POV-Ray : Newsgroups : povray.general : unexpected rotation result Server Time
26 Oct 2026 08:40:24 EDT (-0400)
  unexpected rotation result (Message 1 to 48 of 48)
Subject: unexpected rotation result
Date: 5 Feb 2001 05:07:48
Message: <3a7e7b74$1@news.povray.org>
I came across this one the other day (don't know how I'd missed this
"feature" before).
Basically, I expected the two following rotations to be identical:
rotate y * - 45 + 45
rotate y * (- 45 + 45)
However, only the second one limits the rotation to y (the behaviour I
expected), whereas the first rotates y then z. Does this seem odd to anyone
else? Why is the first statement equivalent to <0,-45,45> ? Don't you need
commas and/or chevrons for vectors involving more than one axis?
Confused of Putney.
Subject: Re: unexpected rotation result
Date: 5 Feb 2001 05:36:06
Message: <3a7e8216@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote in message
news:3a7e7b74$1@news.povray.org...
> "feature" before).
I would guess that pov is doing the multiplication first then adding
45.  Hence it's doing rotate <0,-45,0> + 45.
whereas the brackets in the second force pov
to evaluate the -45+45 first and multiply with y second.
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Date: 5 Feb 2001 05:45:28
Message: <3a7e8448$1@news.povray.org>
"Gail Shaw" <gsh### [at] monotixcoza> wrote in message
news:3a7e8216@news.povray.org...
Ah, it would appear that my problem here was based on a more serious
underlying misunderstanding. I've always specified single-axis rotations as,
for example, rotate x * 45. I thought that this just meant rotate x 45
degrees. So what does rotate x*45 mean? 45 times what?
Date: 5 Feb 2001 05:56:48
Message: <3a7e86f0@news.povray.org>
news:3a7e8448$1@news.povray.org...
as,
x is equivalent to <1,0,0> hence rotate x*45 is exactly the same
as saying rotate <1,0,0>*45 or rotate <45,0,0>
Gail
Date: 5 Feb 2001 05:58:55
Message: <3a7e876f@news.povray.org>
news:3a7e86f0@news.povray.org...
SHPINGGG! (sound of light going on in confused head)
Many thanks Hurricane Beach.
Date: 5 Feb 2001 06:02:35
Message: <3A7E8847.C9EFB12A@merlin.net.au>
x = <1,0,0> so x*45 = <45,0,0>
As for the first problem, the POV parser uses normal precedence rules.
It does the multiplication first, then the addition.
y = <0,1,0> so y* -45 = <0,-45,0>
then it promotes the second 45 to a vector so that it can be added
45 becomes <45,45,45>
so the end result is <0,-45,0> + <45,45,45> = <45,0,45>
PoD.
Date: 5 Feb 2001 06:03:40
Message: <3a7e888c@news.povray.org>
news:3a7e876f@news.povray.org...
Glad to have been of help.
ROFL. Haven't seen that one before.
Gail
Date: 5 Feb 2001 06:19:45
Message: <3a7e8c51@news.povray.org>
"PoD" <pod### [at] merlinnetau> wrote in message
news:3A7E8847.C9EFB12A@merlin.net.au...
Yep, got it figured now. I'd never taken in that rotate y on its own meant
anything, so I'd misunderstood what the * in rotate y*45 meant (I vaguely
assumed it was to allow the parser to recognise a single vector
transformation).
That aside, intuitively, I would still have expected "rotate y * foo + bar"
to limit the rotations to the y axis. Still, now I know.....
All in all, it reminds me of what someone at work told me. He is an
experienced programmer and script writer, but he always uses brackets - e.g.
x := ((x*45) + 10)
When I asked him why, he said that a) he doesn't have to worry about someone
screwing up the parser, b) it makes the code clearer and c) why not?
Date: 5 Feb 2001 11:15:25
Message: <3a7ed19d$1@news.povray.org>
"Tom Melly" <tom### [at] tomandlucouk> wrote in message
news:3a7e8c51@news.povray.org...
> experienced programmer and script writer, but he always uses brackets...
