POV-Ray : Newsgroups : povray.general : filename.rca Server Time
18 Aug 2025 06:08:54 EDT (-0400)
  filename.rca (Message 1 to 4 of 4)
Subject: filename.rca
Date: 11 Dec 2001 06:56:40
Message: <3c15f478@news.povray.org>
i hang around in my catalog tree and found a file named <filename.rca>. i
opened it and found many many funny float numbers in it. every line starts
with <C1>. it has nearby 994 lines and every line has ten columns (without
<C1>). also, i found the same filename as .pov and .tga (which i expected
to be there).
in the same catalog a found a second file with .rca. my third though was,
if it has to do with radiosity. but i rendered more scenes with radiosity
then .rca-files exist.
question: why did POVRay (i think he was it) write such a file and what
does it say to me?
help welcome
Subject: Re: filename.rca
Date: 11 Dec 2001 07:03:23
Message: <4btb1u89rit3qhmthtb8h9cubv71stouu9@4ax.com>
On Tue, 11 Dec 2001 12:58:19 +0100, marabou <not### [at] availableyet> wrote:
> does it say to me?
I think it is tomporary radiosity file. It is possible to control this file
within 3.5 ( http://www.povray.org/working-docs/id000224.html#6_11_11_2_15 )
Under 3.1 iirc it was created during trace and deleted after succesfull finish.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 11 Dec 2001 07:10:20
Message: <3c15f7ac@news.povray.org>
>> does it say to me?
> file within 3.5 (
> http://www.povray.org/working-docs/id000224.html#6_11_11_2_15 ) Under 3.1
seems that the documentation of v3.5 has better explanations than the v3.1
ones.
thank you.
Date: 11 Dec 2001 08:36:16
Message: <3c160bd0@news.povray.org>
:> question: why did POVRay (i think he was it) write such a file and what
:> does it say to me?
: I think it is tomporary radiosity file.
  The idea is that you can stop a radiosity render and continue it later
without the radiosity data screwing up.
