POV-Ray : Newsgroups : povray.general : Trace()? Server Time
23 Oct 2026 16:54:53 EDT (-0400)
  Trace()? (Message 1 to 31 of 31)
Subject: Trace()?
Date: 12 Nov 2001 19:08:47
Message: <3bf0648f$1@news.povray.org>
Could anyone explain to me exactly how one uses the trace() function to
detect object collisions? The docs say that 'trace() can be used to detect
the exact point a ray intersects a surface' and then gives a perfectly
incomprehensible (to me at least) example.
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
Subject: Re: Trace()?
Date: 13 Nov 2001 01:52:02
Message: <3BF0C313.DE3D24B8@gmx.de>
You will find une in the insert menu:
// trace function tests for intersection with a specified object
#declare Obj = sphere { 0, 1 }
#declare Norm = <0, 0, 0>;
#declare Start = <0.5, 0.5, 1>;
#declare Pos = trace (
                  Obj,             // object to test
                  Start,           // starting point
                  -z,              // direction
                  Norm );          // normal
// if intersection is found, normal differs from 0
#if (Norm.x != 0 | Norm.y != 0 | Norm.z != 0)
Date: 13 Nov 2001 03:23:48
Message: <3bf0d894@news.povray.org>
Mahalis <don### [at] fakeycom> wrote:
: Could anyone explain to me exactly how one uses the trace() function to
: detect object collisions?
  If you mean that you want to detect if an object collided with another
object, regardless of shape, then that's one of the most difficult things
to do. Tracing can help a bit, but that's only perhaps 0.1% of everything you
need for that.
Date: 13 Nov 2001 03:48:17
Message: <ucn1vt8lo1a1ebi08ehvjgv93g1u6r4dvf@4ax.com>
You are talking about 3.5, right? Check trace.pov and trace2.pov in
POV3.5/scenes/language/ directory.
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Date: 13 Nov 2001 18:11:55
Message: <3bf1a8bb$1@news.povray.org>
I didn't exactly mean 'colliding' as in 'running into'; I meant 'colliding'
as in 'intersecting'.
//Mahalis
news:3bf0d894@news.povray.org...
you
> need for that.
Date: 13 Nov 2001 23:07:06
Message: <3bf1edea$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3bf0d894@news.povray.org...
> need for that.
This reminds me, I just thought of something for my 4.0 wishlist.  A function
like inside that works for objects instead of vectors, as in:
    #declare A = sphere { 0, 1 }
    #declare B = sphere { 0.5*x,1 }
    #if (intersect(A,B)) #debug "A intersects B\n" #end
That would make collision detection *much* easier.
Hmmm... is this always guaranteed to work?
    #include "stdinc.inc"
    #include "shapes.inc"
    #declare B = box { 2, 3 }
    #declare Min = x*0;
    #declare Max = x*0;
    Extents(intersection { object { A } object { B } }, Min, Max)
    #if (!VEq(Max,<10000000000,10000000000,10000000000>)) #debug "A intersects
B\n"
    #else #debug "A does not intersect B\n"
    #debug concat(VStr(Min), "  ", VStr(Max))
I would suppose it depends on what POV-Ray assigns as the Min/Max for a
degenerate bounding box.  And if the DBB is always possible to detect.
It appears to work with primatives and small CSGs... but I could be wrong.
Haven't tested it much.
Any thoughts?
Michael
#macro M(D)#local J=strlen(D);#local _=""#while(J>0)#local _=concat(_,substr(D
,J,1))#local J=J-1;#end _#end sphere{z*9,5pigment{rgb x}}#macro N(D,J)text{ttf
"timrom.ttf"M(D)1,0 translate-J}#end#macro O(E,K)#local _=N(E,K)light_source{-
z*9rgb 1projected_through{_}}#end O("leahciM"<1.6,-.3.9>)O("nosnhoJ"<1.6.9.9>)
Date: 14 Nov 2001 01:33:29
Message: <3bf21039@news.povray.org>
: I didn't exactly mean 'colliding' as in 'running into'; I meant 'colliding'
: as in 'intersecting'.
  The problem is still exactly the same and exactly as difficult.
Date: 14 Nov 2001 01:36:41
Message: <3bf210f9@news.povray.org>
Redbeard <red### [at] wvadelphianet> wrote:
: This reminds me, I just thought of something for my 4.0 wishlist.  A function
: like inside that works for objects instead of vectors, as in:
:     #declare A = sphere { 0, 1 }
:     #declare B = sphere { 0.5*x,1 }
:     #if (intersect(A,B)) #debug "A intersects B\n" #end
  As I said, that's extremely difficult to implement for any given object.
