POV-Ray : Newsgroups : povray.general : PC Configuration Server Time
3 Nov 2026 14:32:56 EST (-0500)
  PC Configuration (Message 1 to 16 of 16)
Subject: PC Configuration
Date: 17 Dec 2001 21:08:14
Message: <3c1ea50e@news.povray.org>
I am building a new PC for rendering images with POVRay. I am working on a
project that will require a lot of images. I have already done the work but
I still need to render. Due to the complexity of the images each image takes
over a day to render, so  speed is important.
The problem is my budget.
Question, for the Windows version of POVRay has anybody done a benchmark
comparison of how fast images render with the Althon XP processor with 133
sdram versus DRR 2100?
I know the DDR is faster but I have heard that streaming applications (not
computative intensive ones) are the big winners.
I guess that I really want to know if it would be worth the money to upgrade
to the DDR memory if my other choice were to upgrade to a 1800 or 1900
Althon (assuming that I could not afford to do both).
I have looked at some POVRay bench mark sites but they do not distinguish
sdram/DDR in an apples to apples comparison.
Thanks for any help.
Kirk
Subject: Re: PC Configuration
Date: 17 Dec 2001 21:18:36
Message: <3c1ea77c@news.povray.org>
In article <3c1ea50e@news.povray.org> , "Kirk Hubbell" <kir### [at] yahoocom>
What is a "streaming application"?
    Thorsten
Date: 17 Dec 2001 21:44:43
Message: <3C1EABF6.2060909@videotron.ca>
An application that handles huge chunks of data such as mpeg
encoding/decoding, etc...
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 18 Dec 2001 00:43:21
Message: <3C1ED7EA.9050601@skynet.be>
Did you see this ?
http://www4.tomshardware.com/column/01q4/011124/index.html
Fabien.
Date: 18 Dec 2001 02:44:16
Message: <3c1ef3d0$1@news.povray.org>
"Kirk Hubbell" <kir### [at] yahoocom> schrieb im Newsbeitrag
news:3c1ea50e@news.povray.org...
but
takes
If you want to save money and time, give Linux a try. I compiled the sources
of POV-Ray with the Athlon optimisations of the gcc compiler and got shorter
render times than with my Windows version of POV-Ray.
So long,
Bonsai
        ________________
---===|  www.b0n541.net  |===---
       \________________/
Date: 18 Dec 2001 05:51:44
Message: <3C1F2005.5687CA96@free.fr>
I don't know what this means, but I do know that DDR is better
at working on huge amounts of contiguous data, such as gigantic
meshes, enormous image maps, etc. SDRAM is said to be better
for lots of small, independant memory transfers. Hardware sites
such as the one Fabien mentionned are much better at explaining
this than me.
Adrien Beau   adr### [at] freefr   http://adrien.beau.free.fr/
Date: 18 Dec 2001 05:55:32
Message: <3c1f20a4@news.povray.org>
In article <3C1### [at] videotronca> , Francois Labreque
Interesting name, I have never seen it before...
In response to the problem my answer then is:
Compression and decompression of data are usually very local (in memory)
operations and thus the processor speed gains you more than memory speed
given the large caches of processors.  Sure, computer companies want you to
believe you need a 10 GHz system to watch DVD movies, but that isn't true...
POV-Ray on the other hand will benefit from more and fast memory as it needs
real random access in memory over the whole memory range if a scene is large
enough.  However, it should be noted that even DDR-SDRAM still has a
specific access time for the first access which isn't much better than the
first access time of SDR-SDRAM (because decoding an address takes about the
same in either type of RAM).  So again you gain quite a bit from large
caches...
    Thorsten
e-mail: tho### [at] trfde
Date: 18 Dec 2001 09:39:59
Message: <3c1f553f$1@news.povray.org>
sources
shorter
yeah - the biggest boost in performance (bang for buck) will come from code,
not extra hardware
however, as with everything Linux, your mileage may vary - my pc idles with
20%+ cpu usage with Linux (any flavour)
PGP Public Key
Date: 18 Dec 2001 09:42:52
Message: <3c1f55ec@news.povray.org>
Thorsten Froehlich <tho### [at] trfde> wrote:
: However, it should be noted that even DDR-SDRAM still has a
: specific access time for the first access which isn't much better than the
: first access time of SDR-SDRAM (because decoding an address takes about the
: same in either type of RAM).  So again you gain quite a bit from large
: caches...
