POV-Ray : Newsgroups : povray.general : Bug in concentric spheres Server Time
23 Oct 2026 15:04:50 EDT (-0400)
  Bug in concentric spheres (Message 1 to 4 of 4)
Subject: Bug in concentric spheres
Date: 15 Dec 2001 10:31:17
Message: <3c1b6cc5@news.povray.org>
Hi.
I think I have found a bug in POVRay. I'm trying to make several
concentric spheres which are all completely transparent, but which have a
reflection. If I make three or more transparent objects inside one
another, the inmost ones will be rendered totally black.
For example the following code:
---snip---
camera { location <0, 0, -2>  look_at 0 }
light_source { <1,1,-2> White*8 }
plane { -z, -2   pigment { Green } }
#declare COUNT=0.1;
#while (COUNT<0.31)
sphere {
        <0,0,0>,COUNT
        pigment { transmit 1.0 }
#declare COUNT=COUNT+0.1;
---snip---
If the number 0.31 is changed to 0.21 (so there are only two concentric
spheres), the image renders, as expected, to a totally green image. But
with 0.31 or larger, there is a black sphere in the middle of the image.
(It gets bigger with larger values, so that the third outmost object is
always black.)
I originally noticed it in the Debian version "3.02.Linux.cc", but trying
the official Linux version "3.1g.Linux.gcc" didn't help. I've also tried
changing want of the options (eg. bounding box on/off), but nothing has
helped.
I'm sorry if this is a known bug/feature, but I couldn't find any info
about it. If there's a way around this, I'd be grateful if you could tell
me how to do it. (It's for a project of mine which is in a bit of a
hurry.)
(I sent this originally to tea### [at] povrayorg, they suggested I post it
here.)
  __________________________________________________
 /____\   Sampo Niskanen <=> sam### [at] ikifi  \
       \       http://www.iki.fi/sampo.niskanen/     \
        \     ________________________________________\___
         \___/___________________________________________/
Subject: Re: Bug in concentric spheres
Date: 15 Dec 2001 10:34:24
Message: <3C1B6E2E.A89A7CED@pacbell.net>
Sampo Niskanen wrote:
> Hi.
> hurry.)
See the following for an explaination and an easy fix -
http://www.students.tut.fi/~warp/povVFAQ/languageVFAQ.html#maxtracelevel
Ken Tyler
Date: 16 Dec 2001 06:40:55
Message: <3c1c8847@news.povray.org>
Increase max_trace_level in your global_settings block to about 5 or so.
"Sampo Niskanen" <sam### [at] ikifi> wrote in message
news:3c1b6cc5@news.povray.org...
> Hi.
> ---snip---
> #declare COUNT=0.1;
> #while (COUNT<0.31)
> sphere {
>         <0,0,0>,COUNT
> #end
> ---snip---
> always black.)
> helped.
> hurry.)
> here.)
Date: 16 Dec 2001 06:47:26
Message: <3c1c89ce$1@news.povray.org>
"Mahalis" <don### [at] fakeycom> wrote in message
news:3c1c8847@news.povray.org...
Sorry but I have to correct you on that, 5 is the default.  Three
semitransparent spheres have 6 surfaces for the ray to pass through and so
max_trace_level must be more than the number of instances of surfaces.
I knew what you meant though  :-)