Of course it's trivial for spheres, but if you want to support any object,
you are approximating the impossible.
:     Extents(intersection { object { A } object { B } }, Min, Max)
  Note that even if the bounding boxes of the objects intersect, that doesn't
mean that the objects themselves do.
: It appears to work with primatives
  Again that word...
Date: 14 Nov 2001 01:47:48
Message: <3BF213CD.3CBDBBC7@pacbell.net>
>   Again that word...
I'll teach them to stop using "that" word if you stop using "drastical" :)
Ken Tyler
Date: 14 Nov 2001 02:00:58
Message: <3bf216a9@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: I'll teach them to stop using "that" word if you stop using "drastical" :)
  Some english words confuse me a lot.
  The word "drastically" exists. By logic, it would come from the word
"drastical" (drastical + ly = drastically).
  But no, it comes from the word "drastic".
  By reverse logic, it would mean that drastic + ly = drasticly.
  But no, it's drastic + ly = drasticALly.
  It makes no sense.
Date: 14 Nov 2001 02:11:55
Message: <3BF21972.FCD8F3A3@pacbell.net>
>   It makes no sense.
And primitive is often pronounced prim.a.tive so it is somewhat understandable
that people will spell it like they speak it. It is a common problem with the
english language and with those who try to spell it like they speak it.
Followup-To: p.o-t
Ken Tyler
Date: 14 Nov 2001 02:45:10
Message: <3bf22106@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3bf216a9@news.povray.org...
>   It makes no sense.
Sure it does.
It's 'drastic' + '- ally'.
'Drastic' is an adjective. Adding the suffix '-ally' makes it an adverb.
A 'drastical' (or drasticle) would be a neologistic noun representing
that which is a particle of drasticness.
'-ally' is the suffix used to make an adverb from an adjective that
ends in '-ic' when there is no '-ical' form.
Incidentally (and not accidentally), these grammaricals arose from
borrowed Greek. (See? There is no 'incidentical' or 'accidentical' -
those words sound wrong, eh?).
"English makes sense except when it doesn't".
Just to round things off -
'Identical" is an adjective. The word ends in '-ical', The adverb
formed from 'identical' is 'identically'. In this case it is the suffix '-ly'
added to the '-ical' adjective to make the adverb. Sometimes it is hard to
tell if the adverbial suffix appended to an adjective is '-ly' or '-ally'.
So, why is drastic - 'drastic' and identical is not 'identic' ?  I don't know,
it's all Greek to me. What's worse is that 'identic' exists as an adjective, but
means something completely different than 'identical'. ('identic' is a
diplomatic
term used diplomatically by diplomats in a diplomatical manner.)
These -ics, -icals, -lys, and -allys are everywhere.
It almost seems conspiratorical.
Date: 14 Nov 2001 03:43:42
Message: <3bf22ebd@news.povray.org>
pan### [at] syixcom wrote:
: "English makes sense except when it doesn't".
  That sums it up. :)
Date: 14 Nov 2001 05:37:41
Message: <ncd4vt4iprte5bjhvfnmbbo4pq222vj6b4@4ax.com>
On Tue, 13 Nov 2001 23:16:02 -0500, "Redbeard" <red### [at] wvadelphianet> wrote:
of course not
just check this with
    #declare A = plane { x, 1 }
    #declare B = plane { -x, 0 }
I can propose rather such macros (below). It is not tested hardly but seems
work. It could be extended with another level - sampled value for random points
(in bound) of function{pattern{object{I}}}.
I wonder what should be result for plane{x,1} and plane{x,0} ?
Your and mine returns "no intersection", but is it true ?
