POV-Ray : Newsgroups : povray.general : question Server Time
25 Oct 2026 03:13:06 EDT (-0400)
  question (Message 1 to 7 of 7)
Subject: question
Date: 26 Apr 2001 10:54:21
Message: <3ae8369d$1@news.povray.org>
I came across this code and have on question. If the xcounter and zcounter
are identical, why can't they be interchanged in the translate statement?
The image changes dramtically if I substite "zcounter" for "xcounter" or
vice versa, yet the "declare statements seem to do exactly the same thing.
Any clues?
thanks much,
Dennis
 location <0,3,-3>
 look_at <2,0,3>
light_source {
 <100,50,-100>
 color rgb 1
#declare r1 = seed(13);
#declare xcounter = 0;
#while (xcounter < 50)
#declare zcounter = 0;
#while (zcounter < 50)
box {<-.25,-.25,-.25>, <.25,.25,.25>
 translate <xcounter,rand(r1),zcounter>   // rand(r1)
 pigment { color rgb <1,1,1> } finish {metallic}}
#declare zcounter = zcounter + 1;
#declare xcounter = xcounter + 1;
dhm### [at] mediaonenet
www.casdn.neu.edu/~dmiller
Subject: Re: question
Date: 26 Apr 2001 11:14:17
Message: <3ae83b49@news.povray.org>
"Dennis Milller" <dhm### [at] mediaonenet> wrote in message
news:3ae8369d$1@news.povray.org...
They're recursive (?).
The two "while" loops mean they increase at different rates. Additionally, z
repeats for each increment of x.
You can swap them, but you have to swap all references to them.
Date: 26 Apr 2001 12:01:08
Message: <3AE84662.479188F9@gmx.de>
No, just nested.
Recursion would be a macro calling itself for example.
Date: 26 Apr 2001 12:28:54
Message: <chrishuff-155A75.11261926042001@news.povray.org>
In article <3ae8369d$1@news.povray.org>, "Dennis Milller"
Because they are *not* identical. Indenting the code properly makes it
clearer:
The zcounter loop is completely independant of the xcounter loop, and
loops from 0 to 49 *every time the xcounter loop goes through one loop*.
The outer loop runs through 50 times, and for each loop the inner loop
gets reset and runs through again.
This has the effect of zcounter going from 0 to 49 while xcounter = 0,
then again while xcounter = 1, and so on. They start out and end at the
same values, but change at different times and rates.
Christopher James Huff
Date: 26 Apr 2001 12:35:58
Message: <3AE84EEF.C9D3B87F@lbl.gov>
> Any clues?
> #end
> #end
you can't interchange them, because of the call to the
random-function...
if you interchange the xcounter and zcounter in the translate statement,
you are going to mirror your image on the x=z plane.
(e.g. if you compare the boxes with xcounter==zcounter in the two images
you will notice that they didn't change).
HTH
	ARUN
Date: 26 Apr 2001 20:19:10
Message: <3ae8bafe@news.povray.org>
Ah, I see. So z is happening "inside" x in fact. That makes perfect sense.
Thanks very much.
D.
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-155A75.11261926042001@news.povray.org...
zcounter
statement?
thing.
> clearer:
>     #end
> #end
> Personal: chr### [at] maccom, http://homepage.mac.com/chrishuff/
> TAG: chr### [at] tagpovrayorg, http://tag.povray.org/
Date: 27 Apr 2001 04:12:52
Message: <3ae92a04@news.povray.org>
news:3AE84662.479188F9@gmx.de...
> No, just nested.
Ah - I knew it was the wrong word (hence the "?") - thanks.
