POV-Ray : Newsgroups : povray.general : Glass Server Time
26 Oct 2026 09:41:52 EDT (-0400)
  Glass (Message 1 to 19 of 19)
Subject: Glass
Date: 9 Jan 2001 01:31:47
Message: <3a5ab053@news.povray.org>
I've been trying too figure out if PovRay renders glass correctly or not.
If you have a glass sphere that is slightly green (like normal window
glass). With most ray tracers and renderers they just map a colour too the
surface of the glass resulting in an even distribution of transparent green
when rendered(like a balloon), with of course refraction added. In real life
the centre of the sphere is actually darker because the light travels a
longer distance through the middle of the sphere than near the edge.
If PovRay doesn't do this, I think it should be easy too make something to
do this: the longer the distance that the light travels through the object,
the more light is absorbed. But I know nothing about programming or
scripting(yet). I don't want to use it only in spheres but in other shapes
as well.
Is there someone that can help me with this?
Thanks
Nekar Xenos
_____________
'E xapis meta sou.
Subject: Re: Glass
Date: 9 Jan 2001 02:16:28
Message: <c7el5tc1ci9jj2lg2mtj4gsn4qk3q81o6c@4ax.com>
On Tue, 9 Jan 2001 08:34:39 +0200, "J-Print News" <vir### [at] iconcoza>
To an extent :)
In real life glass is green because it absorbs some blue and red. To
achieve the same effect, make your sphere clear white and add a
magenta absorbing media. It behaves in the exact same way as you are
asking. The surface does not need to have a color as it is infinitely
thin (in POV's way of thinking); think of it as coating. You can give
it a finish with reflection and specular highlights, of course.
This is exactly what absorbing media does.
You can also use light attenuation which is faster. In official POV it
is not very accurate, I think, but MegaPOV offers an alternative
formula which is real-life based.
Note: I may be thining of light fading here but I don't have Mega
installed yet to check out (did a full reinstall just yesterday).
Peter Popov ICQ : 15002700
Subject: Re: Glass
Date: 9 Jan 2001 05:25:34
Message: <3a5ae71e@news.povray.org>
Thanks
Is MegaPov free? Where can I get it?
Nekar
Peter Popov <pet### [at] vipbg> wrote in message
news:c7el5tc1ci9jj2lg2mtj4gsn4qk3q81o6c@4ax.com...
> To an extent :)
the
green
life
to
object,
> Personal e-mail : pet### [at] vipbg
> TAG      e-mail : pet### [at] tagpovrayorg
Subject: Re: Glass
Date: 9 Jan 2001 05:41:13
Message: <3a5aeac9@news.povray.org>
Yes, and right here:
http://nathan.kopp.com/patched.htm
Lance.
http://come.to/the.zone
Subject: Re: Glass
Date: 9 Jan 2001 12:08:05
Message: <chrishuff-DA0AD9.12094409012001@news.povray.org>
In article <c7el5tc1ci9jj2lg2mtj4gsn4qk3q81o6c@4ax.com>, Peter Popov
It sounds like you mean the fade_color addition...it lets you specify
the color that light passing through the object attenuates to, and adds
an attenuation calculation that is supposed to be more realistic. And it
has nothing to do with light source fading, it is more of a solid-color
media-like effect.
Christopher James Huff
Subject: Re: Glass
Date: 9 Jan 2001 18:40:33
Message: <3A5BA04C.84746F2E@faricy.net>
Yes and no. That answer your question? ;)
(looks like Peter's explained it already)
Subject: Re: Glass
Date: 10 Jan 2001 05:52:11
Message: <3a5c3edb@news.povray.org>
interior
{ fade_distance ...
  fade_power ...
Subject: Re: Glass
Date: 10 Jan 2001 08:03:00
Message: <chrishuff-8059FF.08044010012001@news.povray.org>
In article <3a5c3edb@news.povray.org>, Warp <war### [at] tagpovrayorg>
wrote:
> interior
> { fade_distance ...
>   fade_power ...
And don't forget the fade_color available in MegaPOV.
Subject: Glass Reflections
Date: 10 Jan 2001 09:55:56
Message: <3a5c77fc@news.povray.org>
I just thought of something else. Glass reflects not only on the outside but
on the inside as well. If you look carefully at a window pane at night
you'll notice there is actually a double reflection.
Can this be done in Pov?
Thanks
Nekar
Subject: Re: Glass
Date: 10 Jan 2001 10:13:31
Message: <838o5t8ke8ok7tpc1vid8cj519dq2tg97c@4ax.com>
On Tue, 09 Jan 2001 12:09:44 -0500, Chris Huff <chr### [at] maccom>
>media-like effect.
