POV-Ray : Newsgroups : povray.general : Bent text? Server Time
3 Nov 2026 11:36:57 EST (-0500)
  Bent text? (Message 1 to 22 of 22)
Subject: Bent text?
Date: 14 Feb 2002 08:13:50
Message: <3c6bb80e@news.povray.org>
I would like to model a column with words engraved or carved into or out of
(i.e. protruding from) the column.  I don't know how to create 3D letters
which are curved to match the column, however.
The hard way would be to use Chris Colefax's Bend include file.  Hard in
terms of render time--I have more than one column with unique text.  I would
like to ask if anyone knows of an easier way to accomplish this.
Thanks,
Hershel
Subject: Re: Bent text?
Date: 14 Feb 2002 08:23:56
Message: <3c6bba6c@news.povray.org>
"Hershel Robinson" <her### [at] yahoocom> wrote in message
news:3c6bb80e@news.povray.org...
of
would
    I don't think you can bend the individual letters in any easy way, but
there are ways to parse out the text string and rotate out each letter. Here
is the sample file I copied from somewhere...
background {
    color rgb 1
#declare Rotation = clock + 55;
#declare CText = "SOPHIE'S WORLD  SOPHIE'S WORLD  SOPHIE'S WORLD  "
 location <0, 0, -8>
 direction <0, 0, 1.5>
 look_at <0, 0, 0>
light_source {
 <-1, 1, -12>
 colour rgb <1.3, 1.3, 1.3>
#declare Letter = 1;
union {
 #while (Letter <= strlen (CText))
  text {
   ttf "c:\windows\fonts\courbd.ttf", substr (CText, Letter, 1), 0.1, 0
   translate <0, -0.5, -3>
            scale <0.55, 1.1, 1>
   rotate <0, -360 / strlen (CText) * Letter, 0>
   no_shadow
  #declare Letter = Letter + 1;
   colour rgb 0.9
  finish {
   crand 0.01
 rotate <0, Rotation, 0>
 rotate <15, 0, 20>
Date: 14 Feb 2002 08:30:55
Message: <3c6bbc0f$1@news.povray.org>
Hi Hershel,
I can propose you something that worked for one of my picture, move and
place each letter individualy. It is painfull when writing the scene, but
efficient at rendering. I used the following macro to place each letter. It
can be automated.
//Macro
#macro MDepTexte(Ax)
#declare DepTexte = transform {
        scale 1.5
        rotate 90*z
        translate <0,0,-4>
        rotate Ax * x
        translate <0,0,4>
        translate <-7,-2,-1>}
transform DepTexte
// usage: to write 3 times the word Spheres
#declare Angle = 16;
#declare AngOff = -120;
#declare i =0;
#while (i<3)
// create a TrueType text shape
text
  ttf
  "couri.ttf",
  "S",
  0.5,
  0
  MDepTexte(-3*Angle+AngOff)
  texture { T_Stone27 scale 2 }
text
  ttf
  "couri.ttf",
  "p",
  0.5,
  0
  MDepTexte(-2*Angle+AngOff)
text
  ttf
  "couri.ttf",
  "h",
  0.5,
  0
  MDepTexte(-1*Angle+AngOff)
text
  ttf
  "couri.ttf",
  "e",
  0.5,
  0
  MDepTexte(0*Angle+AngOff)
text
  ttf
  "couri.ttf",
  "r",
  0.5,
  0
  MDepTexte(1*Angle+AngOff)
text
  ttf
  "couri.ttf",
  "e",
  0.5,
  0
  MDepTexte(2*Angle+AngOff)
text
  ttf
  "couri.ttf",
  "s",
  0.5,
  0
  MDepTexte(3*Angle+AngOff)
#declare AngOff = AngOff + 120;
#declare i = i + 1;
#end // while
of
would
> Thanks,
> Hershel
Date: 14 Feb 2002 08:33:54
Message: <pren6u0olknsehje4gi23m9i8jn5bnrn65@4ax.com>
On Thu, 14 Feb 2002 15:14:43 +0200, "Hershel Robinson" <her### [at] yahoocom>
If you want bend text but each letter can stay as is then you can use this
method:
1. split text into letters
2. measure width of each letter
3. create spline along  column
4. walk along spline and measure distance to its origin
5. put every next letter when the measured distance = width of previous letter
note: remember to reorient letter according to current dirrection of spline
something similiar was done in circle_text macro in 3.5
ABX
Date: 14 Feb 2002 08:55:44
Message: <slrna6ngf2.vgm.ron.parker@fwi.com>
Somebody sit down with the object pattern and a cylinder warp and an
isosurface and whip something up for the poor chap, eh?  I would, but I
don't happen to have a running copy of POV at the moment.
