POV-Ray : Newsgroups : povray.general : PNG And Transparency. Server Time
23 Aug 2025 00:59:01 EDT (-0400)
  PNG And Transparency. (Message 1 to 7 of 7)
Subject: PNG And Transparency.
Date: 14 Aug 2001 12:22:45
Message: <3b795055@news.povray.org>
Dear All,
    I have searched the new Web newsgroup interface, which is very nice, but
I still can't find
what I'm looking for.
    I am creating some images using text objects in black and white. I would
like to find some way
of creating a PNG file which when loaded into a browser displays the white
as transparent. Is this
possible ? I am using 5 bit per colour PNG output file format and my first
attempt used a background
set to rgbt <1.0,1.0,1.0,1.0> but this did not work. I realise that various
browsers have varying
degrees of support for PNG but is there a way which should theoretically
work ??
    Nigel.
Subject: Re: PNG And Transparency.
Date: 14 Aug 2001 13:47:19
Message: <3B79649E.1AA23BCE@chesapeake.net>
Maybe one of the graphics programs (ie PSP,GIMP....) can save the
image in the correct format with the alpha channel set to white.
"nigel.warner" wrote:
> Dear All,
> I still can't find
> work ??
>     Regards,
>     Nigel.
Date: 14 Aug 2001 18:58:28
Message: <3b79ad14@news.povray.org>
The PNG format doesn't use a "this color is transparent" value like GIF
does (at least I have never heard of that).
  What PNG uses is a full alpha channel, that is, you can specify an amount
of transparency for each pixel (regardless of its color).
  For example POV-Ray can output PNGs with alpha channel transparency (using
the +UA command line parameter; when a camera ray doesn't hit anything, it's
marked as transparent).
  Now the bad news: No web browser that I know of supports PNG transparency
correctly. So until they do, you'll have to use GIFs.
Date: 17 Aug 2001 00:28:35
Message: <3b7c9d73$1@news.povray.org>
PSP v7 supports either alpha channel or "pick a color" transparency for PNG.
Jim
Date: 17 Aug 2001 05:22:46
Message: <3b7ce266@news.povray.org>
Jim Kress <dea### [at] kressworkscom> wrote:
: PSP v7 supports either alpha channel or "pick a color" transparency for PNG.
  But how does it save the transparent color into the PNG file? Does it just
save it as an alpha channel (and the "pick a color" is just a tool to create
automatically the alpha channel)?
Date: 17 Aug 2001 07:48:48
Message: <3B7D04A5.F619E35@sycomore.fr>
From http://www.w3.org/TR/REC-png, section 2.4:
" Transparency control is also possible without the storage cost
of a full alpha channel. In an indexed-color image, an alpha
value can be defined for each palette entry. In grayscale and
truecolor images, a single pixel value can be identified as
being "transparent". These techniques are controlled by the
tRNS ancillary chunk type. "
Adrien Beau - adr### [at] freefr - http://adrien.beau.free.fr
 Mes propos n'engagent que moi et en aucun cas mes employeurs
Date: 17 Aug 2001 09:33:27
Message: <3b7d1d27@news.povray.org>
Adrien Beau <adr### [at] sycomorefr> wrote:
: In an indexed-color image, an alpha
: value can be defined for each palette entry.
  Well, this is just a palette with alpha channel (ie. 4 color components).
: In grayscale and
: truecolor images, a single pixel value can be identified as
: being "transparent".
  Ok, this I didn't know.
