POV-Ray : Newsgroups : povray.general : 3ds to pov to obj Server Time
3 Nov 2026 20:22:20 EST (-0500)
  3ds to pov to obj (Message 1 to 17 of 17)
Subject: 3ds to pov to obj
Date: 12 Sep 2001 13:19:57
Message: <3b9f993d@news.povray.org>
Does anyone know a good and free
program with that I can convert
3ds to pov
and a program that does
convert obj to pov files?
Both should convert to mesh2 with uv coordinates
and smooth triangles intact.
Subject: Re: 3ds to pov to obj
Date: 12 Sep 2001 17:19:13
Message: <3b9fd151@news.povray.org>
Try 3DWin:
http://www.stmuc.com/thbaier/
or Crossroads:
http://home.europa.com/~keithr/crossroads/
www.mp3.com/FeedingTheCats
www.btinternet.com/~manhog/
Date: 13 Sep 2001 11:21:13
Message: <3ba0cee9$1@news.povray.org>
3DWin is shareware, but it does what it should do.
The non-registered version doesn't translate materials and the
texture-mapping.
I did register.
"Alan Holding" <man### [at] btopenworldcom> wrote in message
news:3b9fd151@news.povray.org...
> Try 3DWin:
> or Crossroads:
Date: 13 Sep 2001 14:17:11
Message: <3ba0f827$1@news.povray.org>
Thanks.
I'll try it. But somewhere on the site they say that
the export of the demo version may miss every
5th vertex
stefkeB <ste### [at] hotmailcom> schrieb in im Newsbeitrag:
3ba0cee9$1@news.povray.org...
> texture-mapping.
> I did register.
> > Try 3DWin:
> > or Crossroads:
Date: 14 Sep 2001 03:28:19
Message: <3ba1b193@news.povray.org>
Simon wrote in message <3ba0f827$1@news.povray.org>...
>Thanks.
>5th vertex
Note the word "may".  In my (admittedly limited (two files)) experience, it
doesn't do this.
Mark
Date: 29 Sep 2001 17:21:41
Message: <3bb63b65$1@news.povray.org>
What's the .POB format 3DWin uses for POV Ray files?
> Try 3DWin:
> or Crossroads:
Date: 29 Sep 2001 18:05:17
Message: <3BB646DA.6F8FC2C4@pacbell.net>
It is an extinct binary format not worth thinking about.
Ken Tyler
Date: 29 Sep 2001 18:41:10
Message: <Xns912C6FB22E95seed7@povray.org>
Digital archeology, the business of the future?
Ingo
Date: 29 Sep 2001 23:21:31
Message: <3bb68fbb@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3BB646DA.6F8FC2C4@pacbell.net...
> Ken Tyler
Then how do I use 3DWin to convert from POV? (Unless I am using an older
version and the new version uses .POV files instead!)
Date: 29 Sep 2001 23:54:22
Message: <3BB698AC.B3A31240@pacbell.net>
> > Ken Tyler
Are you looking for a converter to convert from POV-Ray to another
file format? If so stop looking. There is none.
Ken Tyler
Date: 1 Oct 2001 10:05:55
Message: <3bb87843$1@news.povray.org>
hmm... so maybe we're not talking digital archaeology here
but digital astronomy instead...  a big dark hole that sucks
in any format that comes near it, emitting nothing but the
mysterious and puzzling mind-rendering pov rays.   ;-)
miker
Date: 1 Oct 2001 11:06:36
Message: <3bb8867c$1@news.povray.org>
"MR" <a### [at] bnet> wrote in message news:3bb87843$1@news.povray.org...
The problem, as I understand it, is that POV scene-files do not (generally) just
list a series of primitives with simple csg. Most pov files contain macros and
other constructs that would defeat any rational process of conversion.
Converting such a scene would essentially require rendering the scene and then
applying some form of tesselation to the scene-objects. Not really practicle.
Most modelling packages output meshes or similiar which are relatively trivial
to convert.
Date: 1 Oct 2001 11:59:37
Message: <3BB892C7.A451C8BE@scifi-fantasy.com>
> (generally) just list a series of primitives with simple csg.
> Most pov files contain macros and other constructs that would
Macros?  This is something I myself am unfamiliar with, so.
Why can't you convert .pov file that just has primitives/csg
to another format?
...of course, why would you want to use anything other than
POV...;)
Tim Cook
Version: 3.12
Date: 1 Oct 2001 12:10:02
Message: <3BB89615.7E319E8@gmx.de>
> to another format?
> POV...;)
See:
http://www.students.tut.fi/~warp/povVFAQ/filesVFAQ.html#povtootherformatsdifficulty
You could of course define a restricted subset of the POV language for
conversion, but such a converter would not be of much practical use.
Date: 1 Oct 2001 21:50:23
Message: <3BB91EA6.6EEBAA8D@pacbell.net>
> to another format?
Just to illustrate how difficult it would be let's look at just some
of the many ways to describe a simple sphere object. Each of these
will accomplish the exact same thing yet the syntax used will vary -
//traditional
sphere{<1,1,1>,1 pigment{rgb 1}}
// Another
sphere{x+y+z,1 pigment{rgb 1}}
//Yet another
#declare a=x*1;
#declare b=y*1;
#declare c=z*1;
#declare d=1;
#declare My_Sphere = sphere{a+b+c,d}
object{My_Sphere pigment{rgb 1}}
//and one last one
#declare My_Vector = <1,1,1>;
sphere{My_Vector,1 pigment{rgb 1}}
Each of the above examples are perfectly valid and illustrate the
various types of POV-Ray scene file coding in practice today. A
pov2xxx conversion program would have to be able to recognize
each of those varations and decide what to do with them. That is
just the beginning. Then, since POV-Ray objects are mathematical
representations, they would have to be tesselated into a triangle
based or similar system, that most other 3D file formats use. Do
you start to see some of the practical problems involved ?
Ken Tyler
Date: 1 Oct 2001 22:44:23
Message: <3BB929EB.6BEE933C@scifi-fantasy.com>
Hmm.  Yeah, that is a challenging thing.  But...pov can parse
each of the things, and there are already-existing tesselations
for spheres-to-triangles (it's what those other, wimpier 3d
modellers like 3d studio use).  So it's not impossible, nor
terribly unfeasable...pov IS open source, ain't it?  So the
parsing code is already available.
...but then, you're not allowed to use pieces of POV in
other software.  Ok, so much for that idea.
Tim Cook
Version: 3.12
Date: 1 Oct 2001 23:55:50
Message: <3BB93C0D.495DBD50@pacbell.net>
Quite.
>  But...pov can parse
Ah, but POV-Ray is not "open source". The source is provided for
educational purposes and so that you can make modifications to
it for your own edification and enjoyment. Redistribution has
strict rules that must be adhered to which limits for what
you suggest here.
Bingo! If you could strip out the front end language parser
then you will have won a major part of the battle. In fact
nothing is preventing you from doing that for your own private
use. However you would not be able to redistribute it so the
time spent might not be worth the effort from a community
point of view.
Ken Tyler