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 14 Feb 2002 09:14:17
Message: <dmgn6u8f93mc51mqg6g0pbrckt9t82stq2@4ax.com>
I have tried isosurfaces bulided from object patter with megapov but it was
explained to me (iirc in p.u-p) that it is impossible to properly calculate
normal (iirc it was connected with gradient)
(my try is at http://www.abx.art.pl/pov/nonlinear/twist.jpg )
so does your reply means it is now possible in 3.5 ?
Is "yes" then great - I'll refresh my scripts probably.
ABX
Date: 14 Feb 2002 09:18:11
Message: <3C6BC723.B154333A@gmx.de>
Ron, you disappoint me.
You should really know that object pattern & isosurface are not a very
good combination.
Get back to your source files and don't try solving trivial users'
problems... ;-)
Last updated 06 Feb. 2002 _____./\/^>_*_<^\/\.______
Date: 14 Feb 2002 09:24:06
Message: <3c6bc886$1@news.povray.org>
<snip>
As Bill said, the question is, do you need to bend each individual letter? If
not, Bill's script will probably do it.
Also, you could improve the final appearence by intersecting the text with a
column slightly wider than the column that will hold the letters. This will give
the text a curved surface.
Date: 14 Feb 2002 09:33:25
Message: <3C6BCAB5.4FB2FD22@gmx.de>
There's a fairly elegant and fast method for this using the
'HF_Cylinder()' macro from Povray 3.5 and an object pattern function.
Of course this isn't perfect if you have a close view of the object, but
since it's probably faster than any text object CSG solution it's worth
trying.
Date: 14 Feb 2002 09:47:40
Message: <slrna6njge.vjg.ron.parker@fwi.com>
> good combination.
Yeah, what was I thinking, looking at Gilles' spherical text thing and
then extrapolating.
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 14 Feb 2002 11:08:47
Message: <chrishuff-31B547.11082814022002@netplex.aussie.org>
In article <3C6BC723.B154333A@gmx.de>,
> good combination.
On the other hand, the HF_Cylinder() macro doesn't have this problem...
And the blur/'proximity' thread in povray.text.scene-files has some code
that should make the object pattern more acceptable to
isosurfaces...though also very, very slow.
Date: 14 Feb 2002 13:49:15
Message: <3c6c06ab$1@news.povray.org>
Hershel Robinson <her### [at] yahoocom> wrote in message
The easiest but ugly way would be to subtract tall letters from the column
and then fill in underneath them with a cylinder of smaller diameter than
your column.
 -Shay
Date: 14 Feb 2002 15:44:23
Message: <pugn6uo5qscbokvkaua1e76o25fj0mb19u@4ax.com>
Type your text in a paint program or render it white-on-black in POV,
then use the resulting image to displace an isosurface. Some blurring
on the image would help as it would decrease the gradient of the
isosurface and will reduce render times. It will probably look better,
too.
Peter Popov ICQ : 15002700
Date: 15 Feb 2002 09:35:07
Message: <tp6q6u46ci53cskl4huds0cff0bkomtdf3@4ax.com>
On Thu, 14 Feb 2002 14:33:19 +0100, W�odzimierz ABX Skiba <abx### [at] babilonorg>
Thinking more about above two operations I found that it's not a trivial task
when kerning is considered. I have posted my solution at:
http://news.povray.org/sa6q6u8ic6tt2ntql1kt4mm2fiebtf1pih%404ax.com
ABX
Subject: Extended object pattern (was Re: Bent text?)
