POV-Ray : Newsgroups : povray.general : Minor change request for Pov? Server Time
23 Aug 2025 22:07:41 EDT (-0400)
  Minor change request for Pov? (Message 1 to 7 of 7)
Subject: Minor change request for Pov?
Date: 7 Sep 2001 12:42:01
Message: <3b98f8d9@news.povray.org>
Hmm, I find the default quickres.ini a bit restrictive, I prefer to have
various sizes and aspect ratios (ie square, 4x3, 3x2, 16x9, 2x1 etc).
Perhaps it could be modified to support more ratios?  That being the case,
the little window in POV-Win that shows the current selection would have to
be larger, so you could see the full description...
...Chambers
Subject: Re: Minor change request for Pov?
Date: 7 Sep 2001 13:15:17
Message: <3b9900a5@news.povray.org>
"Ben Chambers" <bdc### [at] hotmailcom> wrote in message news:3b98f8d9@news.povray.org...
I'm sure you can manage to do this ... try hitting the 'edit' button on the
render settings dialog.
ummmmm ... what's so hard about dragging the window wider, that we should have
to code a solution for you ?
-- Chris
Date: 7 Sep 2001 21:32:35
Message: <3B99761A.E95D7652@pacbell.net>
> -- Chris
A bit of advice...
People should ask if something is possible before putting in a feature request.
Ken Tyler
Date: 8 Sep 2001 21:05:05
Message: <3b9ac041@news.povray.org>
"Ken" <tyl### [at] pacbellnet> wrote in message
news:3B99761A.E95D7652@pacbell.net...
have
case,
the
Of course I can (and do) edit my own, I was referring to the one that comes
with POV by default.
have to
should have
> > -- Chris
Well, I'm so used to MS apps that I didn't realize you could resize the
combo-box... Sorry <g>
> A bit of advice...
request.
> Ken Tyler
Point taken.
...Chambers
Date: 9 Sep 2001 04:04:09
Message: <3b9b2278@news.povray.org>
Ben Chambers <bdc### [at] hotmailcom> wrote:
: Well, I'm so used to MS apps that I didn't realize you could resize the
: combo-box... Sorry <g>
  There are many MS apps where the same feature is used. For example in IE
you can change the length of the address field
Date: 9 Sep 2001 13:39:45
Message: <3b9ba961@news.povray.org>
news:3b9b2278@news.povray.org...
Boy, do I feel sheepish <g>  Don't know how I missed that one...
...Chambers
Date: 10 Sep 2001 01:41:02
Message: <3b9c526e@news.povray.org>
In fact this is a standard ability of the 'rebar' common control. Any windows
standard control placed into a rebar band (like the combobox in our case) will
automatically be resized to the size of the band (which means that if the band
is resizable, so is the control).
-- Chris
