POV-Ray : Newsgroups : povray.general : keyring background Server Time
23 Oct 2026 05:42:50 EDT (-0400)
  keyring background (Message 1 to 28 of 28)
Subject: keyring background
Date: 15 Mar 2002 20:18:10
Message: <3c929d52@news.povray.org>
The flying keyring image on http://www.povray.org
is currrently is in jpg format and therefore has non-transparent background,
and it's frame doesn't look nice when flying.
Isn't it better to use gif with transparent bg?
Gleb
Subject: Re: keyring background
Date: 15 Mar 2002 22:01:14
Message: <3c92b579@news.povray.org>
  Better PNG with alpha channel. This way you get nice antialiasing to the
background.
Date: 16 Mar 2002 02:47:07
Message: <3c92f87b@news.povray.org>
> background.
Well, theoretically at least. IE wouldn't like it, it'd end up looking
uglier to most people.
Plus, despite PNG's great compression, it would probably be slower than a
JPG. A gif would certainly be slower. I always figured it wasn't that
important.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 16 Mar 2002 04:03:42
Message: <3C930B0E.70700@my.email.address>
>>background.
Use Netscape. It doesn't do the animation. Problem solved! :-)
/Ib
Date: 16 Mar 2002 05:37:36
Message: <3c932070@news.povray.org>
Do you mean bigger?
Gleb
Date: 16 Mar 2002 09:54:55
Message: <3c935cbf$1@news.povray.org>
Both. In most cases, bigger file size means slower download ;-}
"Gleb" <gk1### [at] sotonacuk> wrote in message news:3c932070@news.povray.org...
a
> Do you mean bigger?
> Gleb
Date: 16 Mar 2002 11:08:13
Message: <3C936DED.EB3E579C@scifi-fantasy.com>
> > than a JPG. A gif would certainly be slower.
> Do you mean bigger?
Actually, a gif can be smaller than a JPG.  If you have, say, a line-
art image, or one which uses few colours in large areas, a gif will
be smaller.
- Tim Cook
Date: 16 Mar 2002 14:00:27
Message: <3c93964b$1@news.povray.org>
"Mahalis" <don### [at] fakeycom> wrote in message
news:3c935cbf$1@news.povray.org...
An example gif with transparent bg posted to p.b.i
This draft has 32 colours only, but is 8.5K vs 14K in original jpg
If one consider that quality is poor than it's possible to increase colours,
etc.
Gleb
Date: 16 Mar 2002 14:28:43
Message: <3c939ceb@news.povray.org>
> be smaller.
  But a PNG will be generally slightly smaller than the equivalent GIF
(because PNG has a better compression algorithm).
Date: 16 Mar 2002 14:47:53
Message: <3c93a169@news.povray.org>
Ouch ...
You know, there does not exists something like the "best" compression ...
There can't be an algorithm that compresses better in ALL cases than any other
algorithm you choose ...
Date: 16 Mar 2002 16:08:20
Message: <3c93b443@news.povray.org>
  However, one algorithm can compress in *average* better than another.
Date: 16 Mar 2002 16:23:04
Message: <3c93b7b8@news.povray.org>
define "average" ... as you probably know, there are different kind of messurements
If you think about the standard [ (x1+x2+x3)/3 ] average, then I wouldn't
swear on this for an infinite set of sources to compress ...
Maybe it _CAN_ be true for a countable, closed set ...
(as for all possible images, where it could be computable) but I'm still not sure
'bout this ...
BTW: After thinking a while, I came to the conclusion that your first
statement was not necessarily wrong...
It is of course possible, that one algorithm is worse for every case, than another ...
Date: 17 Mar 2002 15:06:51
Message: <tSl8bEAIQJl8Ew1t@econym.demon.co.uk>
>messurements ...
>sure 'bout this ...
For lossless compression, there are good reasons for believing that the
*overall* average compression should be none whatsoever.
Suppose we compressed all possible images of a given size and colour
depth losslessly. The number of different images would be
height*depth*colour-depth. If our compression is lossless, it must give
a different compressed result for each of the input image files, i.e.
height*depth*colour-depth different compressed files. For these output
files to all be different, their average length would need to be
height*depth*colour-depth bits - which is what we started with.
Mike Williams
Gentleman of Leisure
Date: 17 Mar 2002 16:18:47
Message: <3c950837@news.povray.org>
No-one said that a compression scheme should use just *one* compression
algorithm.
  The simples case of using two algorithms is: First try compressing
with the compression algorithm, and if the result is bigger than the
original, just store the raw image.
  This way some of the images will be smaller than the original and some
will be equal. None of the images will be larger than the original.
  This way the overall average compression rate will be higher than 1.
Date: 17 Mar 2002 16:48:13
Message: <3c950f1d$1@news.povray.org>
> algorithm.
nope !
you have to store at least one bit more (for every image), telling you which
of the both algorithms to use.
Of course, in practice you could tell this probably tell this from the filename
(*hey-idea*: why not store the whole image-data in the filename ? ;), but in theorie
there's nothing like an "filename". So these additional bits would make the
o-a-c-r at least 1.
Assuming, of course, we're speaking 'bout lossless compression ...
This all is coveres by the chapter about kolmogorov-complexity...
Date: 18 Mar 2002 02:48:48
Message: <vyD8zBATTZl8EwWn@econym.demon.co.uk>
>algorithm.
The logic still holds. The data plus the information telling you which
decoding system to use must span all possible images, so information
theory strongly suggests that on average you get no compression.
There are some people who dispute this reasoning. For example ZeoSyc
seem to be claiming that they have invented a lossless compression
algorithm that can compress random data by a factor of 100. Their
algorithm is currently secret, pending patent application.
