POV-Ray : Newsgroups : povray.general : 3DNow or Later? Server Time
4 Nov 2026 04:57:45 EST (-0500)
  3DNow or Later? (Message 1 to 13 of 13)
Subject: 3DNow or Later?
Date: 26 Jan 2001 05:24:09
Message: <3a715049@news.povray.org>
Hi there,
Just wondering if Povray supports 3DNow (plain vanilla K6-2 and/or extended
Athlon), and if not if it plans to support it in the future.
Thanks
Michael
Subject: Re: 3DNow or Later?
Date: 26 Jan 2001 06:25:17
Message: <3a715e9d$1@news.povray.org>
"Michael Brown" <emb### [at] i4freeDELETETHISconz> wrote in message
news:3a715049@news.povray.org...
> Hi there,
extended
Is 3DNow relevant to POV? I may have misunderstood, but I thought it just
increased the speed of 3d graphics and multi-media, and would therefore have
no effect on rendering. That said, 3DNow does, I believe, speed up floating
point calculations.
Question: If 3DNow speeds up float calcs, why is it only of benefit to
graphics and not all apps. using floating point calcs.?
Date: 26 Jan 2001 07:50:28
Message: <3A717294.1A67AFD1@student.ethz.ch>
As I understood it, 3DNow supports single precision floating point only.
But POV (and ray-tracing in general) needs double precision to get good
pictures (there is a thread in p.unofficial.patches about why this is
so). Therefore 3DNow is useless for POV.
- Micha
Date: 26 Jan 2001 08:06:18
Message: <3A717642.3C96091C@gmx.de>
> - Micha
Specifically the threads:
3D!Now & ISSE
double/single precision
BTW, wouldn't that be a good addition to the VFAQ?
Date: 26 Jan 2001 08:32:43
Message: <3A717C79.10257149@kivisalo.net>
WinAmp uses 3DNow to decode mp3s.
______________________________________________________________________
Kari Kivisalo                                  http://www.kivisalo.net
Date: 26 Jan 2001 09:30:04
Message: <3a7189ec@news.povray.org>
"Kari Kivisalo" <kar### [at] kivisalonet> wrote in message
news:3A717C79.10257149@kivisalo.net...
Yes - I gathered that it applied to multi-media (hate that term) - this is
partly what confused me. MM as a generic set of apps is hardly likely to
benefit from something unless that something can also benefit non-MM apps.
The answer would appear to be the 3dnow only works on single-point.
Subject: 3DNever :) (Was Re: 3DNow or Later?)
Date: 26 Jan 2001 17:45:28
Message: <3a71fe08@news.povray.org>
Just have to push to get AMD to beef up 3DNow with double precision, I
guess. Could call it Super Extended 3DNow!  :)
And yes, it would be a good addition to the FAQ.
news:3A717642.3C96091C@gmx.de...
> > - Micha
> 3D!Now & ISSE
> Christoph
> IsoWood include, radiosity tutorial, TransSkin and other
> things on: http://www.schunter.etc.tu-bs.de/~chris/
Date: 28 Jan 2001 06:20:37
Message: <3A7401EC.4B5FDEF@hotmail.com>
My understanding of 3dnow, and intel's counterpart Katimi new instructions, is
that it merely allows you to do the same instruction on several pieces of data
simultaneously.  Basically it saves clock cycles by not having to repeat the
same instruction.  Example multiplying normally you would input something like
this into the processor: data, data, multiply, data, data, multiply, data,
data, multiply... But with (single instruction multiple data) it would use a
single command to to input all the multiply's.  Well this is my understanding
of it.  I have never read the actual list of commands an intel processor
recognizes.
Dan Johnson
Date: 28 Jan 2001 10:04:50
Message: <3a743512@news.povray.org>
http://www.students.tut.fi/~warp/povVFAQ/miscVFAQ.html#3dnow
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?puts(""):m)for(_=(
c/4)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}    /*- Warp -*/
Date: 28 Jan 2001 14:02:52
Message: <slrn978qtm.n50.hjp-usenet@teal.h.hjp.at>
Look in povray.unofficial.patches. Daniel Jungmann has converted the
color handling (which is single precision) to use 3D!Now and reports a
speedup of at least 50%.
	hp
   _  | Peter J. Holzer    | All Linux applications run on Solaris,
|_|_) | Sysadmin WSR       | which is our implementation of Linux.
| |   | hjp### [at] wsracat      |
__/   | http://www.hjp.at/ |	-- Scott McNealy, Dec. 2000
Date: 28 Jan 2001 15:04:39
Message: <3a747b57@news.povray.org>
I wish he were more precise about how his optimizations speed things up.
What is it exactly that has changed? Are *all* renders now just magically
50% faster, or what?
Date: 28 Jan 2001 23:05:50
Message: <3A74ECA1.BD19FA26@pacbell.net>
"Tony[B]" wrote:
> Are *all* renders now just magically 50% faster, or what?
No, not likely. Intersection testing will remain the same as well
as features such as media and radiosity. Complex textures and color
combinations will benefit as well as a possible speed up of multiple
colored light sources. Without having had a chance to test the
optimizations it is difficult to predict how much faster the "average"
scene file will be but you don't get something for nothing. For
example if you don't have a processor with 3DNow support you are out
of luck :)
Ken Tyler
Date: 28 Jan 2001 23:08:56
Message: <3a74ecd8@news.povray.org>
> For example if you don't have a processor
> with 3DNow support you are out of luck :)
Should there be significant improvement via his modifications to the source,
I would not hesistate to obtain one. :)
