POV-Ray : Newsgroups : povray.general : CText Server Time
23 Oct 2026 17:51:45 EDT (-0400)
  CText (Message 1 to 17 of 17)
Subject: CText
Date: 8 Nov 2001 07:50:25
Message: <3bea7f91$1@news.povray.org>
I recently made a macro to do almost-perfctly-centered text. Anyone
interested?
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
Subject: Re: CText
Date: 8 Nov 2001 08:04:01
Message: <nh0lutchh0ph8b0olp9pvohdq94tklu3pi@4ax.com>
> interested?
I'm interested. What is wrong with centered around bounding box? Or is it the
same? Could you provide some image to show atventage of your
"almost-perfctly-center" ?
ABX
#declare _=function(a,b,x){((a^2)+(b^2))^.5-x}#default {pigment{color rgb 1}}
union{plane{y,-3}plane{-x,-3}finish{reflection 1 ambient 0}}isosurface{ //ABX
function{_(x-2,y,1)|_((x+y)*.7,z,.1)|_((x+y+2)*.7,z,.1)|_(x/2+y*.8+1.5,z,.1)}
contained_by{box{<0,-3,-.1>,<3,0,.1>}}translate z*15finish{ambient 1}}//POV35
Subject: Re: CText
Date: 8 Nov 2001 08:23:11
Message: <3bea873f@news.povray.org>
I'm not sure what the advantage is over 'centered bounding boxes' (to be
perfectly honest I've never heard of using such a technique to do this).
//Mahalis
"W³odzimierz ABX Skiba" <abx### [at] babilonorg> wrote in message
news:nh0lutchh0ph8b0olp9pvohdq94tklu3pi@4ax.com...
> > interested?
the
> ABX
1}}
//ABX
1}}//POV35
Download 'text.png' (11 KB)
Preview of image 'text.png'
Subject: Re: CText
Date: 8 Nov 2001 08:28:04
Message: <3BEA8863.410C1559@gmx.de>
See the Center_Object() macro in 'shapes.inc'
BTW, you should know that you should not post binaries in this group.
Subject: Re: CText
Date: 8 Nov 2001 08:41:14
Message: <l82lutola6vcavbh9qopoho3h7m1itbvjo@4ax.com>
With MegaPOV and POV 3.5 you can find useful vector functions min_extent and
max_extent to get lower and higher corner of bounding object. With this you can
find center and size of any object. It is not perfect center but good enough in
almost all situations. You can use it as:
#declare Text=text {ttf "crystal.ttf" "Mahalis" 2 0};
#declare Min=min_extent(Text);
#declare Max=max_extent(Text);
#declare Size=Max-Min;
#declare Center=(Max+Min)/2;
object{Text translate -Center}
You can also find Center_Object in 3.5's standard include files.
So, is your solution still almost-perfect ?
ABX
Subject: Re: CText
Date: 8 Nov 2001 08:49:22
Message: <3bea8d62$1@news.povray.org>
Well, I see 6 lines of code there, as opposed to:
ctext("MaHaLiS","C:\Windows\Fonts\ocrb.ttf",0.125,yes,texture{pigment{Blue}
finish{reflection 0.25 metallic}},interior{})
//Mahalis
news:l82lutola6vcavbh9qopoho3h7m1itbvjo@4ax.com...
and
you can
enough in
> ABX
1}}
//ABX
1}}//POV35
Subject: Re: CText
Date: 8 Nov 2001 09:02:53
Message: <qm3lutsk4ug928itbjhpounodvn89m2u0b@4ax.com>
Oh, you want count?
So let's simplify this 6 lines, remove not necessary space and group to macro
#macro Center(O)object{O translate-(max_extent(O)+min_extent(O))/2}#end
is your macro shorten? :-)
Note it works fine with all objects.
Center(text{ttf "crystal.ttf" "Mahalis" 2 0})
Center(sphere{0,1})
ABX
Subject: Re: CText
Date: 8 Nov 2001 10:18:57
Message: <3beaa261$1@news.povray.org>
Poo. Well.. that only works in POV 3.5, whereas mine works equally well in
3.1 and 3.5.
Look, I'm really scraping the bottom of the barrel here.. :-)
//Mahalis
news:qm3lutsk4ug928itbjhpounodvn89m2u0b@4ax.com...
> Oh, you want count?
macro
> Center(sphere{0,1})
> ABX
1}}
//ABX
1}}//POV35
Subject: Re: CText
Date: 8 Nov 2001 10:38:10
Message: <3beaa6e2@news.povray.org>
"Mahalis" <don### [at] fakeycom> wrote in message
news:3beaa261$1@news.povray.org...
> 3.1 and 3.5.
No your not - your grasping at straws ;)
Subject: Re: CText
Date: 8 Nov 2001 10:58:07
Message: <3beaab8f@news.povray.org>
Okay, okay, I get the message. No one wants my poor little macro [sniff]
<g>
//Mahalis
Subject: Re: CText
Date: 8 Nov 2001 11:04:55
Message: <3beaad27@news.povray.org>
news:3beaab8f@news.povray.org...
> <g>
    What macro?
Subject: Re: CText
Date: 9 Nov 2001 03:26:02
Message: <ik4nutoba5si6hj6fo6ga3h4k3a16741qr@4ax.com>
> <g>
That's not true. I said to you I'm interested at first post. There could be
always interesting technic. But you tried fight. I showed source. Where is your?
ABX
Subject: Re: CText
Date: 9 Nov 2001 03:28:38
Message: <cr4nutcs8vm0j8h9k4qoegcrpjitjc9o7v@4ax.com>
On Thu, 08 Nov 2001 15:02:46 +0100, W�odzimierz ABX Skiba <abx### [at] babilonorg>
> Center(sphere{0,1})
Hmmm, not very brillant example :-)
ABX
Subject: Re: CText
Date: 9 Nov 2001 06:32:57
Message: <3bebbee9@news.povray.org>
#macro ctext(txt,fon,thk,ac,tex,in)
#local len=strlen(txt)*0.55
#if(ac)
text{ttf fon txt thk,0 texture{tex} interior{in}translate
<-(len/2),-0.375,-(thk/2)>}
#else
<-(len/2),0,-(thk/2)>}
txt=Text
fon=Font
thk=Thickness
ac=Absolute center
tex=Texture
in=Interior
//Mahalis
news:ik4nutoba5si6hj6fo6ga3h4k3a16741qr@4ax.com...
> > <g>
be
your?
> ABX
1}}
//ABX
1}}//POV35
Subject: Re: CText
Date: 9 Nov 2001 08:03:59
Message: <3bebd43f@news.povray.org>
Mahalis <don### [at] fakeycom> wrote:
: #local len=strlen(txt)*0.55
  Do you really think this is completely accurate independently of the font
and characters used?
  I would say that min_extent() and max_extent() are much more accurate than
that.
Subject: Re: CText
Date: 9 Nov 2001 16:34:06
Message: <3bec4bce$1@news.povray.org>
Yes, I suppose they are. Phoo, and I thought I had something useful :-(
//Mahalis
news:3bebd43f@news.povray.org...
font
than
> that.
Subject: Re: CText
Date: 9 Nov 2001 17:04:39
Message: <3bec52f7@news.povray.org>
In article <3bec4bce$1@news.povray.org> , "Mahalis" <don### [at] fakeycom>
Well, you had good intent, just the implementation had a few problems...
    Thorsten
e-mail: tho### [at] trfde
