Hi.
I managed to get trace() to work, but I found something that I could find in
the help files. I made the following scene.
location <2,2,-2>
look_at <0,0,0>
light_source { <100,100,-100> color rgb 1 }
#local thing = cone { <0,1,0>,0,<0,0,0>,1 }
#local norm = <0,0,0>;
#local r = seed(0);
object { thing pigment { rgbt <1,0,0,0.7> } }
plane { <0,1,0>,0 pigment { rgb <0,1,0> } }
#local a = 0;
#while (a<500)
#local placex = 1-(2*rand(r));
#local placez = 1-(2*rand(r));
#local start = <placex,10,placez>;
#local ending = <placex,-100,placez>;
#local place = trace(thing,start,ending,norm);
#if (vlength(norm)!=0)
sphere { place,0.05 pigment { rgbt <1,1,1,0.5> } }
#else
sphere { <placex,0,placez>,0.05 pigment { rgb <0,0,1> } }
#local a = a + 1;
It renders as expected: white spheres are on the cone and those that don't
hit the cone are blue and on the plane.
If I chance the line 15 from #local start = <placex,10,placez>; to #local
start = <placex,100,placez>; the amount of white spheres decreace and a lot
of blue spheres appear inside the cone. To my sense the scene should be
exactly same as before. Is there some reason the program works this way or
am I missing something here?
On Wed, 20 Feb 2002 16:39:42 +0200, "Klaus Lehtonen" <leh### [at] hotmail com>
third parameter of trace is value of direction vector,
not ending point of direction vector
I suppose You want:
#local ending = <0,-1,0>;
change to this and check again your script
ABX
Thanks! Now it makes sense. I had totally missed that bit.
"W³odzimierz ABX Skiba" <abx### [at] babilon org> kirjoitti
viestissä:khe77ustr9onfenig3c4juclkeavq6m8qr@4ax.com...
> I suppose You want:
> ABX
