POV-Ray : Newsgroups : povray.general : Isosurfaces in v3.5 vs MegaPOV Server Time
23 Oct 2026 18:57:16 EDT (-0400)
  Isosurfaces in v3.5 vs MegaPOV (Message 1 to 8 of 8)
Subject: Isosurfaces in v3.5 vs MegaPOV
Date: 12 Oct 2001 07:49:54
Message: <3bc6d8e2$1@news.povray.org>
Hello again folks,
My prior post was "isosurfaces in v3.5 and how to convert them to
heightfields" and there I mentioned that isosurfaces were slower in Pov3.5
due to the lack of "method 1"... Here is the proof, and I humbly ask the
great people developing Pov to take another look at this and eventually
explain why method 1 was removed from Pov 3.5.
Render times for an isosurface on AMD 1 ghz  (full code below):
MegaPOV 0.7:
 Method 2 = 11 secs
 Method 1 =  2 secs
POV 3.5 beta 5:
 Method 2 = 13 secs
//  ----- The code
#version 3.5;
camera { right -1.33*x up 1*y direction 1*z location <-3,0,6> look_at 0
angle 48 }
light_source { <-25,25,35> color rgb 1.5 }
isosurface { function { (x-.5)*(x-.5)+y*y+z*z-1
     + .001^((x+.5)*(x+.5)+y*y+z*z-.75)
     - .0001^abs((y+.2)*(y+.2)) }
//  method 1  // method 2
     max_gradient 278.219 accuracy .008
     contained_by { box { <-1,-1,-1.5>,<1.25,1,1.5> } }
     pigment { rgb 1 } finish { ambient 0 diffuse .67 specular .1 }
no_shadow }
//  ----- End
Subject: Re: Isosurfaces in v3.5 vs MegaPOV
Date: 12 Oct 2001 09:01:15
Message: <3bc6e99b@news.povray.org>
In article <3bc6d8e2$1@news.povray.org> , "Hugo" <hua### [at] post3teledk> wrote:
Because it did not meet the code quality and functionality requirements for
an officially supported feature.  If you feel comfortable reading source
code go and see for yourself in the MegaPOV source code of method 1 - it is
really obvious what major problems it has.  If you are not a programmer,
please take my answer as is: Any explanation would be very long and
impossible to understand without knowing the source code and how method 1
works.
As for more discussion about this, please consider
Message-ID: <3B94E1CF.7498B010@pacbell.net>
Date: Tue, 04 Sep 2001 07:14:39 -0700
Organization: POV-Ray Technical Assistance Group
Newsgroups: povray.beta-test
Subject: Attention: Beta Testers
Xref: news.povray.org povray.beta-test:4
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 12 Oct 2001 10:04:59
Message: <3bc6f88b$1@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3bc6e99b@news.povray.org...
> works.
Aww, now I'm intrigued and I didn't even care before.... No offence - I'm sure
you're right - but can we code-idiots have the potted-version and decide for
ourselves that it's impossible to understand.... ;)
Date: 12 Oct 2001 10:17:09
Message: <3BC6FCD5.606B819A@pacbell.net>
I think you just got the potted-version answer. Thorsten is not interested in
discussing it further.
Ken Tyler
Date: 12 Oct 2001 10:23:50
Message: <slrn9sdv7n.fml.ron.parker@fwi.com>
>> works.
It'd be nice to be able to make an explanation that means something to code
idiots, but that would require us to have started with code that can be
understood by someone besides the person or people who wrote it.  There were
no comments, the code flow was all over the place through three seperate
modules that had no apparent organization, it had global variables that did
weird things at weird times, and on top of all of that it had been ported
from 3.0 to 3.1 in the most expedient possible way by Yours Truly.
plane{-z,-3normal{crackle scale.2#local a=5;#while(a)warp{repeat x flip x}rotate
z*60#local a=a-1;#end translate-9*x}pigment{rgb 1}}light_source{-9red 1rotate 60
*z}light_source{-9rgb y rotate-z*60}light_source{9-z*18rgb z}text{ttf"arial.ttf"
"RP".01,0translate-<.6,.4,.02>pigment{bozo}}light_source{-z*3rgb-.2}//Ron Parker
Date: 12 Oct 2001 10:32:45
Message: <3bc6ff0d$1@news.povray.org>
"Ron Parker" <ron### [at] povrayorg> wrote in message
news:slr### [at] fwicom...
<snip>
You mean it was a pile of ca-ca (technical expression)?
Why didn't Thorsten just say so... ;)
Date: 14 Oct 2001 10:37:50
Message: <3bc9a33e@news.povray.org>
"Hugo" <hua### [at] post3teledk> wrote..
"Method 2" is valid for any continuous functions (if you use appropriate
max_gradient and accuracy values) while "method 1" is not.
This is the major problem of "method 1".
>MegaPOV 0.7:
> Method 2 = 11 secs
> Method 1 =  2 secs
>POV 3.5 beta 5:
> Method 2 = 13 secs
As discussed in p.b.i,
http://news.povray.org/povray.binaries.images/18925/?ttop=19235&toff=50&mtop
=123788&moff=10
optimization of the function gives us much faster rendering speed
in some cases.
Try following code.
R. Suzuki
//  ----- The code
#version 3.5;
#include "functions.inc"
look_at 0 angle 48 }
     min(
       sqrt((x-.5)*(x-.5)+y*y+z*z
         + .001^((x+.5)*(x+.5)+y*y+z*z-0.75)
         - .0001^abs((y+.2)*(y+.2)))-1,
       f_r(x*0.55,y,z*0.7)*0.35
     max_gradient 3.2 //278.219
     accuracy .008
no_shadow }
//  ----- End
Date: 15 Oct 2001 09:52:31
Message: <3bcaea1f$1@news.povray.org>
Wow, great tricks you introduce here! I am going to take a closer look at
them and see if I can apply them in general to my isosurfaces cause they all
tend to render slower on Pov3.5... I admit, I'm not so skilled in math as I
would like to be.
Hugo
> in some cases.
> Try following code.
> R. Suzuki
