Hi, I want to get the directions of the normals of a surface to use them in
a pigment. I thought that I could use a combination of 3 slope patterns to
do that
but I don't know how to get the direction when I have 3 vectors and the
degrees in that it stands to them.
On Wed, 19 Dec 2001 13:46:11 +0100, "Simon Adameit" <gom### [at] gmx de> wrote:
>do that
I'm not sure I understand slope pattern well but perhaps you expect something
like this ?
#version 3.5;
global_settings{
assumed_gamma 1.0
noise_generator 2
background{color rgb 1}
camera{
orthographic
location -2*z
direction z
up y
sky y
look_at z
light_source{
<-30,30,-30>
color rgb 1
sphere{
0 .5
normal{granite}
pigment{
average
pigment_map{
[3 slope x color_map{[0 rgb 0][1 red 3]}]
[3 slope y color_map{[0 rgb 0][1 green 3]}]
[3 slope z color_map{[0 rgb 0][1 blue 3]}]
// ABX
something
> like this ?
> pigment{
> average
> pigment_map{
> [3 slope x color_map{[0 rgb 0][1 red 1]}]
> [3 slope y color_map{[0 rgb 0][1 green 1]}]
> [3 slope z color_map{[0 rgb 0][1 blue 1]}]
> ABX
I have something like this but my question is how I can get the direction of
the normal from the colors I get from this pigment.
"Simon Adameit" <gom### [at] gmx de> wrote in message
news:3c20a1a3@news.povray.org...
of
Ah, well then you want to use trace(). It can get you the normal vector
which could then be used as color vector. The example in the documentation
should be enough to go by.
text{ttf"timrom""bob h"0,0pigment{rgb 7}translate 7*z}
documentation
I want to make a pigment that uses the direction of the normal at each point
of the surface, this is not possible with trace.
On Wed, 19 Dec 2001 16:00:12 +0100, "Simon Adameit" <gom### [at] gmx de> wrote:
If slope pattern is proportional to normal vie on Direction parameter then I
think
pigment{
average
pigment_map{
[3 slope x color_map{[0 red -3][1 red 3]}]
[3 slope y color_map{[0 green -3][1 green 3]}]
[3 slope z color_map{[0 blue -3][1 blue 3]}]
returns direction of the normal. But if slope pattern is proportional to the
angle then I'm wrong.
ABX
"Simon Adameit" <gom### [at] gmx de> a écrit dans le message news:
point
Using your 3-slopes trick, you should be able to define a function,
and then use it as a pattern. A pattern of a function of three patterns.
Fabien.
That's what I wanted to do :-)
the
From reading the Docs I thought it is but I'm not sure.
