POV-Ray : Newsgroups : povray.general : Tiling onto a sphere? Server Time
3 Nov 2026 10:33:00 EST (-0500)
  Tiling onto a sphere? (Message 1 to 6 of 6)
Subject: Tiling onto a sphere?
Date: 27 Feb 2002 18:39:40
Message: <3c7d6e3c$1@news.povray.org>
Please excuse me if I'm not using the word 'tiles' in the context it
is used in POV-Ray. I couldn't think of a better phrase to put in
the subject line...
I need to know if it is possible to specify where on a sphere you
want an image to go without it completely filling the surface of
the sphere (by tiling or being stretched over the entire suface).
Maybe it would be clearer if I give an example. Suppose you
have a satellite image of Washington D.C., a satellite image of
the surrounding states, and a satellite image of the entire Earth
and you want to create an animation that zooms in from space
onto the D.C. image, utilizing all three images as resolution
demands.
Another example would be if you had 24 unique 45° x 45° tiles
comprising the entire surface of the Earth. The total dimensions
of all the tiles combined into a single image is way beyond what
my paint program can handle (please don't say get Photo Shop -
I know, I know). :-)
Can POV-Ray put those tiles into their respective positions on a
sphere according to user-defined inputs?
(That second example is what I may be dealing with.)
Mike
Subject: Re: Tiling onto a sphere?
Date: 28 Feb 2002 02:05:23
Message: <xmj72FA6Mdf8EwlP@econym.demon.co.uk>
>the subject line...
>demands.
Here's a rather un-POVlike way of doing it:-
Instead of a true sphere, create a spherical mesh2 with a texture_list
and uv_vectors. The texture_list would be a list of the 24 unique 45° x
45° tiles, and the uv mapping would specify which part of the texture
listed tile is associated with each face of the mesh.
Mike Williams
Gentleman of Leisure
Date: 28 Feb 2002 03:37:13
Message: <3C7DEC39.580603BC@gmx.de>
> demands.
Arbitrary map projections should be possible in Povray 3.5 using functions
as long as you know about the math of the projection.  Note that not all
kinds of projection used in geography can be described through a precise
formula though.
Last updated 21 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 28 Feb 2002 12:51:34
Message: <3C7E6E24.9FABF6CA@spiritone.com>
> the subject line...
> demands.
> Regards,
> Mike
Using 3.1, no. Man, now I have to go try to get this to work and stop my
housecleaning and database programming. (shucky darn ; ) )
I'll let you know what I find. It might even make a cyclopedia entry
Josh English
eng### [at] spiritonecom
http://www.spiritone.com/~english
Date: 28 Feb 2002 16:04:01
Message: <3c7e9b41$1@news.povray.org>
There is a patch in MegaPov which allows you to use frequency, phase, and
once for spherical image maps. As is, it allows you to cut the map up into
strips which would then run pole to pole. I added to it the ability to use
two frequencies and two phases in order to cut a map up into tiles. So far I
have only used my patch privately. Email me privately if you want more info.
Are you using this with the Blue Marble dataset? That's what I am using it
for.
Date: 3 Mar 2002 22:17:10
Message: <3c82e736@news.povray.org>
Chris Jeppesen wrote in message <3c7e9b41$1@news.povray.org>...
>I have only used my patch privately. Email me privately if you want more
>info.
I tried sending a couple of e-mails. Hope they got through.
>for.
Yep. :-)
Mike
