POV-Ray : Newsgroups : povray.general : Gravity Well simulation? Server Time
4 Nov 2026 00:08:43 EST (-0500)
  Gravity Well simulation? (Message 1 to 13 of 13)
Subject: Gravity Well simulation?
Date: 28 May 2001 10:22:54
Message: <3b125f3e$1@news.povray.org>
I want to make an animation that shows how planets look in one of those
diagrams that show the gravity well as a flat surface that is dented where
the planets lay on it. I hope to make it look like spongy rubber instead of
a grid, maybe a mesh, but I can't imagine calculating all the points as the
pieces move...
    Any ideas gratefully accepted.
Subject: Re: Gravity Well simulation?
Date: 28 May 2001 10:31:03
Message: <3b126127@news.povray.org>
"Bill DeWitt" <bde### [at] cflrrcom> wrote in message
news:3b125f3e$1@news.povray.org...
> pieces move...
I think that if you have the formula and can do isosurfaces, you could just do
an isosurface using the formula of the gravity well. Hmm, come to think of it, I
wonder what the formula that Gail posted in p.o-t. would look like as an
isosurface.
/* Nekar Xenos */#local N=<-20,40,100>;#local K=<20,-40,100>;#local R=seed(0);
blob{#while((K-N).x>0)#local X=N;#local N=N+<rand(R),rand(R),1>/3;#local N=(
vlength(N-K)<vlength(X-K)?N:2*X-N);sphere{<N.y,-N.x,N.z>,1,1 scale .02}sphere{N
,1,1 scale.02}sphere{<-N.x-40,N.y,N.z>1,1 scale.01}sphere{<N.x+40,-N.y,N.z>1,1
scale.01 }#end pigment{rgbt 1}interior{media{emission <2,4,5>*5}}hollow}
Date: 28 May 2001 10:38:33
Message: <3b1262e9@news.povray.org>
those
of
the
> pieces move...
how about using a cloth sim (or patch) - i think it will do it
PGP Public Key
Date: 28 May 2001 10:41:11
Message: <3b126387@news.povray.org>
Bill DeWitt <bde### [at] cflrrcom> wrote in message
those
of
the
> pieces move...
As a surface, I have no idea, but you could use splines and create
parallel lines, kinda like in the image Tor Olav Kristensen posted
on 22 Nov 2000, titled "Iso-sombrero (78KB)" (But without the
underling surface)
Would probably work fairly well for a still, as for animating it
<shudder>
Gail
* gsh### [at] monotixcoza                *   Step into the abyss,           *
* http://www.rucus.ru.ac.za/~gail/   *   and let go.        Babylon 5   *
* The difficult we do immediately, the impossible takes a little longer *
Date: 28 May 2001 10:47:20
Message: <3b1264f8$1@news.povray.org>
news:3b1262e9@news.povray.org...
> those
where
> of
> the
> > pieces move...
    I haven't been able to play with that yet. I followed the link to the
Windows version and it never loaded the page.
    I'm thinking Iso-Surface. Each planet should be a spot where the minus Y
is less and less for x and z. If done right you could load planets into a
macro that would write in how many planets and their masses...
    I am working on it, but my math is usually not up to such tasks...
Date: 28 May 2001 10:48:21
Message: <3b126535$1@news.povray.org>
just do
    Right, for me the problem usually is working the formula into the
isosurface...
Date: 28 May 2001 10:50:40
Message: <3b1265c0$1@news.povray.org>
> underling surface)
> <shudder>
    That -would- be scary...
Date: 28 May 2001 11:06:22
Message: <3b12696e@news.povray.org>
news:3b1264f8$1@news.povray.org...
Same here.
Date: 28 May 2001 11:11:20
Message: <3B126ADF.F8F2BA50@gmx.de>
Maybe try it again, my page was not available yesterday, but it should
work again now, just the counter is broken, i hope that will be OK by
tomorrow too.
Date: 28 May 2001 12:39:49
Message: <3b127f55@news.povray.org>
I've made a start using isosurfaces. Here's the relevant portion...
#declare POSX = sin(clock*(pi*2))*5;
#declare POSZ = cos(clock*(pi*2))*5;
#declare Well1=function{sqr(-y)*(x^2+z^2)-5 }
#declare Well2=function{sqr(-y)*((x+POSX)^2+(z+POSZ)^2)-0.5 }
  isosurface{
      function { -y&Well1&Well2 }
Date: 28 May 2001 12:47:23
Message: <3b12811b$1@news.povray.org>
Hi Bill!
I never used Isosurface before, nor Megapov but what about:
#local Sun = function(SunMass/(max((x-SunPosx)*(x-SunPosx)+
(z-SunPosz)*(z-SunPosz),1/hole_deep)))
isosurface {
 funcition {y+Sun[+Earth]}
just insert a Povrayunit equalent Sunmass and SunPos, do the same for
earth and so on.
hole_deep keeps the isosurface from getting infinit at the exact
points of the
pointmasses. Define somewhat 100.
its from the formular
F = G*m1*m2/R^2
That is the force between to pointmasses. G is the gravityconstant
cukk
Date: 29 May 2001 14:16:11
Message: <3b13e76b$1@news.povray.org>
"KalleK" <kal### [at] gmxde> wrote in message news:3b12811b$1@news.povray.org...
> Hi Bill!
> isosurface {
    This seems to be working... and you say you never worked with
isosurfaces before?
Date: 30 May 2001 10:28:07
Message: <3b150377@news.povray.org>
> isosurfaces before?
Yes. I downloaded MegaPov 0.6 sometimes, let all so examples render,
but then leave aside, waiting for 3.5 ...
Now I took a look at some isopovcode to get to know the system of
function. Some trail and error, and here it goes. When I rendered the
scene, there were some artefacts (unlighted areas), but I thought that
would be normal - accuracy problem.
cukk