    Most experienced programmers/scripters do - it's the safest way to get
any language to do what _you want_, rather than what _it thinks you want_ !
E.g, what does 1+2*3-4 evaluate to ?
Scott.
Date: 5 Feb 2001 14:39:50
Message: <3a7f0186@news.povray.org>
Scott Hill <sco### [at] ncgraphicsnet> wrote in message
news:3a7ed19d$1@news.povray.org...
If the rules of precedence that I remember are correct then that equals 3,
but it's
not clear from a quick look. I tend to use brackets if there are more that 3
terms
in an expression, regardless of whether they are actually needed or not.
Gail
Date: 5 Feb 2001 16:01:42
Message: <slrn97u21r.1qn.hjp-usenet@teal.h.hjp.at>
>> an experienced programmer and script writer, but he always uses
>> brackets...
>get any language to do what _you want_, rather than what _it thinks you
>want_ ! E.g, what does 1+2*3-4 evaluate to ?
That one should be the same (3) in just about every programming
language. But there are more difficult examples. E.g., what is
(0x11 & 0xF0 == 0x10) in C? C has so many operators that even the
experienced C programmer gets confused sometimes. It gets worse if you
use several programming languages with slightly different evaluation
rules.
However, more parentheses are not always more readable. Where the
average programmer already knows the precedence (e.g, multiplication
before addition), they only clutter the display and make the reader
wonder why they were used. For example, I wouldn't write
    1+(2*3)+4,
although I would probably write
    1 + 2*3 + 4
to enhance readability for the human reader.
Really religious application of parentheses is required in macro
processors which do simple string substitutions (like cpp or those of
many assemblers). Otherwise you get nasty surprises if you do something
like
#define twice(a) a*2
printf("%d", twice(1+2));
	hp
   _  | Peter J. Holzer    | All Linux applications run on Solaris,
|_|_) | Sysadmin WSR       | which is our implementation of Linux.
| |   | hjp### [at] wsracat      |
__/   | http://www.hjp.at/ |	-- Scott McNealy, Dec. 2000
Date: 5 Feb 2001 16:27:18
Message: <3a7f1ab6@news.povray.org>
> many assemblers).
Why go there, just take POV macros for example :)
I encounted several frustrating quirks with POV macros, before I learned to
use parantheses liberally both in macro bodies and around macro calls.
Margus Ramst
Home page http://www.hot.ee/margusrt
Date: 5 Feb 2001 18:09:32
Message: <3A7F3285.CAAFC1FA@faricy.net>
3. Bad example, that's standard basic math. Everyone learns order of operations
in elementary school! :) In fact, even with all the computer-specific
extensions like bit rotation and boolean logic, the order of precedence should
still be the same in every language.
Date: 5 Feb 2001 18:13:59
Message: <3A7F3390.822EA9BB@faricy.net>
> rules.
True, parentheses can help you be less obfuscated. But I thought all
languages had the same order of operations, except maybe a few very obscure
examples.
>     1+(2*3)+4,
>     1 + 2*3 + 4
I find myself doing that more; put a space padding around additive
operations but bunch together multiplicative operations. That shows the
algebraic seperation of terms, which incidentally is also where the parser
should seperate it. So is useful to know. :)
Date: 5 Feb 2001 18:53:15
Message: <slrn97uf7e.4fs.ron.parker@fwi.com>
>examples.
Sometimes the parser has a bug, though.  Not that I'm naming names or
anything.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 6 Feb 2001 01:20:54
Message: <3a7f97c6$1@news.povray.org>
David Fontaine wrote in message <3A7F3390.822EA9BB@faricy.net>...
>examples.
All Reverse Polish Notation languages have the same order of operation:
strictly left-to-right for all operators.
Mark
Date: 6 Feb 2001 01:24:03
Message: <3A7FAE41.E1255D1A@hotmail.com>
> "feature" before).
Which the parser expands to y*-45 + <45,45,45> = <45,0,45>
Which the parser evaluates as y*0.
> Confused of Putney.
