I've been working on a computer game called MazeQuest.
The game is for a project in multimedia class. We've had a few months to
make a multimedia application of our own choice and to document all choices
and considerations we've made in the design.
I chose to make a small computer game with lots of POV-Ray graphics and
animations in it. :) A few images from the game can be seen in
povray.binaries.images.
The concept is extremely simple and the gameplay is not very good, but you
can always just look at it as an extended graphics gallery. ;)
The game is about 2.7 MB. The first beta is up now for anyone interested.
It's just a zip file that you have to download and unzip.
The game runs on Windows and requires ActiveX if I'm not mistaken.
Furthermore it apparently requires a not-too-slow computer - I've been
developing the game at school where it runs fine and it also runs fine on
our 1 GHz computer at home, but on my Pentium 150 it messes completely up
and then crashes... :(
There are also some problems with the animations getting a red tint for some
reason. Restarting the game sometimes help for that.
I have made the game with an authoring tool that keeps me far away from any
actual program code, so all such problems are not my fault!
One more thing to keep in mind is that the game is foremost made as a school
project - and while it probably impresses my teacher, it probably looks
rather dump if you interpret it as a serious attempt at making an actual
game...
Ok, I think I've warned you enough by now.
I haven't had time to set up a webpage for the game, but it can be
downloaded from here:
http://students.aabc.dk/rjohan7/mazequest.zip
Feedback is much appreciated as always!
Rune
PS, Sam Benge (SamuelT) just mailed me. He's lurking on these newsgroups but
are unfortunately not able to post at the moment. I should tell you all
"Howdy!" from him. :)
Rune's World: http://rsj.mobilixnet.dk (updated Nov 5)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
That was amazing. I got to level four. It was a bit difficult, though... fun
though, I liked it. Good animations and all.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
High score: 2500
- Slime
"Rune" <run### [at] mobilixnet dk> wrote in message
news:3c1fdcf3@news.povray.org...
On my win2000 machine at work, it runs fine for a couple of minutes, then causes
a sudden reboot (which requires a second, controlled, reboot to get network
connections up and running again).
What I saw looked nice though....
On Wed, 19 Dec 2001 01:17:44 +0100, "Rune"
I got thru the first level ok (with 250 points), as soon as I began
second level it hung after showing me the map.
/Erkki
> not mistaken.
Did I say ActiveX? I meant DirectX. I guess I was mistaken then...
Rune
> as I began second level it hung after showing me the map.
Thanks for trying it out!
Did the computer hang or just the game?
Did you attempt playing it more than once (and if yes, did it hang all the
times)?
What computer do you have and which windows version?
Rune
> couple of minutes, then causes a sudden reboot
> network connections up and running again).
Aww, too bad. :(
Seems like the authoring tool we use has a lot of bugs. :(
What computer did you use?
Rune
> bit difficult, though... fun though, I liked it.
I'm glad you liked it and that it worked for you without problems. :)
You can easily edit the levels and make your own. Just look in the data
folder for the text files called level1.txt, level2.txt etc.
If you make any custom levels I'd be interested in seeing them, and maybe
implement
them in the game!
Rune
news:3c211553@news.povray.org...
Viglen genie p3 733
hi rune!
if it is permitted to tell, what authoring tool did you use?
thanks, miker
choices
some
any
school
> game...
> Rune
but
> 3D images and anims, include files, tutorials and more:
I used Mediator by Matchware ( http://www.matchware.net/default.htm ), but
that's just because that's what my school has got.
It's very easy to use as everything is done through a graphical
user-interface, and all triggers and actions are controlled with small
icons. But the software is rather *limited* and certainly not intended to
make the kind of game that I've made with it. As a result, the animation
sequences are jaggy because the timing in the program is not perfect.
Furthermore the program seems to be quite *buggy*, as can be seen in this
thread.
The new version of Mediator may be better on both regards according to their
website (more flexible and many bugs fixed), but I have no experience with
it myself.
As a whole I can't recommend it as serious users will get too advanced for
it too quickly. Also, programs made using Mediator can always be opened and
modified by other people who also have Mediator, so copyright-wise you're
not very well protected.
Rune
Please do not quote the whole message when replying.
Most if not all of us use threading nwsreaders and so we already have the
original message.
We do not need it posted again and again.
On Wed, 19 Dec 2001 23:07:48 +0100, "Rune"
>times)?
Compaq PIII 1 GHz, 128 MB RAM, Win/ME, it was only the game that hung
and I didn't try it again.
/Erkki
