POV-Ray : Newsgroups : povray.general : Is it real...? Server Time
23 Oct 2026 18:56:32 EDT (-0400)
  Is it real...? (Message 1 to 26 of 26)
Subject: Is it real...?
Date: 13 Oct 2001 10:25:16
Message: <3bc84ecc@news.povray.org>
Just wondering how many people try to model reality, and how many try to
model an appearance of reality. For instance, when you need a crowd of trees
in the background, are you more likely to make a bunch of trees, or will you
put up an image map of some trees on a box? When trying to make a texture,
do you make it in detail every time, or do you let it slide if it is too far
back for all the normals to be seen?
    Since I always tend towards animation, I try to make things real. It
means that some projects just don't get done. But if I ever want to do a
walk through of one of my scenes, nothing ends up looking bad from the other
side.
    Just curious, no intent to disparage either method or assume that people
should use one exclusively of another. I just get the feeling that people
who aren't as hung up on reality are the ones that send us such good scenes
more often than others.
Subject: Re: Is it real...?
Date: 13 Oct 2001 11:30:36
Message: <3bc85e1c@news.povray.org>
"Bill DeWitt" <bde### [at] cflrrcom> wrote in message
news:3bc84ecc@news.povray.org...
to
trees
you
far
Having thought about this particular thing many times before I think I might
know my answer by now.
I put things together mostly by building from scratch, only cobbling a scene
together.  However, I've tried a few things which I wanted to be based on
reality as perceived or as photographed or even as measured.  So what
happens is that I create from that primary habit of piecing stuff together
but if the subject is realism, or rather reality, then I use sources to go
by.
other
> side.
Yes, and that's why stage-propping a scene is faster, easier and yet can be
too lacking.
people
scenes
The old saying, art for arts sake, but if it doesn't match up with a
preconceived idea it is destined to failure.  Actually that could be
debatable.
Bob H.
Date: 13 Oct 2001 11:32:02
Message: <3BC85E26.30603@videotron.ca>
A bit of both.  I will usually start by trying to model things as they
should be (almost to the point of thinking about intermolecular bonds)
but after hours of frustration, will reluctantly revert to faking it.
But still can't come to terms with the concept of using object libraries
or scanned images, unless told to.  I have so many failed reinvented
wheels lying around my hard disk, it's not even funny.
> side.
Same here.  I have spent numerous hours finagling over details that go
on the back of an object that would appear facing the camera, just in
case I wanted to reuse it at another angle or making sure that moveable
parts are.
Agreed.  This is the main reason I've only ever submitted one IRTC entry.
/*   videotron.ca  */}camera{location<6,1.25,-6>look_at a orthographic}
Date: 13 Oct 2001 12:44:17
Message: <3BC8A78A.1000706@chesapeake.net>
Mostly I just model stuff. I don't worry about making a scene.
Maybe that is why I don't ever post pics here.
> side.
Date: 13 Oct 2001 12:47:50
Message: <3bc87036$1@news.povray.org>
I tend to experiment with reality in both modelling and texturing, at the
expense of getting any serious project finished of course.
-tgq
to
trees
you
far
other
> side.
people
scenes
Date: 13 Oct 2001 12:56:48
Message: <3BC873DF.ACA0408C@hotmail.com>
> try to model an appearance of reality. For instance, when you need a
> crowd of trees in the background, are you more likely to make a bunch
> of trees, or will you put up an image map of some trees on a box?
It depends on the level of detail required.
> When trying to make a texture, do you make it in detail every time, or
> do you let it slide if it is too far back for all the normals to be
> seen?
My textures are rarely complicated, so I can afford to make them work
at all scales.
John
ICQ: 46085459
Date: 13 Oct 2001 13:16:22
Message: <3bc876e6@news.povray.org>
Most of the time I just model everything that's going to be in the scene,
but if there isn't going to be anything of much interest beyond a certain
point I just put everything inside a reflective sphere.
 camera{location<0,0.25,-2> look_at 0.5*y} #declare
T=texture{pigment{crackle scale 0.5 rotate 90 turbulence 0.75 color_map{[0
rgb 1][0.05 rgb 1][0.1 rgb<1,0.25,1>][0.25 rgbf 1][1 rgbf 1]}}
finish{ambient 1}} #declare c=difference{torus{0.5,0.1
rotate -90*x}box{<0.7,0,0.2>,<-0.7,-0.7,-0.2>}}  merge{object{c
translate<0.5,0.5,0>} object{c translate<-0.5,0.5,0>}
cylinder{<1,0.5,0>,<1,0,0>,0.1} cylinder{<-1,0.5,0>,<-1,0,0>,0.1}
cylinder{0.5*y,0,0.1} texture{T}}
//Mahalis
to
trees
you
far
other
> side.
people
scenes
Date: 13 Oct 2001 13:28:23
Message: <3BC8799D.C439E19C@hotmail.com>
NO
- It never is.