Hope this enlightens,
John
Date: 6 Feb 2001 07:02:19
Message: <3a7fe7cb@news.povray.org>
news:3A7F3285.CAAFC1FA@faricy.net...
get
want_ !
> 3.
    No ! 5.
operations
should
    That's the point - we and parsers all assume, because we've all learned
(or, in the case of parsers, have been hard coded with) the correct operator
ordering, that it evaluates to 3, but, I may not have meant that, I could
just as easily meant ((1+2)*3)-4 ! Without brackets it is ambiguous, to a
degree - we may default to assuming that we're meant to follow the standard
operator order rules but we don't and can't know that that assumption is
correct.
Scott.
Date: 6 Feb 2001 07:31:34
Message: <3a7feea6$1@news.povray.org>
Scott Hill schrieb in Nachricht <3a7fe7cb@news.povray.org>...
>correct.
Well, it is even ambiguous with brackets. Cause if you don't fallow the
standard rules, you could give the brackets a totally different meaning.
That's what makes all communication that faulty - we assume, that we follow
the same rules, but most of the time we don't. As a wise man said ones - it
is more of an wonder that communication does happens most of the time in a
correct way than the opposite.
Marc-Hendrik
Date: 6 Feb 2001 07:37:08
Message: <3a7feff3@news.povray.org>
Gail Shaw <gsh### [at] monotixcoza> wrote:
: I would guess that pov is doing the multiplication first then adding 45.
  Well, that's exactly what it should do because that's the correct behaviour.
Multiplication has higher precedence than addition.
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 6 Feb 2001 13:27:35
Message: <3a804217@news.povray.org>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in message
news:3a7feea6$1@news.povray.org...
standard
> >correct.
follow
it
    Hmm, yes, but not in the same way - you may as well say that it's
ambiguous because we _could_ interpret the numerical digits differently -
the problem is not that we're misinterpret anything, but, rather that there
isn't enough information in the original form - we need the precedence rules
to remove the ambiguity but they do not redefine or even clarify the meaning
of any of the symbols ('+' stills means 'plus', '-' still means 'minus' and
'*' still means 'times'). Likewise, adding brackets does not change the
meanings of any of the symbols, they just clarify how those symbols are
intended to interact.
Does that make any sense ?
Scott.
Date: 6 Feb 2001 14:45:34
Message: <3a80545e@news.povray.org>
"Scott Hill" <sco### [at] ncgraphicsnet> wrote in message
news:3a804217@news.povray.org...
<snip>
<snip>
Exactly - the sentence "the man went into the farmer's toilet and took his
trousers down" is ambiguous because we don't know whether the man takes his
own or the farmer's trousers down. It is also ambiguous because "trousers"
could mean "dictation". However, one is an ambiguity within the rules of
English, whereas the latter is only ambiguous if we ignore the rules of
English. We resolve the first by using common sense - we would generally
assume that the man takes his own trousers down (unless the book has been
purchased in a specialist shop and is being read one-handed).
Unfortunately, there is no common sense that can resolve "3+2*5". There is
nothing to imply that the multiplication occurs first. It would not be
illogical to write a parser that evaluated the addition first - it doesn't
break a rule, so much as a convention designed to resolve the inherant
ambiguity. However, to write a parser that ignored brackets or treated them
as some other operator would be an act of blatent idiocy.
Date: 6 Feb 2001 15:02:14
Message: <3a805846@news.povray.org>
Scott Hill schrieb in Nachricht <3a804217@news.povray.org>...
Yes, it does. But only if you use a hierarchic structure for the rules, you
use. From a strictly mathematical point of you (I think) there is no
difference in the rule that multiplications are done before additions and
the one that tells you, what brackets mean or what the digit "2" mean. Or is
this not right?
From a more general point of view you and Tom are absolutely right of
course.
Marc-Hendrik
Date: 6 Feb 2001 18:17:03
Message: <3A8085CA.B22C86A5@faricy.net>
Scott Hill wrote:
>     No ! 5.
> correct.
