POV-Ray : Newsgroups : povray.general : Cubic spline question Server Time
23 Oct 2026 12:22:03 EDT (-0400)
  Cubic spline question (Message 1 to 17 of 17)
Subject: Cubic spline question
Date: 15 Feb 2002 17:22:36
Message: <3c6d8a2c@news.povray.org>
I'm getting confused by cubic splines.
Doesn't cubic splines work that way that any point on the spline is
dependent on exactly four control points, no more, no less? At least that's
the impression I get from the POV-Ray documentation, and when using cubic
splines in prisms it works exactly that way indeed.
But the cubic spline used in the spline feature in POV-Ray 3.5 works
completely differently. It seems that there any point on the spline is
dependent on all the control points, or at least much more than four as far
as I can see. The code below illustrates it (POV-Ray 3.5 beta 11).
So, can anyone enlighten me?
camera {location 6*y look_at 0 translate 3*x}
light_source {1000*y, color 1}
plane {y, 0 pigment {checker color rgb 1.0, color rgb 0.9}}
#declare Spline =
spline {
   cubic_spline
   0, 0*x+30*z,
   1, 1*x,
   2, 2*x,
   3, 3*x,
   4, 4*x,
   5, 5*x,
   6, 6*x,
#declare C = 0;
#while (C<=240)
   #declare V = C/40;
   #declare Color = <0,0,1>;
   #if (V=int(V)) #declare Color = <1,0,0>; #end
   sphere {Spline(V), 0.03+Color.x/50 pigment {color Color}}
   #declare C = C+1;
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Jan 20)
Subject: Re: Cubic spline question
Date: 16 Feb 2002 00:53:58
Message: <3c6df3f6$1@news.povray.org>
Well, I don't have a copy of Povray handy to fire up and play with,
but as I understand it, the spline of any *segment* depends on exactly
4 points.  But splines can have more than 1 segment.
So with the points 0-6 in your example, you'd have the following
segments:
Segment 0:  exists between points 1 and 2, defined by points 0, 1, 2, 3
Segment 1:  exists between points 2 and 3, defined by points 1, 2, 3, 4
        2:                        3     4                    2, 3, 4, 5
        3:                        4     5                    3, 4, 5, 6
Jamie
Date: 16 Feb 2002 01:01:25
Message: <3c6df5b5@news.povray.org>
Rune wrote in message <3c6d8a2c@news.povray.org>...
I tried using the four control point method for pure splines, but that
resulted in sharp turns at the control points.  The "all control points"
method gives a spline that is smooth along its entire length (essential for
those applications that require computing the second derivative of the
spline).
Mark
Date: 16 Feb 2002 05:07:42
Message: <3c6e2f6e@news.povray.org>
> but that resulted in sharp turns at the control points.
Funny, I've never had that problem and the splines in prisms don't have it
either.
> The "all control points" method gives a spline that is
> smooth along its entire length (essential for those
> derivative of the spline).
That's probably a fine spline, but is it a cubic spline or a completely
different type? To have different spline types go under the same name seem
like a very bad thing to do. Is it official POV-Team policy to do that?
Rune
Date: 16 Feb 2002 05:54:51
Message: <3c6e3a7b$1@news.povray.org>
> different type?
I asked some spline questions a while ago because I think, Pov spline { }
behaves in unexpected ways that are hard to control. By reading Chris
Colefax's spline toturial I found that "cubic splines" are a broad class of
spline types. None of them seems to completely resemble the Pov spline { }
but I don't know for sure.. Someone told me, Pov is using "natural cubic
splines".. That's all I can tell.. With all respect to the Pov-team, I think
Colefax has done a better job, but it's alright for a beginning.
Hugo
Date: 16 Feb 2002 06:23:19
Message: <3c6e4127@news.povray.org>
"Hugo" wrote:
> By reading Chris Colefax's spline toturial I found that
> "cubic splines" are a broad class of spline types.
But AFAIK all of them use four control points per segment (because they're
cubic).
> Someone told me, Pov is using "natural cubic splines"..
I think that all splines in POV-Ray that go under the name "cubic spline"
should be identical, that being in prisms, spline{} or anything else. The
way it currently is seems very inconsistent and IMO strange.
Rune
Date: 17 Feb 2002 01:56:17
Message: <3c6f5411@news.povray.org>
Rune wrote in message <3c6e2f6e@news.povray.org>...
I am getting quite tired of repeatedly having to defend my decision on how
cubic splines work.  Rune, for the record, this is the third time I have
explained this to you.  This is the last time I will say this.  For the
record, here is what I have to say on the matter:
Cubic splines are a *very* *broad* *class* of splines.  The type I have
chosen to code in the spline{} functionality of POV-Ray are the natural
cubic splines.
