I've been using povray for close to 2 years and I'm having a prolem thats
probably very simple to solve, but can't seem to do it.
I'll create my scene, add lights and camera. when I run it It displays
nothing. I've tried using this code (in 3.1g and 3.5b), and nothing just a
black image. Am i doing something wrong?
location <5, 5, 5>
look_at <0, 0, 0>
light_source {
<45, 35, 25> color 1
sphere {
<0, 0, 0>, 1
color 1
Kevin
Kevin Loney wrote:
> sphere {
> <0, 0, 0>, 1
> pigment {
> color 1
"color 1" is interpretated as color rgbft 1 which makes the sphere
compleatly transparent. Use "color rgb 1" or "color White" instead.
- Micha
"Micha Riser" <mri### [at] gmx net> wrote in message
news:3bc0b2fd$1@news.povray.org...
> Kevin Loney wrote:
> > sphere {
> > <0, 0, 0>, 1
> > pigment {
> > color 1
Or just pigment {rgb 1 }
Or use colors.inc, and then pigment{White}. That's very clear... I
don't understand why people don't use colors.inc more often. I almost
never type "rgb": I'm feel lost finding colors that way.
Jaime Vives Piqueres
http://www.ignorancia.org/
"Jaime Vives Piqueres" <jai### [at] ignorancia org> wrote in message
news:3BC0CA63.153FB729@ignorancia.org...
Funny, I never even use colors.inc anymore. I had a color picker for a
while, but then I got used to rgb and can pretty much type out my color
first or second try. Especially since I rarely want rgb 1 but might want rgb
<1.1, 0.9, 0.9 >
> <1.1, 0.9, 0.9 >
I find it easier to type rgb 1 that it is to type White. Also, you don't
have to spend time typing #include "colors.inc" into every scene file you
make.
Ken Tyler
> make.
There's that, but I have insert menus for that (or did, I am still
working on new ones). Mostly I find "white" or "blue" to -not- be what I
want. I want the box of crayons that have the 63 million colors.
Same here. I am prefectly comfortable describing my own colors as needed.
But that is the beauty of POV-Ray. People can use it anyway they want
and if some people find using colors.inc easier than designing their own
colors then more power to them.
Ken Tyler
I might be tempted by a color select box on the tool bar of the editor.
Something that if you clicked on the one out of 16 or somewhere on the
rainbow box it would then type in "rgb <n.nn, n.nn, n.nn >. But anything
else is just too time consuming for the value returned. I dont' even use the
insert menu pigments becuas it takes longer than typing a rgb value.
Sure, and it is good while learning to do other things.
Oh, well... I never said I use the colors in colors.inc as they are!
;) I use them as a palette of known colors to mix. It is easy for me to
think on something like "White*.9+Red*.1" when a I want a light pink. I
don't care if it's longer and I don't mind typing '#include
"colors.inc"': it is worth for me.
For me colors.inc is a gift from god!
As I am colour blind, I feel much more confortable with Turquoise than rgb
stuff.
In any case I have absolutly no opinion on the result!
Chaps
news:3BC15D57.1B966040@ignorancia.org...
> La Persistencia de la Ignorancia
Always the first line I ever type in a POV scene, whatever it is, is
'#include "colors.inc"'. If I don't like a color, I guess what its rgb value
is and fiddle it a bit.
"Chaps" <cha### [at] yahoo com> wrote in message
news:3bc18328@news.povray.org...
> stuff.
> Chaps
I
"Mahalis" <don### [at] fakey com> wrote in message
news:3bc1ac1e@news.povray.org...
value
I haven't ever checked, but isn't there a parse time hit for including
unused files? In a lengthy animation it probably makes a difference.
The problem appears to be the use of "color 1." The keyword "color" is an
artifact of an earlier version of POV-Ray. You might want to consider using
"rgb 1" or "rgb <1,1,1>" (without the quotes, of course) in its place.