NO!! 1+2*3-4 is three, only three, exactly three, no more, no less, and most
certainly not and NEVER five. If you meant (1+2)*3-4, that would be analagous to
me typing orange and meaning purple. Anyone who types 1+2*3-4 and expects 5 is
an idiot.
Date: 6 Feb 2001 18:19:51
Message: <3A808672.D37E6BD5@faricy.net>
[snip]
Of course there is. It's called simple algebra.
a*x^2+b*x+c means what to you?
Date: 7 Feb 2001 00:20:58
Message: <3a80db3a$1@news.povray.org>
David Fontaine wrote in message <3A8085CA.B22C86A5@faricy.net>...
most
analagous to
is
>an idiot.
I just typed the expression 1+2*3-4 into my TI-1795 calculator, and, as
expected, got the number 5.
Mark
Date: 7 Feb 2001 04:24:39
Message: <3a811457$1@news.povray.org>
news:3A808672.D37E6BD5@faricy.net...
is
> [snip]
(a*(x^2)) + (b*x) + c - but this is not common sense, it is following a
convention that exists because common sense is not available.
In fact, one could argue that the only common sense option is to evaluate
the expression strictly left to right. IMHO common sense would dictate that
the solution is: (a*x)^2 + (b*x) + c.
Date: 7 Feb 2001 04:27:17
Message: <3a8114f5$1@news.povray.org>
news:3A8085CA.B22C86A5@faricy.net...
most
analagous to
5 is
> an idiot.
I disagree. Anyone who types 2*1.5 and expects 5 is an idiot. Typing 1+2*3-4
and expecting 5 just means that they don't know the conventions. The
conventions exist because intelligence alone cannot resolve the issue.
Date: 7 Feb 2001 04:28:34
Message: <3a811542@news.povray.org>
"Mark Wagner" <mar### [at] gtenet> wrote in message
news:3a80db3a$1@news.povray.org...
Good point.
Date: 7 Feb 2001 05:33:16
Message: <chrishuff-95BA06.05341707022001@news.povray.org>
In article <3a811457$1@news.povray.org>, "Tom Melly"
> that the solution is: (a*x)^2 + (b*x) + c.
You still followed the precedece of * over +, I think it's even uglier:
((((a * x) ^ 2) + b) * x) + c
Unless you were only talking about individual terms.
I think my exponent patch (which allows you to use ^ for pow() in
ordinary scene code) breaks on this, instead of evaluating that as:
It will see:
((a*x)^2) + (b*x) + c
Christopher James Huff
Date: 7 Feb 2001 06:40:02
Message: <3a813412$1@news.povray.org>
news:3a805846@news.povray.org...
you
is
> this not right?
    Hmm. IMHO, no. But then I've just tried putting into words why they're
different and I can't. I'll have to ponder on this one for while....
> course.
    Of course. I'm _always_ right! ;-)
Scott Hill.
NC Graphics (Cambridge) Ltd.
http://www.ncgraphics.co.uk
Date: 7 Feb 2001 07:34:23
Message: <3a8140cf@news.povray.org>
"Chris Huff" <chr### [at] maccom> wrote in message
news:chrishuff-95BA06.05341707022001@news.povray.org...
I didn't really follow the precedence - I just reduced the equation to a
non-ambiguous form... Well, almost. I should have written ((a*x)^2)+(b*x)+c.
As I wrote it originally, I suppose it could mean (a*x)^(2+(b*x)+c).
Date: 7 Feb 2001 09:32:37
Message: <3a815c85@news.povray.org>
In article <3a80db3a$1@news.povray.org> , "Mark Wagner"
Yes, because you did not calculate the above!  What you calculated* was :
1+2=3
3*3=9
9-4=5
Obviously this cannot be the same as 1+2*3-4.
     Thorsten
* Your calculator manual will of course explain this exactly the same way.
However, most newer caclulators (and many expensive older ones) support
calculations in mathematical order (or whatever this is called).
e-mail: tho### [at] trfde
Date: 7 Feb 2001 10:20:51
Message: <3a8167d3@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3a815c85@news.povray.org...
