POV-Ray : Newsgroups : povray.general : Real-time raytracing... Server Time
23 Aug 2025 14:48:44 EDT (-0400)
  Real-time raytracing... (Message 1 to 10 of 18)
Subject: Real-time raytracing...
Date: 1 Apr 2001 10:58:43
Message: <3ac74223@news.povray.org>
I was just looking at some of the real-time raytracing demos at
http://www.acm.org/tog/resources/RTNews/demos/overview.htm and I was
wondering: why can't POV-Ray be that fast?
cu!
ZK
http://www.povplace.be.tf
Subject: Re: Real-time raytracing...
Date: 1 Apr 2001 11:17:09
Message: <3AC74676.82F845AD@gmx.de>
If you restrict a raytracer to a very basic functionality (like only
certain highly optimized shapes) you can gain a major speedup.
Furthermore these programs use direct access to the graphics hardware and
probably integer arithmetic for their calculations.
Date: 2 Apr 2001 07:23:54
Message: <3ac8614a@news.povray.org>
  Because povray doesn't model just spheres and cylinders without textures.
  To get a decent scene you need lots of primitives and complicated textures,
lighting algorithms and so on.
  The reason is the same why 3DStudio is not a real-time renderer even
though games draw similar images in real-time.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 2 Apr 2001 10:04:19
Message: <3ac886e3@news.povray.org>
textures.
textures,
a couple of those on the site do feature proc textures, a variety of shapes
and simple csg animations.
however these raytracers are very highly optomised to just the scenes the
demo shows, and there is often a pixel doubling routing on the go to blow
the real time rendered output (anything from 160x80 - 320x240) up full
screen
Hi-Impact web site design & database driven e-commerce
PGP Public Key
Date: 2 Apr 2001 19:03:52
Message: <3ac90558@news.povray.org>
tnx for your answers...
Still, I think POV-Ray should be made much faster than it currently is :)
cu!
ZK
Date: 2 Apr 2001 19:23:49
Message: <3ac90a05$1@news.povray.org>
Strange, I find POV-Ray much faster now than it was a couple of years ago...
"Zeger Knaepen" <zeg### [at] studentkuleuvenacbe> wrote in message
news:3ac90558@news.povray.org...
> cu!
> ZK
Date: 2 Apr 2001 20:04:59
Message: <3AC91328.D406B71B@via.ecp.fr>
So do I : I remember it would take a whole night to render a simple
stone cup at 320x200 on my old Atari STe :)
JM
Date: 2 Apr 2001 20:12:31
Message: <d75ictcigan6ailco8jf11v54bt7gg94eg@4ax.com>
  The solution is simple - you need a faster computer for POV-Ray. As a side
benefit, your secondary applications will also perform better ;)
Alan - ako### [at] povrayorg - a k o n g <at> p o v r a y <dot> o r g
Date: 2 Apr 2001 22:08:12
Message: <slrn9cic31.c24.ron.parker@fwi.com>
Feel free to contribute some fixes that make it so.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 3 Apr 2001 01:06:13
Message: <3ac95a45$1@news.povray.org>
In article <3ac74223@news.povray.org> , "Zeger Knaepen"
It can.  You just have to remove the parsing stage for every frame.  You
can do this either by constructing objects manually in memory or by
parsing once and then manipulating the objects directly.  It is
possible, not too much work and you get a decent frame rate on an
average system.  However, you should reduce max trace level to two or
three.
Just be aware which options you have to turn off because they assume a
static scene and do break real-time manipulation of the scene if you
don't fix them on the fly, too.  For example the vista buffer or object
bounding.
      Thorsten