Tor Olav
Date: 13 Oct 2001 13:52:38
Message: <3BC87F70.9F8AEC49@ignorancia.org>
  I always try to get the appearance of reality by any mean, don't
matter if it is a phisically correct one or not. But this does not means
I model with detail all objects in the scene. In fact, most of my scenes
can't be rendered bigger because I used tricks that only work with
limited resolutions. I only have detailed objects at distance when I
reuse an old model, wich was on the foreground on a previous scene.
  Hmmm... not necesarily, but "usually" true. That's because an excess
of scruples can lead to never finish something. An old problem of art,
and many other human activities.
Jaime Vives Piqueres
http://www.ignorancia.org/
Date: 13 Oct 2001 14:12:29
Message: <3bc8840d$1@news.povray.org>
Although most of my work so far has been more abstract (that is, things that
you won't find in real life), I make it in such a way that if it *did*
appear in real life, the mathematics behind it all would be identical. I
don't use hacks to make things look realistic if the workings behind them
are unrealistic, with a few exceptions. For example, I try to avoid
shadowless lights, because you don't find shadowless lights in the real
world. Stuff like that.
- Slime
[ http://www.slimeland.com/ ]
[ http://www.slimeland.com/images/ ]
to
trees
you
far
other
> side.
people
scenes
Date: 13 Oct 2001 14:37:42
Message: <3bc889f6@news.povray.org>
Although I have been poving this (in an off-and-off-and-off-and-on
manner...) since v2.2, I am obviously not skilled enough to get
photo-quality scenes rendered. Not that I would like to. Getting the perfect
kitchen rendered is not one if my goals, but having a perfectly believable
non-exixting object sitting on top of a table or, better yet, a tiled floor
is what I want. So I guess I do shoot for realism. One day I'll get it, I'm
sure.
Ruy
"Bill DeWitt" <bde### [at] cflrrcom> escreveu na mensagem
to
trees
you
far
other
> side.
people
scenes
Date: 13 Oct 2001 15:31:55
Message: <3bc896ab@news.povray.org>
In article <3bc889f6@news.povray.org> , "Ruy" <ruy### [at] hipernetcombr> wrote:
> sure.
Don't worry.  I never managed to get anything matching those great POV
artists either.  And I have been using POV for years, just never the scene
description langauge... ;-)
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 13 Oct 2001 16:13:50
Message: <3bc8a07e$1@news.povray.org>
"Ruy" <ruy### [at] hipernetcombr> wrote in message
news:3bc889f6@news.povray.org...
perfect
floor
I'm
> sure.
    Well, I wasn't talking about photo-realism. For instance, I have a
continuing project of modeling a microscope. There are some internal gears
that I had to dismantle the microscope to find. But I found them and modeled
them even though it will take a cutaway view to ever see them. Probably
slows down the rendering a lot and certainly slowed down the project.
    But I can't see modeling something and leaving out the working parts.
Probably a psychosis of some sort.
Date: 13 Oct 2001 16:53:17
Message: <3bc8a9bd$1@news.povray.org>
I model small objects from scratch, based on precise measurements from real
life. Because big objects in real life are made up of small objects. I have
a library of small but realistic looking things, that I made myself. Those I
can add to a bigger scene later on. Even on a distance, details should give
a better look. I model the back side of things too, but I try to avoid fully
invisible things, such as internal gear like you mention.
You rarely see me posting images here, first of all because I work a long
time with them, and don't finish anything so often... Secondly because I
recently lost most of my objects in a harddisk crash, so please backup your
things, folks.
Hugo
modeled
Date: 13 Oct 2001 18:38:01
Message: <3bc8c249@news.povray.org>
news:3bc8a07e$1@news.povray.org...
modeled
I see what you mean now, my blunder...
In answer to (what I think is) your real question, I model my scenes in a
way you can render them from any standpont and they would still make sense.
I don't use - to stay on your example - backdrop pictures and other
subterfuges made possible by povray, but not possible in real life.