> 1+2=3
> 3*3=9
> 9-4=5
    Yeah, but the point is that 5 is just as valid a result as 3, for the
sum 1+2*3-4, if we ignore the 'accepted' operator precedence rules. We could
quite as easily have precedence rules that state that addition and
subtraction is done before multiplication and then everyone would be saying
"But it's not 3, it's -3!". Do you see ? All that makes 1+2*3-4 evaluate to
3, rather than -3, or 5, or -1 is an arbitrary rule about which order the
operations should be done in - change those rules and you change the
answer - but you don't change any fundamental aspect of mathematics.
    There are, unless I've missed some, 5 ways (if we ignore standard
operator order rules) to interpret '1+2*3-4' :
    (1+(2*(3-4))) = -1
    (1+((2*3)-4)) = 3
    ((1+(2*3))-4) = 3
    ((1+2)*(3-4)) = -3
    ((1+2)*3)-4) = 5
    These're all _mathematically_ correct statements, yet we only except one
to be the correct evaluation of '1+2*3-4'. This is not, as I've already
said, because any of the others are wrong, but merely because the statement
is ambiguous and we therefore need some way to de-ambiguate (choose) between
the possible interpretations.
Scott Hill.
P.S. When will p.o-t be back ?
Date: 7 Feb 2001 10:42:55
Message: <3a816cff$1@news.povray.org>
news:3a8167d3@news.povray.org...
It is! (follow ups to ot.)
Date: 7 Feb 2001 10:50:09
Message: <3a816eb1@news.povray.org>
Scott Hill schrieb in Nachricht <3a8167d3@news.povray.org>...
>    (1+(2*(3-4))) = -1
>    (1+((2*3)-4)) = 3
>    ((1+(2*3))-4) = 3
>    ((1+2)*(3-4)) = -3
>    ((1+2)*3)-4) = 5
one
between
They are not mathematically correct, because an improtant part of the
mathematical system are the precedence rules. They are in no way more
arbitrary than any other mathematical rule, 'cause mathematics is no science
but just a set of rules which have at first nothing to do with any real
thing in the world (although they prove to be of much help to understand
some things in real world). If you just cancel one of the rules you can as
easily give up the whole system - or at least you have to say what you are
doing. The mathematical system in whole is not ambiguos at all - cause there
are rules to tell you how everything interacts which each other.
Well, it is back for more than a week now.
Marc-Hendrik
Date: 7 Feb 2001 11:14:51
Message: <3a81747b$1@news.povray.org>
news:3a816eb1@news.povray.org...
science
I disagree - for example I am not offended/shocked/suprised/whatever that
entering 2+3*5 in a calculator gives me 25 but gives me 17 in POV. However,
if a calculator or program ever told me that 3*5 was anything but 15, I
would ask for a refund.
IMHO you're missing the point. Precedence rules exist (once more with
feeling) because common-sense cannot resolve the issue.
Another English example - "rape" is both an act and a plant. If I say "there
is a lot of rape in Sussex" you have no way of knowing whether I mean the
plant or the act. The doubt can only be resolved by some extra words. For
example "there are many rape-plants in Sussex".
This is the linguistic equivalent of brackets in a function. For you to
argue that the meaning of * or + is just as arbitary as precedence is the
equivalent of me saying that "there is a lot of rape in Sussex" is as
ambivalent as "there is a lot of crime in Sussex" because, in some private
language of my own, "crime" also means "oxygen".
Yes, maths is arbitary, but so is English. Nevertheless "rape" is ambivalent
in a way that "crime" is not.
Date: 7 Feb 2001 12:23:25
Message: <3a81848c@news.povray.org>
Tom Melly <tom### [at] tomandlucouk> wrote:
: I disagree - for example I am not offended/shocked/suprised/whatever that
: entering 2+3*5 in a calculator gives me 25
  If I enter that in my calculator it gives me 17.
  Why?
  There are two (main) types of calculators.
  Usually calculators only calculate one operation at a time. They do not
have memory for long expressions (some of these have indeed parentheses,
but still they work in the same way when parentheses are not used) and they
calculate every sub-expression right after it has been entered.
