First, let me start by saying that I HAVE seen Rune's IK leg, and that while
it looks like a nice file, does not solve my problem. I have a bipedal
system with legs consisting of a thigh and calf each 1.75 units, and a foot
.75 units long. The model is manipulated by telling the joints a rotation
(I want the system to be as versatile as possible). My problem is this: How
much and when should the joints flex? I suppose I could figure it out, but
if anyone else has ideas, any input would be much appreciated!
Barron
If you give a man a program you will frustrate him for a day; if you teach a
man to program you will frustrate him for a lifetime; if you teach a Gates
to program you will frustrate the world.
> Rune's IK leg, and that while it looks like a
I would like to help, but I can't if not you explain exactly why the IK leg
solution doesn't solve your problem.
> rotation (I want the system to be as versatile
> as possible). My problem is this: How much and
The IK leg file can be used to find the angles if you really need them, but
I still don't understand what prevents you from using transformations rather
than rotations. They are equally versatile and walking will be much easier
when using transformations.
Rune
Rune's World: http://rsj.mobilixnet.dk (updated Nov 5)
POV-Ray Users: http://rsj.mobilixnet.dk/povrayusers/
I, too, preferred to set up a system where I kept my original "FK
construction", used IK to program the position of the joints, then
back-calculated what FK would allow these IK coordinates. It's more complex to
code this mechanism, but the simple FK construction is inherently pleasing to
me.
> "FK construction", used IK to program the position of the
> joints, then back-calculated what FK would allow these IK
> coordinates. It's more complex to code this mechanism, but
> the simple FK construction is inherently pleasing to me.
But you cease to give me a rational reason, and so far the transformation
method has proven to be able to do the same and much more... :)
Rune
Greg M. Johnson scribis news:3BF01FF8.2FAAC21C@aol.com:
> complex to code this mechanism, but the simple FK construction is
I have seen the term IK and FK used freely on this board. And though I
understand that they mean Inverse Kinetics and Forward Kinetics, just what
does that mean?
Gis posta, Arto.
> though I understand that they mean Inverse Kinetics and Forward
> Kinetics, just what does that mean?
Inverse Kinematics is a method wherein (since we're talking about
walking, I'll use a leg as example) you move the foot to its end
position, and everything that's attached to it (attempts to) move
appropriately. Forward Kinematics is where you move each part
manually, i.e. upper leg is fixed at hip move knee relative to hip,
then ankle location relative to knee, then foot relative to ankle.
(Hear the word of the Lord!)
AFAIK, FK is what POV/Moray has. Poser has IK as an option when
positioning arm/leg, but it's kinda funky because just moving
your foot doesn't take into consideration HOW you're moving your
leg. It just does the simplest 'point B is the average of A and
C' construct (I think...).
Tim Cook
Version: 3.12
First of all, they are both ways of positioning joints so the limb/body as a
whole is in the correct position, but their approaches to doing so are quite
different. In forward kinematics, you specify a rotation at each joint in,
say, an arm, to position the hand where you want it. In inverse kinematics,
you specify the location of the hand and the joint angles are mathematically
computed to place the had at that point.
Essentially, with forward kinematics:
Hip-moves-upper leg-moves-knee-moves-lower leg-moves-ankle-moves-foot.
With inverse kinematics:
Foot-moves-ankle-moves-lower leg-moves-etcetera.
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
"Arthur Flint" <mra### [at] chesapeake net> wrote in message
news:Xns### [at] 204 213 191 226...
> does that mean?
You may determine the rationality of this, but here goes:
1) My two complete and favorite blob systems were built with FK, so there's
no rewrite from scratch.
2) It's quite hard to model. I came up with the perfect system using
transforms and spent a week making a blob out of it. It is hideous.
Hi Timothy R. Cook, you recently wrote in povray.general:
Moray also has some IK functionality.
- Lutz
email : lut### [at] stmuc com
Web : http://www.stmuc.com/moray
Timothy R. Cook scribis news:3BF06018.5A563507@scifi-fantasy.com:
Thanks to both of you who answered. Now I can start to think about seetting
up some form of posing system for the manniquins that I use.
Gis posta, Arto.
> built with FK, so there's no rewrite from scratch.
You don't have to rewrite your model from scratch at all! Simple
translations inside the transforms can be used to make sure all body parts
are aligned correctly.
> perfect system using transforms and spent a week
If that's the case it doesn't sound too perfect to me...
As I said, you can model your model like you would normally do, and a line
with a transform statement is no more hideous than a line with a rotate
statement.
Rune
