POV-Ray : Newsgroups : povray.general : fillet? Server Time
23 Aug 2025 00:58:55 EDT (-0400)
  fillet? (Message 1 to 4 of 4)
Subject: fillet?
Date: 8 Aug 2001 18:14:58
Message: <3b71b9e2@news.povray.org>
Hello,
is-it possible with Pov:
 -- to round the corners of a solidn(3D fillet)? ;
 -- to sweep a template along a path? ;
 -- to join two closed shapes to produce a solid?
Thanks
Subject: Re: fillet?
Date: 8 Aug 2001 19:15:43
Message: <chrishuff-E3706B.18130508082001@netplex.aussie.org>
In article <3b71b9e2@news.povray.org>,
With some shapes this is fairly easy, for example using a CSG of
spheres, cylinders, and boxes to make a rounded box. Macros have been
written for some objects...boxes, cylinders, and cones mainly.
Check out the prism object, it might do what you want. You can't use a
curved path though, unless you use an external editor to create a mesh
or code it yourself...you could write a macro that generates a mesh of
the sweep. This would be a lot easier to do in MegaPOV using the spline
patch, but would still require a lot of coding. And of course a mesh
will take up more memory, and you might have to use a very high-res mesh
to make the individual triangles invisible...you will probably spend a
lot of time parsing.
Uh, how about "union {}"? Or "merge {}" if you want to remove interior
surfaces.
Or were you talking about making solid shapes out of non-solid shapes,
like bezier patches? That isn't possible, sorry. MegaPOV can use solid
meshes, but that's it.
Christopher James Huff - chr### [at] maccom, http://homepage.mac.com/chrishuff/
Date: 8 Aug 2001 23:20:47
Message: <3B720201.E0193DA7@pacbell.net>
> the sweep.
A publically available macro has been written with this in mind
http://members.nbci.com/dvarrazzo/epov.htm
Ken Tyler
Date: 9 Aug 2001 17:03:35
Message: <3B72F893.58FE8F5@faricy.net>
Sylvax wrote:
> Hello,
http://davidf.faricy.net/povre.html#macros_shape