  What happens when you type "2+3*" (yes, I left the '5' intentionally out)
is the following: The calculator gets a '2', then a '+', then a '3'. Now
it expects either a number or another key (such as '=' or another operator).
When it gets something that is not numerical input it immediately calculates
the result of the current operation (as if '=' had been pressed) before
continuing.
  In fact, pressing any operator is like pressing '=' and that operator
(some very cheap calculators don't even have a '=' at all, but you have to
press some operator in order to get the result, such as '+'). Pressing the
operator is more like a shortcut for '=' and the operator itself.
  This is most probably done for simplicity. Usually these kind of calculators
are used for very simple tasks, like adding the prices of some products
together and so on. Modifying the behaviour of the operator keys to work
in another way would most probably just confuse people.
  When you type "2+4*5" you are, in fact, typing "2=+3=*5", although it's
kind of hidden.
  Now, the most advanced calculators (mainly graphical ones, like mine) allow
you to actually write long expressions (the whole expression is shown on
the screen of the calculator) and the result is calculated only when you
press '=' (or usually 'enter' in those calculators).
  These calculators also usually allow you to navigate through the expression
with cursor keys and make modifications to it.
  (The most advanced allow you to enter more complex mathematical operations
such as summation, derivative and integrals. Mine does; it even shows them
in the same way as I would write them on paper.)
  Since in these calculators you are actually calculating the result of the
whole expression, not just a sub-expression at a time, the result is the
mathematically expected one.
Date: 7 Feb 2001 14:41:13
Message: <ae738t4t1vm66jo1sup9dgpbkvkim23ec3@4ax.com>
11123-4
12222223-4
and so on
Basically one or more 1's followed by zero or more 2's followed by
'3-4'
It basically depends on the input string you are matching against.
Peter Popov ICQ : 15002700
Date: 7 Feb 2001 14:58:30
Message: <3a81a8e6@news.povray.org>
news:3a81848c@news.povray.org...
that
>   Why?
<SNIP>
Exactly - there is no wrong answer in the two answer, they are just using
two different conventions. However, to calculate the result on the basis
that "+" meant "/" would be silly.
Date: 7 Feb 2001 17:31:51
Message: <3A81CCBB.635F3E91@faricy.net>
I don't know, it seems sensible to me. Addition versus multiplication: to me,
multiplying implies part of the same thing, like  width and height of a
rectangle, whereas addition is the sum multiple things, ie multiple rectangles.
Think of the problem of surface area of a 3d solid. Hence multiplication
operations should be "groups" when figuring out the order of operations. It
gets progressively more obscure, but I think a similar arument can be made for
all precedences.
Besides from which, mathematics and programming require strict rules and some
degree of consistency by their very nature.
Date: 7 Feb 2001 17:49:10
Message: <3A81D0CA.309094A@faricy.net>
> most
> analagous to
> 5 is
> > an idiot.
I still disagree. Mathematics REQUIRES conventionality. There can be NO
ambiguity in mathematics. It operates on the idea of proof through logic.
There are reasons for the order of operations. Every multiplication operation
takes parts of the same thing; length*width=area of *one* face on a cube, or
average_velocity*time=displacement. Addition and subtraction however take
multiples of something; you sum multiple faces to get the total surface area, et
al. Of course it is not always this simple, but that's why we use parentheses.
The parentheses show us clearly, visually and unambiguously that an operation is
being used as one piece in a larger operation.
If your calculator is giving you five it is merely a limitation of the
technology. The manual probably states clearly that five is techincally wrong,
and shows what the calculator is *really* doing. Any scientific calculator obeys
order of operations, and even the older ones will expect that you request the
result before the computation is complete. Instead the cheap calcs think you
want a result after every operation, then discard everything you typed in.
Date: 8 Feb 2001 04:36:14
Message: <3a82688e$1@news.povray.org>
news:3A81CCBB.635F3E91@faricy.net...
It
for
> all precedences.
Well, yes, but obscure is the important point. Okay, you might be able to
make a clear arguement for * over + but what about - and + or / and * ?