Actually, I'd love to, but I am way to incompetent in the language to be
able to.Anyway, I'm not that uptight about it, though. Should you take a
cutaway at some of my models, you would fing flaws. My rule of thumb is: if
it will *never*  be visible, don't model it; if there is the slightest
chance that someday it will be rendered in a way that it will be visible, go
ahead and do it.
Ruy
Date: 14 Oct 2001 02:54:46
Message: <3bc936b6$1@news.povray.org>
This is off the topic a bit, but you know what I'd like to see? A microscope
made in POV-Ray, using refraction, that actually works like a real
microscope if you put the camera up to the eyepiece. That'd be cool.
Useless, but cool.
- Slime
> perfect
believable
> floor
> I'm
> > sure.
modeled
Date: 14 Oct 2001 06:50:05
Message: <3bc96ddd$1@news.povray.org>
Just like to add that in schools, they learn not to model anything that
won't be visible or important in the scene / animation they are working at..
In Hollywood, they model what they are asked to model, sometimes one half of
an object and not the other, if it's not going to be used.. And they use
*any* tricks that work.. But it's a matter of purpose.. Art for joy, art as
learning curve, art for money.. I think it's good to try all 3 ways of
working..
Hugo
modeled
Date: 14 Oct 2001 07:42:18
Message: <3bc97a1a@news.povray.org>
Art for money? That'll be the day... :-)
//Mahalis
"Hugo" <hua### [at] post3teledk> wrote in message
news:3bc96ddd$1@news.povray.org...
at..
of
as
> working..
> Hugo
gears
> modeled
parts.
Date: 14 Oct 2001 07:50:30
Message: <3bc97c06@news.povray.org>
> perfect
> floor
> I'm
> > sure.
I was thinking of modelling the engine of my car as well, but considering the
render speed at the moment, I've been thinking of a height-field from a
photograph of an engine - very bad...
But I definitely still want to do the interior. I guess I want to make it seem
as real as possible and I get to know Pov better in the process.
- Nekar
Version: 6.0.282 / Virus Database: 150 - Release Date: 2001/09/25
Date: 14 Oct 2001 09:25:37
Message: <3bc99251$1@news.povray.org>
"Slime" <noo### [at] hotmailcom> wrote in message
news:3bc936b6$1@news.povray.org...
microscope
    When I get mine done, it will do this. You should be able to change the
magnification and focus too.
> That'd be cool.
> Useless, but cool.
    Exactly.
Date: 15 Oct 2001 11:02:36
Message: <3bcafa8c$1@news.povray.org>
<snip>
The vast* majority of my scenes will only work from the set-up camera. I very
rarely model anything that isn't directly viewable. Even visible objects may be
distorted if viewed from other angles. For reflective surfaces, I'll generally
have a textured plane or box for something to reflect, but that's about it...
For an example, see my post to pbi...
That aside, when you render schrodinger's box, is the cat inside it alive or
dead? ;)
* can the majority of a small number of scenes be vast? Hmmm....
Date: 15 Oct 2001 21:07:42
Message: <3bcb885e@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> escreveu na mensagem
news:3bcafa8c$1@news.povray.org...
or
> dead? ;)
Oh, that's an easy one: both.
Date: 15 Oct 2001 21:37:25
Message: <3BCB8F16.F4273D74@geocities.com>
> or
> > dead? ;)
No. Neither.
Jon A. Cruz
http://www.geocities.com/joncruz/action.html
Date: 16 Oct 2001 02:07:21
Message: <3bcbce99@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
or
> dead? ;)
That depends on the state of the box (open/closed), the position of the
camera
and wheter or not a computer can be considered an observer for the purpose
of making quantum wavefroms collapse.
<grin>
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.          Babylon 5 *
* Just think of me as the storm before the calm     Magic: The Gathering*
Date: 16 Oct 2001 04:38:26
Message: <3bcbf202$1@news.povray.org>
"Gail Shaw" <gsh### [at] monotixcoza> wrote in message
news:3bcbce99@news.povray.org...
> camera
So how does bill resolve rendering a closed box if he insists on rendering the
hidden parts?
Date: 16 Oct 2001 08:37:46
Message: <3bcc2a1a$1@news.povray.org>
the
> hidden parts?
    You make some switch/case statements that put a animatable cat in it if
the particle fails to decay, and puts a stiff cat in it if it does decay...
or is that the other way around... Anyway, then you make a random decay
function for the particle.