> value
On a 386 with 4 megs of memory it was a problem. With modern machines
the impact is not a consideration.
Ken Tyler
On a PII 400, rendering 256 frames of a sphere with and without
colors.inc.
6m 23s with
6m 15s without
Probably have to be several large includes on very many frames for it to
be a consideration.
How this?
I wouldn't define the keyword "color" an artifact. The problem here is
simply that color 1= color rgbft 1 so that the object is completely
transparent.
Jonathan.
JRG wrote:
> How this?
> transparent.
Allow me to clarify my remarks. Up until POV-Ray 2.2, I believe, the
"color" keyword was required when creating a color definition. Since this
is no longer the case, the keyword, in povese, has been deprecated.
Are you saying that every time I wrote #declare gold = color rgb <1,.6,.2>;
I was wasting my time? Oh my god... and I'm still alive?
Yet I wouldn't define it an *artifact*. Obsolete syntax is a better
definition IMO.
Jonathan.
"Dave Dunn" <poi### [at] aol com> ha scritto nel messaggio
news:3BC20A9D.1D678E1C@aol.com...
> JRG wrote:
> > How this?
> > transparent.
<1,.6,.2>;
Only in that <1,.6,.2> is a horrid gold.
But bear in mind the following thing:
pigment { color rgb 1 }
pigment { rgb 1 }
pigment { color 1 }
all work (although differ), but
pigment { 1 }
does not.
So you can't really say the 'color' keyword is no more required in all
cases.
Also it isn't deprecated since that would mean it is suggested to no more
use it.
Christoph Hormann <chr### [at] gmx de>
This is not true with the right finish.
In fact most of my gold textures use this pigment.
"Bill DeWitt" <bde### [at] cfl rr com> ha scritto nel messaggio
news:3bc210d6@news.povray.org...
> <1,.6,.2>;
On Mon, 08 Oct 2001 16:20:45 -0400, Dave Dunn wrote:
>JRG wrote:
>> How this?
>> transparent.
Not true. See what happens when you try skipping it in a colour_map.
(though it's true that it's an artifact of some sort: everyone knows that
the proper way to spell it is with the U, as it's spelled in the POV source.)
#macro R(L P)sphere{L __}cylinder{L P __}#end#macro P(_1)union{R(z+_ z)R(-z _-z)
R(_-z*3_+z)torus{1__ clipped_by{plane{_ 0}}}translate z+_1}#end#macro S(_)9-(_1-
_)*(_1-_)#end#macro Z(_1 _ __)union{P(_)P(-_)R(y-z-1_)translate.1*_1-y*8pigment{
rgb<S(7)S(5)S(3)>}}#if(_1)Z(_1-__,_,__)#end#end Z(10x*-2,.2)camera{rotate x*90}
"JRG" <jrg### [at] hotmail com> wrote in message
news:3bc21193@news.povray.org...
If I label my jokes no one falls for them.
Indeed.
#macro R(L P)sphere{L F}cylinder{L P F}#end#macro P(V)merge{R(z+a z)R(-z a-z)R(a
-z-z-z a+z)torus{1F clipped_by{plane{a 0}}}translate V}#end#macro Z(a F T)merge{
P(z+a)P(z-a)R(-z-z-x a)pigment{rgbf 1}hollow interior{media{emission 3-T}}}#end
Z(-x-x.2x)camera{location z*-10rotate x*90normal{bumps.02scale.05}}
"Bill DeWitt" <bde### [at] cfl rr com> escribió en el mensaje
news:3bc0e12a$1@news.povray.org...
editor.
the
You can try DotColor3.0 (it's freeware) in colour mixer mode to get the
exact colour with the exact rgb values .
Maybe you can find it useful.
this is the link:
http://www.inetis.com/freeware.asp
Txemi Jendrix
tji### [at] euskalnet net
http://www.geocities.com/txemijendrix