Mike Williams
Date: 18 Mar 2002 09:24:10
Message: <3c95f88a@news.povray.org>
  In fact, every image file has to contain at least the information about
its dimensions. Generally at least 4 bytes are used to define the dimensions
of the image.
  Besides this, it usually contains information about the pixel depth (ie.
how many bits per pixel it has).
  This means that taking every possible image (ie. every possible pixel
combination), on average you get a *bigger* file than the plain raw image.
  The *only* way of getting an average of no compression is that we only
use fixed-sized images with fixed-sized pixel depth.
  But in this case the size of the file itself is the piece of information we
need to know if the compression algorithm was used or if the image is raw:
If the size of the file is exactly what is needed to contain the raw image
data, then compression was not used. If the size of the file is smaller, then
compression was used.
  In this case we get an average file size which is smaller than the original
file size.
  I think this is theoretically impossible, as shown in this thread.
  Of course if they say that *some* images can be compressed by a factor of
100, then it's believable. However, it's nothing fancy: Just take a huge
image with one color and compress it with whatever algorithm you like. You
can easily get a compression factor of 100000:1 if you want.
Date: 18 Mar 2002 13:35:39
Message: <3c96337b@news.povray.org>
> Just take a huge image with one color and compress it with whatever
> algorithm you like. You can easily get a compression factor of
Heheh ... yes ... create a GIF file of 4096x4096, 2-Bit with one
color. Attach this on a mail, that goes to an Outlook user ... *g
He is lucky, if he doesn't use the preview-function ..
Date: 18 Mar 2002 15:36:22
Message: <3c964fc6@news.povray.org>
In article <3c96337b@news.povray.org> , "Jan Walzer" <jan### [at] lzernet> wrote:
A true color PNG image of the same size will work even better...
BTW, such a 1 bit GIF is about 11 KB and a 24 bit PNG about 78 KB, so it could
really work!
    Thorsten
e-mail: tho### [at] trfde
Date: 18 Mar 2002 19:07:37
Message: <3c968149@news.povray.org>
> really work!
  I just tried to compress a 4096x4096 image to PNG with pngcrush (using its
brute force search for the best compression settings).
  At 24 bits per pixel the image file is 58540 bytes long, and at 8 bits
per pixel it's 2131 bytes long.
  (I really wonder why the 24-bit image is so big. Why not three times the
size of the 8-bit version?)
Date: 18 Mar 2002 20:30:12
Message: <3c9694a4@news.povray.org>
news:3c968149@news.povray.org...
could
> > really work!
its
I'm just guessing but I would suppose that at 8-bit there are larger blocks
of the same color than at 24 bit and larger blocks are easier to compress?
Correct me if I wrong I'm just taking an educated stab here.
Corey
x]
Warp -
Date: 18 Mar 2002 20:46:17
Message: <3c969869$1@news.povray.org>
When compressing to 8 bit, you gain in two respects- one is that you
have a far smaller palette to work with, so you spend about one third of the
space right off the bat.  But another thing happens as well- smaller
"distances" between colors mean that you will have better image compression
ratios.  Take JPG compression for instance.
    If you are familiar with the first term of palette reduction, you can
see that you could create a small table that represents some basic set of
colors and that table might be far smaller than 256 colors in some images.
You might get by with a mere 50 to 70 base colors.  6 bits might be
sufficient to adequately describe your color subset.
    Then, you create the "templates" that a DCT (discrete cosine transform)
might use to describe how an 8x8 cell of the image might be recreated using
some small number of those colors, using three templates that get overlaid
to describe the RGB components.  There are not many such templates used,
thus resulting in a further compression.
    Overall, JPG is lossy exactly because the data is not perfectly
recreated; it is "derived" from some basic selection of colors and then DCT
templates are used to approximate what they looked like.  Other schemes such
as run length encoding are done it other systems.  GIF is a perfect example.
When you go to a small number of colors and then specify that 61 dots
following this one will all be color 46 from the palette, you can see some
immediate benefits right there.
    Of course, each image format has its advantages and disadvantages, and a
truly universal image compression routines would analyze an image and select
the one that gave best compression and lowest loss and then recommend that
file format for your final image.  There's a useful tool to write.
Cheers!
Chip Shults
Date: 19 Mar 2002 06:24:36
Message: <3c971ff4@news.povray.org>
In article <3c968149@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
I was surprised by the size of the 24 bit image as well.  I suppose it is
because the image data internally is handled in such a way that it gives
better results for images with lots of color changes.
Did you try to play with manually setting the compression window size (if the
program you are using allows this)?  Maybe this will give better results...
    Thorsten
Date: 19 Mar 2002 08:17:32
Message: <3c973a6c@news.povray.org>
  By setting the compression window size to 512 (which seems to be the maximum
zlib supports; the default seems to be 4), the file was reduced to 55976 bytes.
  It's still oddly large.
Date: 19 Mar 2002 08:23:56
Message: <tree9u4ug8ega996jhl0j8fccpe2mpjjdm@4ax.com>
I think it's becouse of some kind of dictionary.
ABX
Date: 19 Mar 2002 08:39:35
Message: <3c973f97@news.povray.org>
  Curious. I supposed that converting the image to JPG could make it laughably
small. However, no matter what compression settings I use, I can't get it
smaller than the PNG! :-o
Date: 20 Mar 2002 11:26:09
Message: <3c98b821$1@news.povray.org>
news:3c950837@news.povray.org...
This is not also true in all cases. Have you tried to "compress" just one
pixel? or two?
"Compressed" (means represented in some known format) file can be larger
than the original image,
because it also has to store some extra info.
Gleb
Date: 20 Mar 2002 14:43:07
Message: <3c98e64b@news.povray.org>
> pixel? or two?
  Read my posts again: The idea was that if the compressed file is larger
than the raw file, then just store the image in raw form.
