POV-Ray : Newsgroups : povray.general : Making Clouds Server Time
3 Nov 2026 12:46:04 EST (-0500)
  Making Clouds (Message 1 to 18 of 18)
Subject: Making Clouds
Date: 28 Jan 2002 13:01:02
Message: <3c5591de@news.povray.org>
Can anyone point me in a direction for making clouds, not the kind that are
painted on a surface with a texture map but rather a three dimensional
floating cloud that has the characteristics of a real cloud. I want to float
one over my terrain sculpture.
thanks
Mitch
Subject: Re: Making Clouds
Date: 28 Jan 2002 13:14:07
Message: <0t4b5u8qghn3m9hr2ldeuc5124lshg7m1i@4ax.com>
On Mon, 28 Jan 2002 10:03:38 -0800, "Mitchell Waite" <mit### [at] dnaicom> wrote:
http://news.povray.org/search/?s=cloud
http://www.povray.org/cgi-bin/htsearch?words=cloud
http://www.irtc.org/cgi-bin/htsearch?words=cloud
http://news.povray.org/3889782D.B530971F%40pacbell.net
ABX
Date: 28 Jan 2002 13:52:09
Message: <3c559dd9@news.povray.org>
There is a 'minipatch test.pov' file in MegaPOV demos, under 'media' folder.
This producing 3d clouds with shadows (to itself, also), and it's relative
fast.
Anto
ant### [at] matkoviccom
http://matkovic.com/anto
"Mitchell Waite" <mit### [at] dnaicom> wrote in message
news:3c5591de@news.povray.org...
are
float
> thanks
> Mitch
Date: 28 Jan 2002 14:26:49
Message: <3c55a5f9$1@news.povray.org>
On my site (Tutorials->POV-Ray->Tips and Tricks) I explain how to make not too slow
but
good looking clouds.
cu!
Date: 28 Jan 2002 16:31:12
Message: <3c55c320$1@news.povray.org>
Thanks for the references, I spent some time looking through them, but I
could not find any simple cloud pov files. Most where really really
complicated. What I would like to find is something easy to work with.
Mitch
"W³odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:0t4b5u8qghn3m9hr2ldeuc5124lshg7m1i@4ax.com...
are
float
> ABX
Date: 28 Jan 2002 16:36:37
Message: <3c55c465$1@news.povray.org>
Thanks Zeger!
That looks like it may work but when I run the Cloud POV Ray file in 3.5 I
get a black background and no cloud. Is there something I might be doing
wrong. I see a reference to something called superpatch but don't know what
that is.
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in message
news:3c55a5f9$1@news.povray.org...
too slow but
> cu!
> camera{location-z*3}#macro G(b,e)b+(e-b)*(C/50)#end#macro L(b,e,k,l)#local
C=0
> ;#while(C<50)sphere{G(b,e),.1pigment{rgb G(k,l)}finish{ambient 1}}#local
C=C+1
> ;#end#end
L(y-x,y,x,x+y)L(y,-x-y,x+y,y)L(-x-y,-y,y,y+z)L(-y,y,y+z,x+y)L(0,x+y,
> <.5,1,.5>,x)L(0,x-y,<.5,1,.5>,x)               // ZK
http://www.povplace.be.tf
Date: 28 Jan 2002 19:29:50
Message: <3c55ecfe@news.povray.org>
> that is.
The Superpatch is more or less an old version of MegaPov.
If POV-Ray didn't halt on the double_illuminate keyword, the problem is probably the
max_trace_level.
Add this at the end of your POV-file:
//start code
global_settings {
    max_trac_level 50  //should be enough
//end code
The problem is that the code uses 10 layers of clouds and the default max_trace_level
is
less than 10, so you couldn't look through the last couple of layers.
Oh, and don't forget to add a light_source outside of the clouds (inside would work
also,
but the results will be less realistic).
cu!
Date: 28 Jan 2002 19:38:49
Message: <3c55ef19@news.povray.org>
Zeger:
Ah nothing like a little light source to make things visible :)
That definitly helped. I also did need the max_trace_level.
Now my next request...can you explain a) how this works and b) can I make it
work in Moray?
Mitch
news:3c55ecfe@news.povray.org...
I
what
> > that is.
probably the
> max_trace_level.
> //start code
> global_settings {
> //end code
max_trace_level is
would work also,
> cu!
C=0
C=C+1
> ;#end#end
Date: 28 Jan 2002 20:06:30
Message: <3c55f596$1@news.povray.org>
> work in Moray?
a) I'll try to explain it, although I'm not really good at explaining things :)
Ok, let's start with 1 layer.  What you get is just a shaded, partially transparent
sphere, with a cloud-pattern on it.  Most of the light just falls through it, because
even
the least transparent parts of the layer still are transparent.  Now add a second
layer.
The light that passes through the first sphere (we see the shading of the sphere from
the
inside because of the double_illuminate modifier) now illuminates the second sphere.
But
the first layer casts a cloud-shaped shadow on the second layer (because of the used
pattern).
Now by adding more layers, we get a cloud-pattern with light edges and darker parts
where
the clouds are.  More or less.
b) I don't know, I haven't used Moray for 2 years. But it will work if you can set
double_illuminate from within Moray.  But it's not easy to switch between the number
of
layers with Moray.  I would make an inc-file with the clouds and include it in your
Moray-scene.
cu!
Date: 28 Jan 2002 21:41:52
Message: <3c560bf0$1@news.povray.org>
Zeger your explaining is fine. Only thing is what the heck is double
illuminate flag mean. There is no explaination of it in the povray 3.5 docs.