From _Numerical Mathematics and Computing, Fourth Edition_, by Ward Cheney
and David Kincaid, a natural cubic spline is one where:
1) The function is constructed from a number of cubic polynomial pieces
2) The function is continuous
3) The first derivative of the function is continuous
4) The second derivative of the function is continuous
5) The function passes through all control points
6) The second derivative of the function is zero at the first and last
control points
For cubic splines in general, the first four conditions hold.
_Applied Numerical Methods_, by Brice Carnahan, H. A. Luther, and James
Wilkes agrees with these definitions.
These are the two textbooks I used in developing the cubic splines used in
the spline{} code.
From my experiments with producing a cubic spline by fitting a cubic
polynomial to each set of four control points, the resulting curve is
continuous and passes through all control points, but does not have
continuous first or second derivatives, and so is not a cubic spline of any
sort.  Rune, if you'll look at the image you attached to the post "Yet
another spline bug", posted on 8/29/01 in the povray.pre-beta.binaries
group, you'll see what happens when you produce a curve by this method.
From looking at the code for the prism object, it appears that this is the
method used by that object.
Rune, if you want a different behavior for cubic splines, please code it
yourself.
Mark
Date: 17 Feb 2002 03:04:19
Message: <3C6F644A.5E797131@engineer.com>
> control points
I can verify that cubic_spline in beta 11 meets these specifications.
Differences between splines through random 3D point sets produced by spline{}
and my lspline3 macro are too small to be noticed.
_____________
Kari Kivisalo
Date: 17 Feb 2002 03:56:46
Message: <3c6f704e@news.povray.org>
> defend my decision on how cubic splines work.
> have explained this to you.
I didn't know that, because the way the cubic splines have been worked have
been changing many times.
I acknowledge that I there's many things in this issue I don't know, so
that's why I asked. Ok, so the splines in the spline{} are indeed cubic
splines, just a different type than the splines used in prisms, which are
also labeled cubic splines.
> "Yet another spline bug", posted on 8/29/01 in the
> povray.pre-beta.binaries group, you'll see what happens
> when you produce a curve by this method. From looking at
Sorry, but the sharp corners in the image I posted on 8/29/01 in the
povray.pre-beta.binaries group were caused by a buggy implementation rather
than the spline type itself. FYI prisms do not have such sharp corners.
Here are the problems I have with the current situation:
Cubic splines are a broad class of spline types, yet in both prisms and
spline{} it means a very specific spline. This wouldn't matter so much if it
was the same one in all features of POV-Ray, but to have the word
cubic_spline mean different things in different context is very inconsistent
and is bound to cause confusion.
The natural cubic splines are very difficult to control. Once you have
gotten one segment to look just right, it can be ruined by any of the next
control points added. One serious result of this is that it's nearly
impossible to make a smoothly closed (looping) spline. When using the spline
type in prisms there's an easy rule to follow which is that the first three
an last points should be identical. But with natural cubic splines I have
yet to succeed to make a loop. Can anybody explain how to do it? Perhaps it
would be a good idea if it was explained in the documentation how to make a
smoothly closed spline with this spline type. It would be very relevant!
The best solution in my opinion would be to call the natural cubic spline by
another name maybe "natural_cubic_spline" and then also have support for the
cubic spline type used in prisms, which is easier to control. But of course,
as usual the answer is "please code it yourself" so I guess there's no hope
of seeing that implemented.
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Feb 16)
Date: 17 Feb 2002 06:06:41
Message: <3c6f8ec1$1@news.povray.org>
Rune wrote in message <3c6f704e@news.povray.org>...
it
inconsistent
If I knew for certain what sort of cubic spline is used in "prism", I'd be
able to duplicate it and add it as another type of pure spline.
Mark
Date: 17 Feb 2002 06:41:54
Message: <Xns91B8817AE8F1Cseed7@povray.org>
On 2002 02 17, you wrote in povray.general:
> I'd be able to duplicate it and add it as another type of pure
> spline.
If I understand the source right it indeed is a Catmull-Rom spline:
 CatMul Rom basis Matrix (hits every input vector)
 As T goes from 0 to 1 you go from n to n+1
          n-1      n   n+1   n+2
   T^3     -1     +3    -3    +1     /
   T^2     +2     -5     4    -1    /
   T^1     -1      0     1     0   /  2 (divisor)
   T^0      0      2     0     0  /
In that case, could you use the spheresweep code?
Also IMO in the spheresweep the camul_rom_spline keyword should be
replaced by cubic_spline. In the docs we can then make clear that what
is
called a cubic spline in POV-Ray is the catmull-rom spline.
I posted a basic file on splines, that shows the matrices and the their
in:
Newsgroups: povray.binaries.tutorials
Subject: Splines.bas
Message-ID: <Xns### [at] povrayorg>
Date: 17 Feb 2002 06:35:16 -0500
Xref: news.povray.org povray.binaries.tutorials:1289
Ingo
p.s. (sorry Mark, hit a wrong button, so you also got it by mail)
Date: 17 Feb 2002 07:07:17
Message: <3c6f9cf5@news.povray.org>
> in "prism", I'd be able to duplicate it and add it as
I'm very happy to hear that.