Date: 15 Feb 2002 12:21:53
Message: <o1fq6uk3k4bmuu1kqeqd0mmpgu976nlg45@4ax.com>
On Thu, 14 Feb 2002 15:18:11 +0100, Christoph Hormann <chr### [at] gmxde>
> good combination.
Well, I have an idea around this problem. In the truth it's even feature
request. What about changing definition of Inside method of objects ?
I mean if it could return not only yes/no to describe object but variable
float value to describe distance (not in units) to surface just like
isosurface does. So positive value means outside, zero means surface, negative
means inside.
In particular:
- for plane it returns linear distance to plane
- for sphere it returns distance to center minus radius
- for cylinders, cones, linear lathes, linear prisms, boxes, disc, separated
triangles, polygons, heighfields, torus etc. it returns obvious combination of
plane and sphere method listed above
- for csg it returns min/max of insides of components (just like method used
in isosurfaces)
- for isosurface and blob it returns value of function modified with threshold
- meshes and other patches has no inside now so no problem with them
I suppose it could be probably possible also for rest of object like: julia,
curved lathe, prism, sor, and sphere_sweep, superellipsoid, ttf, quadrics,
polys etc. They are available with formulas so probably calculation of value
could be possible.
I want to highlight that I don't mean linear distance. I mean value of math
formula used to build shape.
It should allow then recreation of object via object pattern with isosurface
and easy displace of surface of complex CSGs, bending, twisting perhaps even
beveling etc. It could be probably either blur  and proximity pattern :-)
What do you think?
ABX
Subject: Re: Extended object pattern (was Re: Bent text?)
Date: 15 Feb 2002 12:30:02
Message: <3c6d459a@news.povray.org>
W³odzimierz ABX Skiba <abx### [at] babilonorg> wrote:
: Well, I have an idea around this problem. In the truth it's even feature
: request. What about changing definition of Inside method of objects ?
: I mean if it could return not only yes/no to describe object but variable
: float value to describe distance (not in units) to surface just like
: isosurface does.
  I suggested this some time ago (a year or two perhaps). It would make
the proximity pattern much faster.
Date: 15 Feb 2002 12:30:49
Message: <b7hq6u4kcf9lrumg1v76q1apstgtprb4u1@4ax.com>
On Fri, 15 Feb 2002 18:21:17 +0100, W�odzimierz ABX Skiba <abx### [at] babilonorg>
I wonder if it could be possible even for patches but returns not negative
values (becouse of no inside). Then with small treshold it could be possible
to rebuild mesh with isosurface and displace its surface.
Also this whole solution makes my old deform patch unnecessary.
ABX
Date: 15 Feb 2002 13:00:50
Message: <3C6D4CD0.625A64E8@gmx.de>
> means inside.
This would be nice, but for shapes like text a combination of lots of
different functions would be necessary, therefore it would be quite slow,
even though having this internally instead of in user defined functions
would probably be faster.
Date: 15 Feb 2002 13:02:32
Message: <fPHg8AA4jUb8Ewzs@econym.demon.co.uk>
>method:
It's quite easy to grab a copy of circle_text and just flip the letters
the right way out. If you want the individual letters to actually have
bent surfaces, then invoke the Cylinder_Text macro with a slightly
larger Radius value, and then trim it by intersecting with a cylinder of
the required radius.
#include "shapes.inc"
/* Cylinder_Text( Font, Text, Size, Spacing, Thickness, Radius,
Inverted, Justification, Angle )
Creates a text object with the bottom (or top) of the character cells
aligned with all or part of a circle.  This macro should be used inside
an object{...} block.
      Font: The font to use (see the documentation for the text object)
      Text: The text string to be created
      Size: The height of the text string, as you would use to scale a
            standard text object
      Spacing: The amount of space to add between the letters.
