When I use a stone texture and change the diffuse value, only one
element of the texture is changed:
#include "stones.inc"
camera{location z*-2}
light_source{z*-2 rgb 1}
plane
z, 0
texture
T_Stone25
finish
diffuse 2
Why isn't the whole texture changed? What can I do to change the
diffuse value of the whole texture?
I use POV-Ray 3.5.
Felix Wiemann
>I use POV-Ray 3.5.
plane {
z, 0
T_Stone25
diffuse 2
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
Huh? That's not logic!
Hugo
> plane {
> z, 0
> texture {
> T_Stone25
> diffuse 2
Felix Wiemann <Fel### [at] gmx net> wrote:
: texture
: T_Stone25
: finish
: diffuse 2
AFAIK this is actually a layered texture. You are not modifying the first
texture, but you are creating another texture on top of it.
The effect you describe is strange, though.
N(11117333955)N(4254934330)N(3900569407)N(7382340)N(3358)N(970)}// - Warp -
In article <3c55354b$1@news.povray.org>,
> I use POV-Ray 3.5.
What you are doing is creating another texture layer with the default
texture used for everything but the diffuse. You want:
plane {z, 0
T_Stone25
finish {
diffuse 2
BTW, it also greatly helps readability if you neatly indent the code,
indenting inner blocks more than their containing blocks, and it helps
avoid this sort of problem later on. You don't necessarily have to do it
the way I did it, just be consistent and use *some* indentation.
Christopher James Huff <chr### [at] mac com>
> plane {z, 0
> texture {
> T_Stone25
> finish {
> diffuse 2
That doesn't work. It's still only one element with higher diffuse. I
wonder about that, too.
helps
it
I've tried so. Let me explain my indent "system":
1 (object or object modifier like union, pigment, plane, ...)
2 {
3 (some code)
4 }
(some code) can contain an object or object modifier.
It's better visible in an editor. I think it's a quite logical system.
But what do you suggest should I change?
Felix Wiemann
> > plane {z, 0
> > texture {
> > T_Stone25
> > finish {
> > diffuse 2
That's totally normal.
Check T_Stone25 definition....
It is a layered textured. so applying modifiers only works for one, not all of
them.
Solution for your problem : inline T_Stone25 and put the relevant finish
modifiers!
Non Sine Numine
http://grimbert.cjb.net/
On Mon, 28 Jan 2002 17:17:08 +0100, J�r�me Grimbert
> modifiers!
There can be also some persons which don't want open, search, copy, close long
way (also becouse of respect to authors of code). For such persons there is
still workaround.
// START
#default{finish{diffuse 2}}
plane{
z, 0
texture{T_Stone25}
#default{finish{diffuse .6}} // default according to documentation
/* rest of scene */
// END
ABX
> still workaround.
Unless one also want an Unmodified T_Stone_27
Or already add loaded "stones.inc", may be due to another include...
So beware of that solution.
Non Sine Numine
On Mon, 28 Jan 2002 18:05:44 +0100, J�r�me Grimbert
> > still workaround.
Have you checked my solution ? It leaves T_Stone_27 unmodified
But of course there are some danger situations. Mainly when other default are
changed somewhere.
ABX
> close long way (also becouse of respect to authors of code). For such
> persons there is still workaround.
Thank you!
But why isn't it possible to change the diffuse value but the reflection of
a layered texture?
background{1} //NEW
plane{z, 0
texture{T_Stone25}
finish{reflection 2} //INSTEAD OF DIFFUSE
The whole texture reflects the background light! POV-Ray's SDL is normally a
very modularized and logical language, so I expect that a layered texture
identifier is handled by the same way as the inline code and as a non
layered texture identifier. I find it also confusing that there's a
difference between "reflection" and "diffuse". Can anyone explain this
behavior to me?
Felix Wiemann
On Mon, 28 Jan 2002 14:51:41 +0100, "Hugo" <hua### [at] post3 tele dk> wrote:
Of course it's not, sorry for the hurried answer. See below.
plane {
z, 0
T_Stone25
finish { diffuse 2 }
Now, this better make some sense or else I am quitting POV.
Humbug!
Ken Tyler
