POV-Ray : Newsgroups : povray.general : Spline problem Server Time
3 Nov 2026 12:49:51 EST (-0500)
  Spline problem (Message 1 to 16 of 16)
Subject: Spline problem
Date: 19 Jan 2002 10:28:57
Message: <3c4990b9$1@news.povray.org>
OK, can someone tell me why this generates a parse error:
#declare Spline = spline {cubic_spline
                           -2/13, <-1,0,0>
                          -1/13, <0,0,0>
                          0,     <1,0,0>
                          1/13,  <5,0,0>
                          2/13, <8,0,0>
While this doesn't:
                          -2/13, <-1,0,0>
                          (-1/13), <0,0,0>
                          0,     <1,0,0>
                          1/13,  <5,0,0>
                          2/13, <8,0,0>
The only difference between these two bits of code is the brackets
around -1/13.
I'm hopelessly confused as to why the brackets are necessary on that one
line, and that one line alone.
Subject: Re: Spline problem
Date: 19 Jan 2002 11:12:36
Message: <chrishuff-9C93D9.11132819012002@netplex.aussie.org>
In article <3c4990b9$1@news.povray.org>,
>                            -2/13, <-1,0,0>
>                           -1/13, <0,0,0>
>                           0,     <1,0,0>
>                           1/13,  <5,0,0>
>                           2/13, <8,0,0>
You don't have commas separating the items. POV-Ray doesn't care about
spaces or separate lines, it sees:
                            -2/13, <-1,0,0>
                           -1/13, <0,0,0>
as:
-2/13, <-1,0,0> - 1/13, <0,0,0>
When you add in the parentheses, it sees:
-2/13, <-1,0,0> (-1/13), <0,0,0>
and can figure out that the "-1/13" is a separate value.
Date: 19 Jan 2002 11:15:06
Message: <3c499b8a@news.povray.org>
Aha!  Thank you.  I thought it would be something really obvious, and I
had wondered why commas weren't necessary.  I guess I shall simply use
commas at all times now.
>                             -2/13, <-1,0,0>
>                            -1/13, <0,0,0>
> as:
Date: 19 Jan 2002 15:42:56
Message: <3c49da50$1@news.povray.org>
Why are those commas optional anyway?
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
Date: 19 Jan 2002 16:00:14
Message: <chrishuff-54F4FD.16010819012002@netplex.aussie.org>
In article <3c49da50$1@news.povray.org>, "Slime" <noo### [at] hotmailcom>
Backwards compatibility. The same code is used to parse all commas, and
that code was written to support the old <xVal yVal zVal> vector syntax,
so it tries to accept blank spaces. Sometimes it accepts them when it
shouldn't, but it has no way to tell...
Date: 19 Jan 2002 16:03:10
Message: <3c49df0d@news.povray.org>
Andrew <ast### [at] hotmailcom> wrote:
: had wondered why commas weren't necessary.
  The main reason is backwards compatibility, but there are other really good
reasons as well.
  For example, suppose that you wanted to make the spline points inside a
loop. You could do something like this:
spline
{ cubic_spline
  #declare Ind = 0;
  #while(Ind < 10)
    Ind, <Ind, Ind*Ind, 0>
    #declare Ind = Ind+1;
  Now suppose that the commas were mandatory. That wouldn't work anymore.
It won't work either if you add a comma after the vector.
  I'll let it as an exercise how complicated that would need to be done if
Date: 19 Jan 2002 16:29:31
Message: <chrishuff-1EEB89.16302619012002@netplex.aussie.org>
In article <3c49df0d@news.povray.org>, Warp <war### [at] tagpovrayorg>
Not very. I always do it anyway, for possible forwards compatability in
case a future version makes them required.
    #declare Ind = 0;
    #while(Ind < 9)
        #declare Ind = Ind + 1;
Date: 19 Jan 2002 16:29:55
Message: <3c49e553$1@news.povray.org>
Only one line more, if the following parses ...
spline
{ cubic_spline
  0, 0
  #declare Ind = 1;
  #while(Ind < 10)
    ,Ind, <Ind, Ind*Ind, 0>
OK .. I(We all) know, what you mean, but probably this example was too simple
Question: How far back do we need Backward-compatibility ?
