrast ratio so they will look good without post processing.
This limits the scenes somewhat but no more than before. It will
train the eye to see the true relations in a scene, which is
valuable knowledge. It will enable you, with post processing, to
build scenes in a wide range of contrast ratios.
_____________
Kari Kivisalo
Date: 19 Mar 2002 18:11:30
Message: <3C97C602.BB87F907@LuxLab.com>
You have to be prepared to step into a higher level of consciousness.
Seriously, if you don't get it, don't stress about it.
_____________
Kari Kivisalo
Date: 19 Mar 2002 18:25:31
Message: <3c97c8eb@news.povray.org>
Isn't the whole point of gamma correction to assure a linear scale of
brightness or whatever it's called? So that when you specify a color that's
half as bright as another color, you really do percieve it that way when
looking at it?
What I'm saying is that when I specify a color of 10% brightness in relation
to white, I don't want to get a color that looks like it's of 60% brightness
in relation to white.
Could you explain your point further?
Rune
Date: 19 Mar 2002 18:27:29
Message: <3c97c961$1@news.povray.org>
> Remember that the monitor distorts your perception of
> the true relations in the scene. Without assumed_gamma
> you are seeing a distorted image.
This is what I mean. The monitor distorts the light and by using
assumed_gamma 2.2, the final result that hits my eye is correct.. (?)
> level of consciousness. Seriously, if you don't
Hmm.. I am ready.. I know you're good at this light stuff. :o)
Hugo
Date: 19 Mar 2002 19:20:22
Message: <3c97d5c6$1@news.povray.org>
Thank you!  I've been looking for this!
- Kevin R.
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c979331@news.povray.org...
desert
for
> recently.
> Rune
Date: 19 Mar 2002 19:23:12
Message: <3C97D6D0.F68C64DF@LuxLab.com>
I blame the docs. It's really the other way around. If your
display_gamma is 2.2 or not set, using assumed_gamma 2.2 does
nothing. assumed_gamma 1 corrects for gamma 2.2 display. At least
in 3.5.
I hope so or the folks at luxlab.com will be really disappointed.
Ok, the laboratory was empty, I went there and now I'm pretending
to be the prof :)
_____________
Kari Kivisalo
Date: 20 Mar 2002 04:14:58
Message: <3c985312$1@news.povray.org>
> your display_gamma is 2.2 or not set, using
> assumed_gamma 2.2 does nothing. assumed_gamma 1
> corrects for gamma 2.2 display. At least in 3.5.
I just read the Pov-docs about display_gamma.. Made me confused, but I think
display_gamma should be linked to that of my graphics card.. By default it's
2.2 when not specified in povray.ini (which it is not).. Assumed_gamma
should be 1.. This means, what appear on my monitor will be gamma corrected
on-the-fly but the image on disk will be non-gamma corrected.
This doesn't sound like a good idea for most people.. Almost every picture
we download from the net has already been gamma corrected, and would suffer
from further (such heavy) adjustments. I don't use windows-controlled gamma
correction, and I doubt many people do.
> do not match well with assumed_gamma 1.
This doesn't sound similar to Kari Kivisalo? He seems to simply describe
another way of using the same amount of gamma correction.. So that shouldn't
change the way we use light and textures?
Regards  :o)
Hugo
Date: 20 Mar 2002 08:59:04
Message: <3C989608.7EAB1602@LuxLab.com>
The section on display_gamma points to 6.11.3 for more information on gamma.
6.11.3 Assumed_Gamma
no assumed_gamma in scene :
   No gamma correction is applied to output file.
assumed_gamma 1 :
   Gamma Display_Gamma is applied to output file.
   If Display_Gamma is not specified, 2.2 is used.
assumed_gamma G :
   Gamma Display_Gamma/G is applied to output file.
   If Display_Gamma is not specified, 2.2/G is used.
Recommended value for assumed_gamma is 1.
The render window displays the image as it is written to file.
Radiosity works best with assumed_gamma 1 as will any feature
designed to simulate reality, like fresnel reflection.
Two tips to ease your path to enlightenment:
  Write rgb 0.2 instead of rgb 0.5 and rgb 0.03 instead of rgb 0.2.
  Don't hesitate to use image editor to enhance contrast at first.
Oh, and rgb 0.8 -> rgb 0.6 :)
_____________
Kari Kivisalo
Date: 20 Mar 2002 10:37:11
Message: <3c98aca7$1@news.povray.org>
Thanks! From what I sense here, assumed_gamma 1 actually *activates* a gamma
correction of 2.2 in the output file, where the default assumed_gamma 2.2
becomes nothing because it gets divided with display_gamma 2.2.
Oh man! So instead of simulating gamma correction myself by using ordinary
rgb values, I should let the computer do this.. Yes, I understand this now!
Old rgb values should be ^ with 2.2 to get the new values ... but maybe it's
not so simple with finishs.. hmm.. but thank you!
Hugo
Date: 20 Mar 2002 10:54:09
Message: <chrishuff-68FB22.10541620032002@netplex.aussie.org>
In article <3c98aca7$1@news.povray.org>, "Hugo" <hua### [at] post3teledk>
With the finish statements that specify a brightness (reflection,
ambient, diffuse, phong, specular), it should be similar. With
statements that specify a size or falloff (brilliance, roughness,
phong_size), it would be like "gamma correcting" the radius of a sphere,
which is of course nonsense.
And don't forget your lights.
Date: 20 Mar 2002 15:09:26
Message: <3c98ec76$1@news.povray.org>
I made the bumps a bit smaller and got a perfect desktop. Again simplicity
is beautiful. Thanks, Jonathan.  :)
Ari-Matti
