POV-Ray : Newsgroups : povray.general : Real-time raytracing... Server Time
25 Oct 2026 03:58:32 EDT (-0400)
  Real-time raytracing... (Message 1 to 18 of 18)
Subject: Real-time raytracing...
Date: 1 Apr 2001 10:58:43
Message: <3ac74223@news.povray.org>
I was just looking at some of the real-time raytracing demos at
http://www.acm.org/tog/resources/RTNews/demos/overview.htm and I was
wondering: why can't POV-Ray be that fast?
cu!
ZK
http://www.povplace.be.tf
Subject: Re: Real-time raytracing...
Date: 1 Apr 2001 11:17:09
Message: <3AC74676.82F845AD@gmx.de>
If you restrict a raytracer to a very basic functionality (like only
certain highly optimized shapes) you can gain a major speedup.
Furthermore these programs use direct access to the graphics hardware and
probably integer arithmetic for their calculations.
Date: 2 Apr 2001 07:23:54
Message: <3ac8614a@news.povray.org>
  Because povray doesn't model just spheres and cylinders without textures.
  To get a decent scene you need lots of primitives and complicated textures,
lighting algorithms and so on.
  The reason is the same why 3DStudio is not a real-time renderer even
though games draw similar images in real-time.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 2 Apr 2001 10:04:19
Message: <3ac886e3@news.povray.org>
textures.
textures,
a couple of those on the site do feature proc textures, a variety of shapes
and simple csg animations.
however these raytracers are very highly optomised to just the scenes the
demo shows, and there is often a pixel doubling routing on the go to blow
the real time rendered output (anything from 160x80 - 320x240) up full
screen
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 2 Apr 2001 19:03:52
Message: <3ac90558@news.povray.org>
tnx for your answers...
Still, I think POV-Ray should be made much faster than it currently is :)
cu!
ZK
Date: 2 Apr 2001 19:23:49
Message: <3ac90a05$1@news.povray.org>
Strange, I find POV-Ray much faster now than it was a couple of years ago...
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in message
news:3ac90558@news.povray.org...
> cu!
> ZK
Date: 2 Apr 2001 20:04:59
Message: <3AC91328.D406B71B@via.ecp.fr>
So do I : I remember it would take a whole night to render a simple
stone cup at 320x200 on my old Atari STe :)
JM
Date: 2 Apr 2001 20:12:31
Message: <d75ictcigan6ailco8jf11v54bt7gg94eg@4ax.com>
  The solution is simple - you need a faster computer for POV-Ray. As a side
benefit, your secondary applications will also perform better ;)
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 2 Apr 2001 22:08:12
Message: <slrn9cic31.c24.ron.parker@fwi.com>
Feel free to contribute some fixes that make it so.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 3 Apr 2001 01:06:13
Message: <3ac95a45$1@news.povray.org>
In article <3ac74223@news.povray.org> , "Zeger Knaepen"
It can.  You just have to remove the parsing stage for every frame.  You
can do this either by constructing objects manually in memory or by
parsing once and then manipulating the objects directly.  It is
possible, not too much work and you get a decent frame rate on an
average system.  However, you should reduce max trace level to two or
three.
Just be aware which options you have to turn off because they assume a
static scene and do break real-time manipulation of the scene if you
don't fix them on the fly, too.  For example the vista buffer or object
bounding.
      Thorsten
Date: 3 Apr 2001 02:06:53
Message: <3ac9687d@news.povray.org>
Can you post a sample? This sounds plausible, so it would be nice to see it
work  =)
Nekar
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3ac95a45$1@news.povray.org...
> three.
> bounding.
>       Thorsten
Date: 3 Apr 2001 06:52:07
Message: <3ac9ab57$1@news.povray.org>
uhm, I'm not a programmer :)
But I was wondering about something..  Can someone explain me how exactly
that bounded_by-stuff works?  If  I'm right, the raytracer first checks if a
ray intersects with the bounded_by-object using a simple form of raytracing
itself.  Couldn't that be made faster by first doing a scanline rendering of
the bounded_by-objects, and then only raytracing the pixels that are inside
those objects?  Of course it would have it limitations, like you can't use
spheres for bounded_by-objects, and it will only work with the
default-camera-type (perspective or whatever it's called), but I think it
would be a little bit faster...
Well, I don't know.  I'm not a programmer, so it might be a real stupid
id...
cu!
ZK
Date: 3 Apr 2001 07:04:52
Message: <3AC9AE55.824C6B21@gmx.de>
> id...
That's about what the vista buffer does IIRC.
Bounding generally works with boxes, because they are quite fast to
compute.  Manual bounding using bounded_by{} is only useful in certain
cases like complex CSG or hierarchical bounding of unions.
Date: 3 Apr 2001 11:10:26
Message: <3ac9e7e2$1@news.povray.org>
So, how does it work with other camera_types?
cu!
ZK
Date: 3 Apr 2001 11:17:16
Message: <slrn9cjqbu.cka.ron.parker@fwi.com>
The short answer is that it doesn't.  From the docs:
  The vista buffer is created by projecting the bounding box hierarchy onto
  the screen and determining the rectangular areas that are covered by each
  of the elements in the hierarchy. Only those objects whose rectangles
  enclose a given pixel are tested by the primary viewing ray. The vista
  buffer can only be used with perspective and orthographic cameras because
  they rely on a fixed viewpoint and a reasonable projection (i. e. straight
  lines have to stay straight lines after the projection).
Date: 3 Apr 2001 13:19:04
Message: <3aca0608$1@news.povray.org>
ok, tnx :)
onto
each
because
straight
ZK
Date: 3 Apr 2001 14:45:08
Message: <3aca1a34$1@news.povray.org>
In article <3ac9687d@news.povray.org> , "Nekar Xenos"
> work  =)
You have the sample code already.  Just look into the file povray.c in
the source distribution.  Follow it through once and call all the init
code.  Then just change the function FrameRender (povray.c) and merge it
with a modified version of function Start_Non_Adaptive_Tracing
(render.c) or call trace_pixel directly.  It is really easy and there is
not much work needed at all.  For example, take all the code and then
you should get an order like this:
 COLOUR col;
 init_vars();
 // build your scene here
 Initialize_xxx
 Initialize_Renderer();
 for(y...)
  for(x...)
   trace_pixel(x, y, col); // col contains the colour of the pixel
 Deinitialize_xxx
To find out how to construct objects manually, just take a look into the
Create_xxx (xxx = object name) methods in the individual source files.
For example, this creates a point light source:
 LIGHT_SOURCE *gLight;
 // light_source
 //  <-100, 80, -100>
 //  color rgb 1.2
 gLight = Create_Light_Source();
 Make_Vector(gLight->Center, -100.0, 80.0, -100.0);
 Make_Colour(gLight->Colour, 1.2, 1.2, 1.2);
 Post_Process((OBJECT *)gLight, NULL);
 Link_To_Frame((OBJECT *)gLight);
You can manipulate the light source easily by changing its center.
As for everything else, well, now you know how to get started - most of
the fun with POV-Ray is playing around with the source code :-)
      Thorsten
Date: 3 Apr 2001 18:08:44
Message: <3ACA493B.16F65F69@skynet.be>
BTW, I'd like to ask : why is the focal_blur only availiable in the
"perspective" camera ?  From the general principle of blur
oversampling, I can't figure why, but maybe I miss something...
Fabien.