Commas are standard at least since 3.0, so I think somewhere should be a
hard-cut ...
_IF_ all the suggestions for the (somewhere in the far future) POV4 will
come true, we
will have a complete(?) different SDL, with hardly any way for
backward-compatibility ...
[Talking about cardriving]
"People are opstacles?
Oh...I always treat them as bonus points..." [Ian Burgmyer in p.o-t]
// Jan Walzer <jan### [at] lzernet>
Date: 19 Jan 2002 16:59:53
Message: <3c49ec58@news.povray.org>
Christopher James Huff <chr### [at] maccom> wrote:
: Not very. I always do it anyway, for possible forwards compatability in
: case a future version makes them required.
  If a future version makes commas mandatory, that would be a huge step
*backwards* in versatility.
  (Unless a #-command can replace a comma.)
Date: 19 Jan 2002 17:44:12
Message: <chrishuff-4B8A52.17450919012002@netplex.aussie.org>
In article <3c49ec58@news.povray.org>, Warp <war### [at] tagpovrayorg>
How?
Date: 19 Jan 2002 18:49:12
Message: <3c4a05f7@news.povray.org>
:>   If a future version makes commas mandatory, that would be a huge step
:> *backwards* in versatility.
: How?
  Because it would disallow making automatic generation of long lists of
items (number, vectors...) in such a simple and versatile way as currently.
  Currently it's just enough to create the list of items in a loop, without
having to take into account that there should be one comma less than the
number of items.
  (Note that the problem with the solution you suggested is that there might
be cases where the loop is not executed even once, that is, no items are
created at all.)
Date: 19 Jan 2002 19:19:30
Message: <chrishuff-240E57.19202719012002@netplex.aussie.org>
In article <3c4a05f7@news.povray.org>, Warp <war### [at] tagpovrayorg>
> number of items.
> created at all.)
In this case it's an extra line and some math in the loop. The cases you
mention aren't that common, and you can still put a comma on every line
but the last, it's just a little more complex. Not by very much,
either...just by one #if() statement in the mix.
Date: 20 Jan 2002 14:01:18
Message: <slrna4m15e.694.hjp-usenet@teal.h.hjp.at>
>> number of items.
>> created at all.)
You could also allow a superfluous comma after the last item, like many
other programming languages (e.g., C and perl) do.
	hp
   _  | Peter J. Holzer    | Hört doch dieses törichtes Volk ohne
|_|_) | Sysadmin WSR       | Verstand, die Augen haben und nicht sehen,
| |   | hjp### [at] hjpat         | die Ohren haben und nicht hören!
__/   | http://www.hjp.at/ |    -- Jeremia 5:21
Date: 21 Jan 2002 03:07:14
Message: <0tin4usrh1hbhf2td9the8l6l19rctr2e0@4ax.com>
On Sat, 19 Jan 2002 19:20:27 -0500, Christopher James Huff <chr### [at] maccom>
parsing is slowest part of  POV, such additional #if() could slow down simple
loops  more then twice sometimes imo
ABX
Date: 21 Jan 2002 07:42:44
Message: <slrna4o366.f44.ron.parker@fwi.com>
> hard-cut ...
But why?  The cases where it's still possible to leave them out are perfectly
unambiguous anyway, so why require them?
#macro R(P)z+_(P)_(P)_(P+1)_(P+1)+z#end#macro Q(C,T)bicubic_patch{type 1u_steps
6v_steps 6R(1)R(3)R(5)R(7)pigment{rgb z}}#end#macro _(Y)#local X=asc(substr(C,Y
,1))-65;<T+mod(X,4)div(X,4)9>-2#end#macro O(T)Q("ABEFUQWS",T)Q("WSXTLOJN",T)#
end O(0)O(3)Q("JNKLCGCD",0)light_source{x 1}// ron### [at] povrayorg
Date: 21 Jan 2002 09:08:03
Message: <chrishuff-66B74C.09085821012002@netplex.aussie.org>
In article <0tin4usrh1hbhf2td9the8l6l19rctr2e0@4ax.com>,
Only if you only loop once, for example when you have two items, you
might have an extra millisecond or so.
