POV-Ray : Newsgroups : povray.general : Undefine macro? Server Time
3 Nov 2026 15:43:08 EST (-0500)
  Undefine macro? (Message 1 to 21 of 21)
Subject: Undefine macro?
Date: 6 Dec 2001 09:26:06
Message: <3c0f7ffe@news.povray.org>
I really need to be able to undefine macros, but it doesn't seem to be
possible...?
I find it strange, as it's possible to overwrite a macro, just like
variables, and to check if a macro is defined using #ifdef, just like
variables, but to undefine it isn't possible for some reason (or is it?).
Rune
Rune's World:    http://rsj.mobilixnet.dk (updated Nov 5)
Subject: Re: Undefine macro?
Date: 6 Dec 2001 09:44:18
Message: <3c0f8442$1@news.povray.org>
Why do you need to undefine it?
Not trying to be confrontational, it may help to find a solution.
-tgq
"Rune" <run### [at] mobilixnetdk> wrote in message
news:3c0f7ffe@news.povray.org...
> possible...?
> Rune
> 3D images and anims, include files, tutorials and more:
Date: 6 Dec 2001 13:04:20
Message: <3c0fb324@news.povray.org>
In my particle system many settings are specified with macros rather than
with variables. The particle system can be called more than once in the same
scene, and sometimes you want some settings to be specified the first time
the system is called, but not the second time.
Rune
Date: 6 Dec 2001 22:08:10
Message: <3c10329a@news.povray.org>
Have you tried #undef ???
If that doesn't work, perhaps you could redefine it after it is called
based on a flag set within the macro?
N Shomber
Date: 6 Dec 2001 23:36:15
Message: <slrna10hq6.kpj.ron.parker@fwi.com>
Can you just redefine it to do nothing?
#local R=<7084844682857967,0787982,826975826580>;#macro L(P)concat(#while(P)chr(
mod(P,100)),#local P=P/100;#end"")#end background{rgb 1}text{ttf L(R.x)L(R.y)0,0
translate<-.8,0,-1>}text{ttf L(R.x)L(R.z)0,0translate<-1.6,-.75,-1>}sphere{z/9e3
4/26/2001finish{reflection 1}}//ron.parker@povray.org My opinions, nobody else's
Date: 7 Dec 2001 03:33:56
Message: <3c107ef4@news.povray.org>
Rune wrote in message <3c0f7ffe@news.povray.org>...
>possible...?
You should be able to "undefine" a macro by redefining it as something like:
#macro mymacro(a,b,c)
  /* A macro that does nothing */
Mark
Date: 7 Dec 2001 04:34:48
Message: <3C108A14.18681430@namtar.qub.ac.uk>
From this I assume Rune means that his system checks whether or not the
macro is defined (using #ifdef), else it assigns a default value;
redefining the macro to do nothing wouldn't be any use here.
signature{
  "Grey Knight"
  contact{ email "gre### [at] yahoocom" }
  site_of_week{ url "http://www.esite-host.com/~rocketmg/" }
Date: 7 Dec 2001 07:33:41
Message: <3c10b725$1@news.povray.org>
This may not be what rune is looking for, if  I understand correctly.  If
you do this, you may end up getting an error when you try to use the macro.
If you could undefine it, then you could check if it is defined, and only
run it if it was.
Or perhaps I'm just putting words in your mouth.
-tgq
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:3c107ef4@news.povray.org...
> >possible...?
like:
> #end
> Mark
Date: 7 Dec 2001 07:37:49
Message: <3c10b81d$1@news.povray.org>
"Trevor Quayle" <Tin### [at] hotmailcom> wrote in message
news:3c10b725$1@news.povray.org...
macro.
> run it if it was.
> -tgq
Just thinking, if this is the case perhaps you could do something like:
#macro MyMacro(a,b,c)
    "XXX"
then check using:
#if(MyMacro(a,b,c) != "XXX")
-tgq
Date: 7 Dec 2001 07:44:41
Message: <fvd11uobje6lksrem9uvv32761em5l6pf8@4ax.com>
> possible...?
Could it be good workaround for you ?
#version 3.5;
#include "strings.inc"
#macro Define_Macro(Name)
  Parse_String(concat("#declare Macro_",Name,"_Defined=yes"))
#macro Undefine_Macro(Name)
  Parse_String(concat("#undef Macro_",Name,"_Defined"))
#macro Is_Macro_Defined(Name)
  Parse_String(concat("(defined(Macro_",Name,"_Defined)"))
I have not tested this becouse of "Instances" problem of current beta, sorry.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 7 Dec 2001 10:45:39
Message: <3c10e423@news.povray.org>
My whole point is that #undef doesn't work with macros and that's what I
don't like.
> after it is called based on a flag set within the macro?
I don't want to redefine it! I want to undefine it!
Rune
Date: 7 Dec 2001 10:45:45
Message: <3c10e429@news.povray.org>
> do something like:
That only works when the code invoking the macro expects a string, which it
doesn't.
Rune
Date: 7 Dec 2001 10:45:46
Message: <3c10e42a@news.povray.org>
> correctly.  If you do this, you may end up getting an
Exactly.
> defined, and only run it if it was.
Yes. And much other code will also only be run if the macro is defined.
Rune
Date: 7 Dec 2001 10:45:47
Message: <3c10e42b@news.povray.org>
Sorry, too slow, as the macro will be called 10000, 100000 or more times.
Besides, the macro is to be defined by the *user* of my include file, so
simplicity is vital.
Rune
Date: 7 Dec 2001 10:45:48
Message: <3c10e42c@news.povray.org>
No! I want to undefine it!
I use #ifdef to test whether or not the macro is defined, and of course it
still returns true if I redefine the macro to do nothing.
You can define a macro and you can test whether or not it's defined, but you
can't undefine it. I find that highly inconsistent! Is there any reasoning
behind this design in POV-Ray?
If not, I hope that the ability to undefine a macro using #undef will be
added to POV-Ray ASAP.
Rune
Date: 7 Dec 2001 10:45:49
Message: <3c10e42d$1@news.povray.org>
That's not undefining the macro. #ifdef is the proof, and also the reason
it's not a working solution for me.
See my reply to Ron.
Rune
Date: 7 Dec 2001 10:55:32
Message: <g8p11u41ah88kc5078uk8m61b23jgumjb1@4ax.com>
Is it some kind of method/properities of the particle ?
Can you list this methods ?
Can you build array of arrays of methods ?
#if(Defined_Method(ParticleID,Method_Selector)) ?
So user have to write macro with method and define entry in array of methods?
Of course it is workaround not as good as it could be.
ABX
Date: 7 Dec 2001 11:13:06
Message: <slrna11qkk.nq1.ron.parker@fwi.com>
The ability to do so was mostly already there, but there was a bug that
prevented it from working.  When we saw the macro ID, we tried to invoke
the macro instead of just looking at its ID.  That bug will be fixed in
the next beta of 3.5.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 7 Dec 2001 13:42:31
Message: <3c110d97@news.povray.org>
> there was a bug that prevented it from working.
> When we saw the macro ID, we tried to invoke the
> will be fixed in the next beta of 3.5.
Just what I hoped for! Many thanks!
Rune
Date: 7 Dec 2001 13:42:35
Message: <3c110d9b$1@news.povray.org>
Never mind, Ron have said that the problem will be fixed in the next beta.
Rune
Date: 7 Dec 2001 13:49:11
Message: <3c110f27@news.povray.org>
news:3c110d9b$1@news.povray.org...
> Rune
Phew, I have been wracking my brain all day trying to figure this one out.
I have been released.
I did come up with some really odd stuff in the process though.
-tgq