So the sphere are successively smaller and smaller and in a union. In the
code below the while statment leads to 10 spheres right? I am not really
using animation am I as I just see one frame get rendered. So the first
sphere is scale 125 + 0, the second is 125 + 1/10, the third is 124 "+ /10
and so on so they are really close together. Seems that I could put 10
spheres inside eachother in Moray but not sure how to get the double
illuminate part to work. The pigment could be a material couldn't it, since
there is nothing changing in the while loop? Excuse me if I seem slow
figuring this out.
thanks
Mitch
            #declare c=clock;
            #declare mc=1;
            #declare Min_fil=.6;
            #declare Diffuse=1.5;
            union {
                #declare Layers=10;
                #declare Count=0;
                #while (Count<Layers)
                    #declare T=Count/Layers;
                    sphere {
                        0,1
                        scale 125+T*5
                        double_illuminate
                    #declare Count=Count+1;
                hollow
                    average
                    pigment_map {
                        [mc-c
                         bozo
                         color_map {
                             [.6 rgbt 1]
                             [1 rgbt <1,1,1,Min_fil>]
                         turbulence 1  octaves 4 lambda 3
                         translate c*.1
                         scale 30
                        [c
                         bozo
                         color_map {
                             [.6 rgbt 1]
                         translate (c-mc)*.1
                         scale 30
                finish {ambient .1 diffuse Diffuse}
                translate -y*100
            background {rgb <.5,.6,.8>}
            // create a regular point light source
              light_source {
             0*x                  // light's position (translated below)
             color rgb <1,1,1>    // light's color
             translate <-20, 40, -20>
            global_settings {
            max_trace_level 50  //should be enough
news:3c55f596$1@news.povray.org...
make it
> > work in Moray?
things :)
transparent
it, because even
second layer.
sphere from the
second sphere. But
of the used
> pattern).
darker parts where
can set
the number of
it in your
> Moray-scene.
> cu!
C=0
C=C+1
> ;#end#end
Date: 28 Jan 2002 21:54:51
Message: <chrishuff-7DC556.21570028012002@netplex.aussie.org>
In article <3c560bf0$1@news.povray.org>,
6.5.9.8 Double_Illuminate
http://www.povray.org/working-docs/id000172.html#6_5_9_8
Date: 28 Jan 2002 22:24:16
Message: <3c5615e0$1@news.povray.org>
that's right.  You'll get as many spheres as you specified in the variable Layers.
> figuring this out.
As I said: you could do this in Moray (maybe except for the double_illuminate
modifier),
but it wouldn't be as flexible: you couldn't make test-renders with fewer cloud-layers
without deleting spheres from your scene.
cu!
Date: 28 Jan 2002 22:34:54
Message: <3c56185e$1@news.povray.org>
Thanks Chris that is very useful, now I finally understand. Very powerful
feature.
"Christopher James Huff" <chr### [at] maccom> wrote in message
news:chr### [at] netplexaussieorg...
docs.
Date: 29 Jan 2002 01:33:54
Message: <3c564252@news.povray.org>
news:3c55c320$1@news.povray.org...
> Mitch
Write one? :)
Seriously, it's just not a simple task.  Most of the time, I layer several
planes (or stretched discs) at different heights, and the results come out
ok (though not photorealistic).
...Chambers
Date: 29 Jan 2002 03:50:29
Message: <3c566255$1@news.povray.org>
"Mitchell Waite" <mit### [at] dnaicom> a écrit dans le message de news:
are
float
Try Jaime's clouds here (under "stacked sky"), probably the best cloud macro
available.
http://www.ignorancia.org/galleries.shtml
However, note that while there have been good Povray clouds, there is no
perfect way yet(realistic AND fast AND simple to set up) to create 3d clouds
in Povray.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 29 Jan 2002 07:55:01
Message: <3c569ba4@news.povray.org>
> macro available.
  Hmmmm.... thanks! But if I remember well Mitchel scene, I think the
stacked technique is not really appropiated for it, mainly due to the point
of view (not from bellow). Perhaps media is the only solution for this
case, IMHO.
> clouds in Povray.
 Amen.
Jaime Vives Piqueres
Date: 29 Jan 2002 09:52:31
Message: <3c56b72f@news.povray.org>
Hey thanks Jamie, at least that scene is one I can follow (nice and short).
Do I understand from your comments that the stacked plane approach to clouds
will not let me see a single fluffy cloud if I am looking down from above a
small mountain, e.g. I won't see a cloud floating above the terrain?
So far the only method that I have found that comes close to that is the
technique of using concentric spheres and the special double illumination
flag. Any comments on that technique?
Mitch
PS I like the way your site shows the thumbnails.
"Jaime Vives Piqueres" <jai### [at] ignoranciaorg> wrote in message
news:3c569ba4@news.povray.org...
> > macro available.
point
> case, IMHO.
> > clouds in Povray.
>  Amen.
> La Persistencia de la Ignorancia
Date: 29 Jan 2002 11:06:11
Message: <3c56c872@news.povray.org>
> to clouds will not let me see a single fluffy cloud if I am looking down
> from above a small mountain, e.g. I won't see a cloud floating above the
> terrain?
  Well, being based on planes, it works better for viewing directions not
much paralel to the planes.
  Not tried it, but sounds like a fine solution from Zeger description, and
seing the clouds on his images, I think it can be appropiated for your
scene. Being spheres instead of planes, the point of view seems not a big
problem. Definitely, I must try it someday...
  Thanks, I tried to make the design simple but also not too boring.
