POV-Ray : Newsgroups : povray.general : Crash Server Time
23 Oct 2026 17:51:45 EDT (-0400)
  Crash (Message 1 to 3 of 3)
Subject: Crash
Date: 2 Nov 2001 21:11:39
Message: <3be3525b$1@news.povray.org>
For some reason, POV 3.1 crashed when it tried to render something from 3.5.
I checked all the compatiility issues- the only thing that could be causing
it is the "transmit all 0.5". Source:
#declare plogo=merge {
   sphere {2*y, 1}
   difference {
      cone {2*y, 1, -4*y, 0}
      sphere {2*y, 1.4 scale <1,1,2>}
   difference {
      sphere {0, 1 scale <2.6, 2.2, 1>}
      sphere {0, 1 scale <2.3, 1.8, 2> translate <-0.35, 0, 0>}
      rotate z*30 translate 2*y
   rotate <0, 0, -25>
   translate <-0.5,-0.25,0>
   scale 1/4.625
light_source{<0,4,-6> White*1.25}
camera{location<0,0,-2.5> look_at 0}
sky_sphere{pigment{granite scale 0.01 color_map{[0 Black][0.475 Black][0.5
White][0.525 Black][1 Black]}}}
sphere{0,0.875 pigment{image_map{sys "earthmap.bmp" map_type 1 transmit all
0.5}} finish{diffuse 1}} //earth- here's where it crashes
light_source{<0.625,0.625,-0.625> White*0.75 fade_distance 0.1875 fade_power
2}
object{plogo pigment{White} finish{diffuse 1.5 ambient 0.25}}
What's going on here?
//Mahalis
camera{location<0,0.25,-2> look_at 0.5*y} #declare T=texture{pigment{crackle
scale 0.5 rotate 90 turbulence 0.75 color_map{[0 rgb 1][0.05 rgb 1][0.1
rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}} finish{ambient 1}} #declare
c=difference{torus{0.5,0.1 rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}
merge{object{c translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
Subject: Re: Crash
Date: 2 Nov 2001 22:01:38
Message: <3BE35E22.668F7280@pacbell.net>
Are you using a palleted 8 bit .bmp? The 'transmit all' only works
with 256 color palleted image files. Not that it explains the crash
but it is something that you should know anyway. Try converting the
.bmp to a .gif file and see if the problem persists.
Ken Tyler - POV-Ray Technical Assistance Group
Subject: Re: Crash
Date: 3 Nov 2001 10:11:56
Message: <3be4093c$1@news.povray.org>
Thx. I'll try that.
//Mahalis
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3BE35E22.668F7280@pacbell.net...
all