      Thickness: The thickness of the letters (see the documentation for
                 the text object)
      Radius: The radius of the cylinder along which the letters are
              aligned
      Inverted: If this parameter is nonzero, the tops of the letters
                will point downwards (not really much point doing that,
                I just copied it from Circle_text)
      Justification: One of the constants Align_Left, Align_Right, or
                     Align_Center
        Angle: The point on the circle from which rendering will begin.
               The +x direction is 0 and the -z direction is 90  */
#macro Cylinder_Text(F, T, S, Sp, Th, R, I, J, A)
   #local FW = Text_Width(F, T, S, Sp);
   #local TO = text {ttf F T 1 0 scale<S, S, 1>}
   #local TH = max_extent(TO).y;
   #local C = array[strlen(T)]
   #if(FW > 2*pi*R)
      #error concat("\n\n**** Text string \"", T,
         "\" is too long for a circle of the specified radius.\n\n\n")
   #local AW = -FW*180/pi/R;
   #local SA = A;
   #local EA = A + AW;
   #if(((J = Align_Right) & !I)|((J = Align_Left) & I))
      #local SA = A - AW;
      #local EA = A;
   #else
      #if(J = Align_Center)
         #local SA = A - AW/2;
         #local EA = A + AW/2;
   #local CI = 1;
   #while(CI <= strlen(T))
      #local OE = Text_Width(F, substr(T,CI,1), S, Sp);
      #local LW = Text_Width(F, substr(T,1,CI), S, Sp) - OE;
      #local LA = SA + AW*LW/FW + OE/2/FW*AW;
      #if(I)
         #local LA = EA - (LA - SA);
      #local TO = text {ttf F substr(T, CI, 1) Th 0 scale<S,S,1>}
      #if(I)
         #local C[CI-1] =
         object {TO
            rotate 180*z
            translate <OE/2, TH, 0>
            rotate -90*y
            translate R*x
            rotate LA*y
      #else
         #local C[CI-1] =
         object {TO
            translate -OE/2*x
            rotate -90*y
            translate R*x
            rotate LA*y
      #local CI = CI + 1;
   //Create the final object, a union of individual text object letters.
   union {
      #local CI=0;
      #while(CI < strlen(T))
         object {C[CI]}
         #local CI = CI + 1;
// End of macro - start of example code
camera { location  <0, 1, -4> look_at <0, 0, 0>}
light_source {<0,200,-100> colour rgb 1}
#declare Radius = 2;
object {
  //intersection {
    Cylinder_Text("arial.ttf", "This is a test", 1, -0.1, 1, Radius, 0,
                 Align_Left, 150)
    //cylinder {-y,y,Radius}
  pigment {rgb 1}
cylinder {-y,1.5*y,Radius-0.05 pigment {rgb 1}}
Date: 15 Feb 2002 13:07:01
Message: <vejq6u0nflvvto7i54gen5t8nmpie0hv7f@4ax.com>
On Fri, 15 Feb 2002 19:00:48 +0100, Christoph Hormann <chr### [at] gmxde>
Not a problem. We are years before 4.0 so faster machines we use to test it.
ABX
Date: 15 Feb 2002 13:14:59
Message: <chrishuff-AB1A7F.13144615022002@netplex.aussie.org>
In article <o1fq6uk3k4bmuu1kqeqd0mmpgu976nlg45@4ax.com>,
> means inside.
This is what I've been doing for the updated proximity pattern/glow
patch. (which is on hold until POV 3.5 is complete)
However, it would be a very bad idea to replace the Inside() method with
this, as it would often take much longer to compute proximity than to
figure out inside/outsideness...I just added a new proximity method.
(two actually...one for proximity of a point, another for proximity of a
ray)
Date: 15 Feb 2002 13:36:49
Message: <2kkq6uoua65cd3sekqslkrbuiql7gvmile@4ax.com>
On Fri, 15 Feb 2002 13:14:46 -0500, Christopher James Huff <chr### [at] maccom>
But I imagine yes/no inside is calculated with real flot and then "booleaned"
with condition. Look at Inside_Plane, Inside_Sphere. Also Inside_Glyph look
complicated enough to think it somehow calculates distance :-)
But of course you can be right. I don't know internal behaviour of all
Inside() methods.
ABX
