POV-Ray : Newsgroups : povray.general : Spaces in command line Server Time
3 Nov 2026 11:42:35 EST (-0500)
  Spaces in command line (Message 1 to 8 of 8)
Subject: Spaces in command line
Date: 7 Feb 2002 09:41:08
Message: <3c629204@news.povray.org>
Is there any way to call Pov-ray (windows) from the command line with an
output file
name with spaces in? I'm trying to do the following
C:\Program Files\POV-Ray for Windows v3.5\bin\pvengine.exe /RENDER
"C:\Program Files\Microsoft Visual Studio\VB98\TexEdit\Example3.pov" +H200
+W200 +FN +oC:\Program Files\Microsoft Visual Studio\VB98\TexEdit /NR /EXIT
I've tried putting the path in single quotes, I've tried double quotes.
Neither works. Without quotes I get a "program.png"
in the root dir of C and I can't find anything on this in the help file.
Thanks
Gail
#macro G(H,S)disc{0z.4pigment{onion color_map{[0rgb<sin(H/pi)cos(S/pi)*(H<6)
cos(S/pi)*(H>6)>*18][.4rgb 0]}}translate<H-5S-3,9>}#end G(3,5)G(2,5.5)G(1,5)
G(.6,4)G(.5,3)G(.6,2)G(1,1)G(2,.5)G(3,.7)G(3.2,1.6)G(3.1,2.5)G(2.2,2.5)G(9,5
)G(8,5.5)G(7,5)G(7,4)G(7.7,3.3)G(8.3,2.7)G(9,2)G(9,1)G(8,.5)G(7,1)//GS
Subject: Re: Spaces in command line
Date: 7 Feb 2002 09:57:54
Message: <nc556u86ap6qk6p4tj1c84lfc4bm9df8f3@4ax.com>
On Thu, 7 Feb 2002 16:40:44 +0200, "Gail Shaw" <gsh### [at] monotixcoza> wrote:
try replace whole +o statement with
Output_File_Name="C:\Program Files\Microsoft Visual Studio\VB98\TexEdit"
ABX
Date: 7 Feb 2002 11:03:21
Message: <3c62a549@news.povray.org>
"W³odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:nc556u86ap6qk6p4tj1c84lfc4bm9df8f3@4ax.com...
Without trying that I must say that I don't believe you can use the INI
keywords on a command line prompt.  One never can tell until one tries
though  :-)
That program.png is just the failed attempt at making a c:\program (files)
render I guess.
Have you tried the shortened naming method, Gail?
+oC:\Progra~1\Micros~1\VB98\TexEdit
The first six characters then a tilde ~ and whatever number needed (Might be
several Microsoft folders).
bob h
Date: 7 Feb 2002 11:13:33
Message: <7i956ucj1mrtn4uiimvqc01iqmo7cd4355@4ax.com>
> though  :-)
I have tested this with command box, but I remember I've used it with command
line. But it looks like undocumented feature becouse documentation at the end of
5.1.1 says: "Almost all + or - switches have an equivalent option which can be
used in an INI file".
AFAIK it can fail - for example if you have Microsoft Office folder created
earlier then Microsoft Visual Studio folder.
ABX
Date: 7 Feb 2002 13:26:15
Message: <3c62c6c7@news.povray.org>
bob h wrote in message <3c62a549@news.povray.org>...
be
Can't do that as the entire command line is generated by VB code depending
on where povray is installed and where the application is question is
installed.
As far as I can tell VB can't give me the shortened path.
Gail
* gsh### [at] monotixcoza                *   Chaos, disorder and panic      *
* http://www.rucus.ru.ac.za/~gail/   *   My job here is done.           *
* Just think of me as the storm before the calm     Magic: The Gathering*
Date: 7 Feb 2002 14:58:38
Message: <3C62DC64.A6DA22F7@namtar.qub.ac.uk>
> installed.
Try parsing the string, stripping out spaces (and dots; I think short
folder names ignore dots), then
#if(strlen(Path)>8)
  #declare Path=concat(substr(Path,0,6),"~1")
Well, more or less. Needs to be done for each folder name, AND you need
to change the number depending on the creation date of the folder and
all similar folders. Heesh.
signature{
Date: 8 Feb 2002 00:50:49
Message: <3c636739@news.povray.org>
That works. Thanks very much
Gail
Date: 8 Feb 2002 05:07:32
Message: <3c63a364@news.povray.org>
"Grey Knight" <s16### [at] namtarqubacuk> wrote in message
news:3C62DC64.A6DA22F7@namtar.qub.ac.uk...
> #if(strlen(Path)>8)
> #end
A little off topic.
The short path can be discovered using windows API calls
Declare Function GetShortPathName Lib "kernel32" _
      Alias "GetShortPathNameA" (ByVal lpszLongPath As String, _
      ByVal lpszShortPath As String, ByVal cchBuffer As Long) As Long
Gail