I hope Ingo's reply is of help to you. I myself know something about splines
as a user, but my knowledge of splines from a developer's point of view is
rather limited.
Rune
Date: 17 Feb 2002 07:07:22
Message: <3c6f9cfa@news.povray.org>
> should be replaced by cubic_spline. In the docs we can
> then make clear that what is called a cubic spline in
I agree this would be a good idea.
However, another option would be to use the keyword catmull_rom_spline
everywhere that spline type is used, including in prisms. That might be a
more logical choice if more than one type of cubic splines are implemented
in POV-Ray. cubic_spline used in prisms should still be a valid keyword for
backwards compatibility, but should work the same way as catmull_rom_spline.
In spline{} and sphere_sweep{} the keyword cubic_spline shouldn't be allowed
at all (as there's no backwards compatibility issue), and instead the
keywords catmull_rom_spline and perhaps natural_cubic_spline or something
like that should be used instead.
This is just a suggestion.
Rune
Date: 18 Feb 2002 00:38:00
Message: <3c709338@news.povray.org>
ingo wrote in message ...
>> spline.
I've looked up some information on Catmull-Rom splines on the Internet, and
it looks like they fit properties 1, 2, 3, and 5 from my earlier list.
Catmull-Rom splines do not, however, have a continuous second derivative.
Since part of the reason I implemented cubic splines the way I did was to
get a function with a continuous second derivative, I won't replace the
existing cubic splines with Catmull-Rom splines.  It should, however, be
easy enough to add Catmull-Rom interpolation to the various spline
interpolation methods.
Mark
Date: 18 Feb 2002 05:49:21
Message: <j4j17u0sbm72id5dffh7bnsr9g9cu92f1k@4ax.com>
On Fri, 15 Feb 2002 23:20:56 +0100, "Rune" <run### [at] mobilixnetdk>
Rune, In general I agree with you that one spline_type_name should always
produce the same shape apart from place of use. When name specifies not exact
type but class of types then perhaps it's good idea to modify name. I think it
could be great when the way how splines are defined would be somehow unified
(for example I don't understand why I have to write number of points for
splines in objects while I haven't to in splin{} syntax - I prefer spline{}
behaviour in this case). I think also it could be great when all places where
some splines can be used would accept all builded types of splines. I'm even
so radical in this that I think it could be great if ttfs could be imported as
splines and avilable for anything and then create object as prism. But it
sounds more like modeller not raytracer :-)
If you really need to have spline and lathe/prism with the same shape then
there is no problem (as advenced user as you shouldn't have problems with
obvious creation with mesh). Anyway, I prepared some iso-conversion example
for other confused users less advanced than you.
Iso-lathe has all features of lathe{} except it can't have more than two
values for the same y (in basic form, perhaps after modifications this
limitations could be removed). Rendering of this iso-lathe alone is rather
fast.
Iso-prism (or rather parametric-prism) has no inside and is always open but
spline can be not closed. Rendering of this prism clone is rather slow.
Script available at:
http://news.povray.org/3oj17ukbdclmo92oljkd1pisr6ubsaasf2%404ax.com
Preview available at:
http://news.povray.org/0fm17ucj8h2rpb7u6ia5r5kuvd7ql58jb2%404ax.com
ABX
disc{z,-z 5#macro O()asc(substr("-+((1*(,1,/.-,*/(,&.323/'1"e,1))*.1-4#declare
e=e-1;#end#local e=26;pigment{#local g=function(_){ceil(_)-_}function#local//X
k=function{pattern{object{sphere_sweep{linear_spline 13#while(e>0)<O(),O()//AB
>.01#end}}}}{k(g(atan2(x,y)),g(ln((y+x)^2+1e-5)),0)}}finish{ambient 1}}//POV35
Date: 18 Feb 2002 06:05:58
Message: <bmn17ugj054v0el2jed8jbnfpkkvjbhjnc@4ax.com>
Interesting, in the file you posted in the list of spline types there is an
entry:
Spline10:  IType=10 : GOTO Spline  ' Bezier (quadratic)
In 3.5 we have two tokens: bezier_spline and quadratic_spline - is it
situation when the same shape is produced under different names? Or is
quadratic_spline class of splines just like cubic_spline ?
ABX
Date: 18 Feb 2002 07:40:18
Message: <Xns91B98B62B3B1Fseed7@povray.org>
in news:bmn17ugj054v0el2jed8jbnfpkkvjbhjnc@4ax.com W³odzimierz ABX
No, the bezier used in POV-Ray is cubic.
> Or is quadratic_spline class of splines just like cubic_spline ?
Yes
An interesting introduction on splines:
http://www.ddt.pwp.blueyonder.co.uk/evgeny/Intro/Intro.htm
Ingo