// A - first object
// B - second object
// S - sampling level
#macro Colision_Detection(A,B,S)
  #local I=intersection{object{A}object{B}};
  #declare Min=min_extent(I);
  #declare Max=max_extent(I);
  #local K=0;
  #local Found=Sample_Detection(
    <Min.x-.1,Min.y,Min.z>,
    <Min.x-.1,Max.y,Min.z>,
    <Min.x-.1,Max.y,Max.z>,
    <Min.x-.1,Min.y,Max.z>,
    x,S-1);
  #if(!Found)
    <Min.x,Min.y-.1,Min.z>,
    <Max.x,Min.y-.1,Min.z>,
    <Max.x,Min.y-.1,Max.z>,
    <Min.x,Min.y-.1,Max.z>,
    y,S-1);
  #if(!Found)
    <Min.x,Min.y,Min.z-.1>,
    <Min.x,Max.y,Min.z-.1>,
    <Max.x,Max.y,Min.z-.1>,
    <Max.x,Min.y,Min.z-.1>,
    z,S-1);
  #debug concat("Sampling called ",str(K,0,0)," times\n")
  (Found?true:false)
// check ray sended from center of quad <P1,P2,P3,P4> in direction D
// if level S>0 then send subsample
#macro Sample_Detection(P1,P2,P3,P4,D,S)
  #local N=y;
  #local C=(P1-P3)/2;
  #local T=trace(I,C,D,N);
  #if(!(N.x=0 & N.y=0 & N.z=0))
    #local Found=true;
  #else
    #if(S<0)
      #local Found=false;
    #else
      #local Found=Sample_Detection(P1,(P1+P2)/2,C,(P1+P4)/2,D,S-1);
      #if(!Found)
        #local Found=Sample_Detection((P1+P2)/2,P2,(P2+P3)/2,C,D,S-1);
      #if(!Found)
        #local Found=Sample_Detection(C,(P2+P3)/2,P3,(P3+P4)/2,D,S-1);
      #if(!Found)
        #local Found=Sample_Detection((P1+P4)/2,C,(P3+P4)/2,P4,D,S-1);
  #declare K=K+1;
  (Found?true:false)
ABX
Date: 14 Nov 2001 07:08:04
Message: <3bf25ea4$1@news.povray.org>
That's English for ya... ;-)
//Mahalis
Date: 14 Nov 2001 08:55:22
Message: <3bf277ca$1@news.povray.org>
    Problem is... that's
French-German-Spanish-Latin-Greekitalianswedishdutchrussianhebrewjapaneseame
ricanindianetc for ya...
    If we had one history or origin or if it were made instead of grown, it
would not be so confusing.
Date: 14 Nov 2001 09:04:46
Message: <3bf279fe$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:3bf210f9@news.povray.org...
>   Again that word...
Ooops.  Doesn't even look right to my eye.  But the fingers move faster than the
brain, sometimes.
Date: 15 Nov 2001 05:51:38
Message: <Xns915A3B91EED35mrartchesapeakenet@204.213.191.226>
Bill DeWitt scribis news:3bf277ca$1@news.povray.org:
>     grown, it
Try a "made" language then. Several exist. Anything from Klingon to
Atlantian. There are several clubs that for the "speaking" population to
get together at/with and have fun.
My favorite is Esperanto. Is a small group here in D.C. that My daughter
and I go to. My daughter is at the "conversation" level, but I am at the
"scratch my head and don't say anything" level. The day will come when I
will be able to speak with confidance, but that is a long ways away.
Gis posta, Arto.
Date: 15 Nov 2001 05:56:51
Message: <3bf39f73@news.povray.org>
"Arthur Flint" <mra### [at] chesapeakenet> wrote in message
> >     grown, it
I'd love to get to conversation level with ancient Greek but I don't know anyone
else that speaks the language...
- Nekar
Version: 6.0.286 / Virus Database: 152 - Release Date: 2001/10/09
Date: 15 Nov 2001 08:03:44
Message: <3bf3bd30$1@news.povray.org>
"W³odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:ncd4vt4iprte5bjhvfnmbbo4pq222vj6b4@4ax.com...
> of course not
Yeah, I didn't figure it would.
Michael
Date: 15 Nov 2001 11:49:23
Message: <3BF3F1A7.D25648DA@geocities.com>
Ask around of the staff at some Protestant churches in your area. At least here in
the states that is a language usually learned in seminary.
Jon A. Cruz
http://www.geocities.com/joncruz/action.html
Date: 15 Nov 2001 11:50:47
Message: <3BF3F1FB.5C9F9FB7@geocities.com>
> >     grown, it
You forgot to mention the languages that Tolkien made. His history for them
is quite interesting also.
Jon A. Cruz
Date: 15 Nov 2001 11:58:22
Message: <3bf3f42e$1@news.povray.org>
    That's on my list. I hear it is fairly simple to learn if you are a
Latin-based native speaker.
Date: 15 Nov 2001 20:44:25
Message: <Xns915AD2F00B9FCmrartchesapeakenet@204.213.191.226>
Bill DeWitt scribis news:3bf3f42e$1@news.povray.org:
Here is a translation (of sorts) of your comment.
Tio estas je mia listo. Mi audas ke Esperanto estas falica por lerni,se vi
estas Latinderivite indig^ena parolulo.