There maybe an arguement, but it isn't a clear one. However, any arguement
that says 2*3 is not 6 is plainly batty.
Date: 8 Feb 2001 08:21:07
Message: <3a829d42@news.povray.org>
> "David Fontaine" <dav### [at] faricynet> wrote in message
> It
> for
>> all precedences.
Actually, there are plenty of number systems where this is plainly *not*
true.  There are the simple systems where 6 is undefined (base 4, for
example, where 2+3 = 11, or the mod 5 number system, where 2*3 = 2) and then
there are more complex things, where the definitions which you use for the
multiplicative and additive operators get weird.  I can't give a good
example here, since A. It takes a lot of math, and B. It's been close to a
decade since I did discrete algebra.  How number systems behave is highly
dependant upon the assumptions you place upon them.
Now, if you're talking about the integer, rational, or real number lines,
then yes, 2*3 = 6.  However, those are not the only number system available
to us.  I use mod systems all the time in POV, for example.
Geoff
Date: 8 Feb 2001 09:11:22
Message: <3a82a90a$1@news.povray.org>
"Geoff Wedig" <wed### [at] darwinepbicwruedu> wrote in message
news:3a829d42@news.povray.org...
arguement
then
Well, yes, obviously if you use any other system than decimal, then all bets
are off. However, even recognising the validity of some of the arguements
put forward, I still find it remarkably obtuse to argue that precedence is
no more arbitary than what 1+1 equals (base 3 upwards ;)
Date: 8 Feb 2001 09:22:54
Message: <3a82abbd@news.povray.org>
> arguement
> then
Oh, yes.  Precedence is a convention, not a base assumption of mathematics.
Precedence involves how systems of equations are written down, how they're
represented, not the equations themselves.  The equations are what's really
relevant, not their representation.  Representations have changed over the
years (the way Newton wrote out equations was *very* different from anything
we'd see today), but the math that was represented, that is what's
importatn, and that hasn't changed (well, been improved, modified, etc, but
nothing in it has become incorrect within its sphere)
Geoff
Date: 9 Feb 2001 16:02:18
Message: <slrn988lhg.85s.hjp-usenet@teal.h.hjp.at>
>: that entering 2+3*5 in a calculator gives me 25
>  If I enter that in my calculator it gives me 17. Why?
>  There are two (main) types of calculators Usually calculators only  .
>  calculate one operation at a time                                   .
I would debate the "usually" here. Every calculator I have ever bought
(starting with that TI-33 over 20 years ago) knew about precedence
rules. The cheap thingies built into mouse mats and rulers probably
don't but they don't have parentheses either (for the same reason -
parentheses require a deeper stack).
An interesting variation are some printing desk calculators, which use
infix operators for multiplication and division and postfix for addition
and subtraction. So to compute 2*3 - 4*5 you would type
CLR 2 * 3 + 4 * 5 -
>allow you to actually write long expressions (the whole expression is
>shown on the screen of the calculator) and the result is calculated
>only when you press '=' (or usually 'enter' in those calculators).
The TI-33 didn't. It calculated each subexpression as soon as possible.
So if you type 2+3* it would notice that * has higher precedence than +
and throw 2+ on the stack. If you continued typing 5-, it would first
complete the multiplication (giving 15) and further check the stack
for pending operations. Since + has the same precedence as -, it would
perform the addition, too.
The stack had a limited depth (6 entries, I think), but I rarely
exceeded it. That wasn't a high-end calculator at that time, either, it
costed only a few hundred ATS - an HP-42 was about 10 or 20 times as
expensive, IIRC.
	hp
Date: 9 Feb 2001 17:56:29
Message: <3A84756F.7892F9E8@faricy.net>
- and + are the same operation. / and * are the same operation. Well, they're
inverse, but to be inverse they must use the same stuff (ya know, like to be
opposites words must describe the same thing--hot and cold). -x = +(-x) and /x =
*(1/x). It wouldn't make any sense to do multiplaction then subtraction then
division then addition, or something like that.