  On the other hand, when there's a cache miss, significant amount of time is
spent copying a portion of the RAM to the cache. If the RAM is faster, wouldn't
this copying be faster as well?
Date: 18 Dec 2001 09:45:02
Message: <3c1f566d@news.povray.org>
Rick [Kitty5] <ric### [at] kitty5com> wrote:
: however, as with everything Linux, your mileage may vary - my pc idles with
: 20%+ cpu usage with Linux (any flavour)
  Have you tried running at nice -20? (You need to be root for that, though.)
Date: 18 Dec 2001 11:27:50
Message: <3c1f6e86@news.povray.org>
In article <3C1F2005.5687CA96@free.fr> , Adrien Beau <adr### [at] freefr>
Well, POV-Ray will never access them in a continuous fashion but randomly so
you gain little with DDR-DRAM in this case :-(
    Thorsten
Date: 18 Dec 2001 13:15:20
Message: <3c1f87b8@news.povray.org>
In article <3c1f55ec@news.povray.org> , Warp <war### [at] tagpovrayorg>  wrote:
> wouldn't this copying be faster as well?
Yes and no.  It all depends very much on the cache and processor design.
Usually cache misses will be hidden due to pre-fetching.  In particular x86
processors have extraordinarily long pipelines with ten or more stages even
for simple instructions.  So those can hide a lot of latency in memory if
the processor reads early and there are numerous other methods to cover for
slow memory.
In addition statistics show that most thinks at a particular time are done
locally on a small scale.  I.e. a MPEG/JPEG discrete cosine transform will
take blocks of 8*8, so you have 64 fairly local accesses again.  So even in
extreme data processing applications like these there is some locality  The
same is true for POV-Ray on the small scale, i.e. when walking a linked
structure.
While this may seem like a contradiction, a good cache architecture like the
ones used in processors today will hide almost all of these different yet
similar access types and main memory access plays only a very minor role as
long as the time it takes to process one piece of information from memory
still takes longer than it takes to get it from memory.
Well, the whole situation is very complex with the cache and processor
designs today because of out-of-order and delayed bus transfers or even
packet based bus systems and hard to explain without writing a book about
it, so I will stop here...
    Thorsten
Date: 18 Dec 2001 20:48:23
Message: <3c1ff1e7@news.povray.org>
Thanks for all of the dialogue. I have also been asking others and the
consensus seems to be that more processing power will  bring the biggest
bang for the buck although there could be some improvement with faster
memory. I'll probably go with an 1800+ and overclock it a bit and save the
money for DDR and go with sdram 133.
Now my most exciting discovery ... in the midst of this discussion (and
others that I have been having) I stumbled on a web page that hosts a
benchmark and a recompiled version of POVRay 3.1g that is optimized for the
PIII and Athlon, it was done as an experiment. I took a low resolution
render of one of my images (160X120 no AA) and rendered it. Standard POVRay
3.1g took 15 min and 47 sec. With the code optimized it took 4 min and 0
sec. I was astounded. Combining this with a faster processor, I think there
will be a great improvement.
Now, because of the complexity of the image, most of the time saved with the
optimized POV engine was in the parsing. I'll let you know an approximated
time savings after I render a few of the pictures at full resolution where
most of the time saved will be in actual rendering.
For those interested in the site, it is located at:
http://students.washington.edu/sschmitt/pov/
Kirk
"Kirk Hubbell" <kir### [at] yahoocom> wrote in message
but
takes
upgrade
> Kirk
Date: 19 Dec 2001 22:35:16
Message: <3c215c74@news.povray.org>
One last note:
After doing several test renders with the optimized POVRay3.1g from the
website below it looks like parsing improves by about 400% and rendering
improves by 20% to 25%, I didn't do a detailed measurement.
Kirk
news:3c1ff1e7@news.povray.org...
the
POVRay
there
the
> Kirk
a
> but
> takes
133
(not
> upgrade
distinguish
> > Kirk
Date: 20 Dec 2001 03:47:54
Message: <3c21a5ba@news.povray.org>
Please do not quote the whole of a message when replying.
Most if not all of us have the previous message.
Date: 20 Dec 2001 05:41:11
Message: <3c21c047@news.povray.org>
In article <3c215c74@news.povray.org> , "Kirk Hubbell" <kir### [at] yahoocom>
But this is nothing new.  Of course the latest Intel compiler code is better
than the (three year old) Visual C++ or Watcom compiler code.  Just take a
look at the POV-Ray 3.5 beta, which uses the Intel compiler.
    Thorsten