The language uses an accusitive case for the recipent of the action. So in
one instance " a male dog" could be spelled "hundo" and in another,
"hundon". Means you have to listen verry carefully to how things are said
to catch the meaning.
G^is poste, Arto.
(until later, Art)
Date: 15 Nov 2001 22:52:49
Message: <3bf48d91$1@news.povray.org>
    Well, they gotta fix that ^ business... Other than that, as is true of
french italian and spanish, you can pick out root words and get most of the
meaning.
> G^is poste, Arto.
> (until later, Art)
Date: 16 Nov 2001 00:36:18
Message: <i899vtgbsahg9ct49iq0asrahjphpmo8na@4ax.com>
On 15 Nov 2001 20:44:25 -0500, Arthur Flint <mra### [at] chesapeakenet>
A strange mixture of Spanish-, Italian-, Romanian- and Latin-like
ingredients. All Roman languages. BTW should "Latinderivite" really be
a single word?
Peter Popov ICQ : 15002700
Date: 16 Nov 2001 03:59:47
Message: <Xns915B289E4AA1Amrartchesapeakenet@204.213.191.226>
Peter Popov scribis news:i899vtgbsahg9ct49iq0asrahjphpmo8na@4ax.com:
> ingredients.
All true, with some German and Greek roots in there too.
>All Roman languages. BTW should "Latinderivite" really be a single word?
It could well be as we wern't all too sure how to construct that one. Some
words are constructed by concatanation.
i.e. Mang^o "food" + c^ambro "room" = mang^oc^ambro "dinning room"
Gis posta, Arto.
Date: 16 Nov 2001 04:04:35
Message: <Xns915B296E9A1C3mrartchesapeakenet@204.213.191.226>
Bill DeWitt scribis news:3bf48d91$1@news.povray.org:
>     of french italian and spanish, you can pick out root words and get
>     most of the meaning.
It might look better if you could see the characters in proper format.
The "^" should be over the character that it comes after. Until all the
world lives with unicode, that is the best I could do. There is c^, g^, h^,
s^, and a u with a small symbole over it.
Gis posta, Arto.
Date: 16 Nov 2001 08:04:29
Message: <3bf50edd@news.povray.org>
Follow-up set
h^,
    I went through and set up two letter combinations for every phoneme I
could find and pronounce (for my own constructed language), using standard
American English character pronunciations. It seems like the folk who
developed Esperanto could have done something similar.
Date: 22 Nov 2001 13:01:01
Message: <yceboGAMPH$7Ew7m@econym.demon.co.uk>
It occurred to me that it ought to be possible to detect whether two
convex objects had collided by tracing in both directions along the line
that joins their centres.
Consider two convex objects that are not touching. As we look along the
line that joins their centres we encounter the significant points in the
following order:-
        Centre of object 1
        Surface of object 1
        Surface of object 2
        Centre of object 2
If the objects are moved closer so that they intersect, then the order
changes to
        Centre of object 1
        Surface of object 2
        Surface of object 1
        Centre of object 2
(With concave objects all bets are off. It's possible for two concave
objects to touch at the ends while there is still a gap between them
along the line that joins their centres).
I came up with code that looks like this
// trace object2 from the centre of object 1 and vice verca
#declare Surface2 = trace(Object2, Centre1, (Centre2-Centre1));
#declare Surface1 = trace(Object1, Centre2, (Centre1-Centre2));
// The objects intersect if Surface2 is nearer to Centre1
// than Surface1 is
#if (vlength(Surface2-Centre1) < vlength(Surface1-Centre1))
  #debug "They intersect\n"
#else
  #debug "They don't\n"
But that code can sometimes give the wrong answer if the objects overlap
to such an extent that the centre of one lies inside the surface of the
other. For example, if the centres are very close the order might be
        Surface of Object 1
        Centre of Object 1
        Centre of Object 2
        Surface of Object 2
and the surfaces could be at any distance.
I think that this works
// The objects intersect if the centre-centre distance
// is less than the sum of the centre-surface distances
#if ((vlength(Centre2-Centre1)  < (vlength(Surface1-Centre1) +
     vlength(Surface2-Centre2))))
#else
Mike Williams
Gentleman of Leisure
Date: 22 Nov 2001 13:05:03
Message: <3BFD3E3E.FC0DCA3E@aol.com>
I'm wondering, with the centers (Am. sp.) known, if you might not be able to
use max_extents to learn where the outer edge of the object lies...