I actually mean this:
>:: 7.2. Realistic attenuation
>:: If you set fade_power in the interior of an object at 1000 or above,
>:: MegaPov will use a realistic exponential attenuation function:
>:: Attenuation = exp(-depth/fade_dist)
>:: Colored attenuation does work with this exponential attenuation also.
Sorry abouit not being precise before but I just finished installing.
Subject: Re: Glass Reflections
Date: 10 Jan 2001 10:25:39
Message: <3a5c7ef2@news.povray.org>
J-Print News <vir### [at] iconcoza> wrote:
: Can this be done in Pov?
  The question would better be "could this be avoided with povray?".
  Povray does this by design. Trying to avoid this would be the hard thing
(I can't think of any way right now). Of course there's no reason to avoid
it...
char*i="b[7FK@`3NB6>B:b3O6>:B:b3O6><`3:;8:6f733:>::b?7B>:>^B>C73;S1";
main(_,c,m){for(m=32;c=*i++-49;c&m?putchar('\n'):m)for(_
=(c>>2)&7;putchar(m),_--?m:(_=(1<<(c&3))-1,(m^=3)&3););}  /*- Warp -*/
Date: 10 Jan 2001 10:31:56
Message: <3a5c806c@news.povray.org>
"J-Print News" <vir### [at] iconcoza> wrote in message
news:3a5c77fc@news.povray.org...
but
I wasn't sure so I tried it. This behaviour as far as I can see is
reproduced by default in both pov and mp. Try the following code:
light_source{<0,0,0> color rgb<1,1,1>*2 translate <0, 30, 0>}
light_source{<0,0,0> color rgb<1,1,1>*2 translate <0, -30, 0>}
camera{location  <5.0, 0.0, -5.0> look_at   <0.0, 0.0,  0.0>}
box{
  <-10,-10,0>,<10,10,1>
  pigment{rgbf 1}
  finish{reflection 1/2 ambient 0 diffuse 0}
sphere{0, 1 translate<-5,0,-5> pigment{Red}}
Date: 10 Jan 2001 15:50:37
Message: <chrishuff-BEFAA0.15521810012001@news.povray.org>
In article <3a5c7ef2@news.povray.org>, Warp <war### [at] tagpovrayorg>
> it...
In the official version, textures affect both sides of each surface the
same way, so glass panes will have that double-reflection effect
(actually, many more than two reflections, depending on
max_trace_level). MegaPOV allows you to override the texture of the
"interior" side of the surface with the interior_texture feature. This
feature also works with objects like bezier patches or triangles, which
don't have an "interior" but clearly have two sides.
Date: 10 Jan 2001 15:56:03
Message: <MPG.14c6dbdad88f5cb2989867@news.povray.org>
[snip]
Easy.  Define two textures for the glass, one with reflection, and one
with none.
Construct your pane of glass as a CSG difference of two cubes, one taking
a face off the other.  Assign the textures, one to each cube, and viola!
You have a pane of glass which has one face which eiother reflects or
does not reflect, depending on how you assigned the textures.
Bye for now,
     Jamie.
Date: 10 Jan 2001 15:58:54
Message: <slrn95pj8h.agl.ron.parker@fwi.com>
Maybe, maybe not.  There's also TIR, which is solely dependent on the
IOR of the object.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 10 Jan 2001 17:09:58
Message: <MPG.14c6ed695d0c3372989868@news.povray.org>
> IOR of the object.
True enough I suppose.  Then you could always just use a clipped plane as
a single face of a pane of glass, and fake it.  (the great maxim of
computer graphics as far as I'm concerned, if it's too tricky to do the
real way, fake it.  <grin>)
Although thinking about it, assuming that both textures were identical
apart from the reflection settings (Interior etc.) then surely the non-
reflective face would work to kill any TIR that might be taking place?
I'll try playing with it tomorrow night, as I need to hit the shower and
get to bed since I'm knackered.
Bye for now,
     Jamie.
Date: 11 Jan 2001 06:30:57
Message: <3a5d9971@news.povray.org>
Jamie Davison <jam### [at] dh70qdu-netcom> wrote:
: Construct your pane of glass as a CSG difference of two cubes, one taking
: a face off the other.  Assign the textures, one to each cube, and viola!
: You have a pane of glass which has one face which eiother reflects or
: does not reflect, depending on how you assigned the textures.
  This works only when looking from one side of the glass, but not the other
side.
  Suppose that we are also seeing the other side of the glass at the same
time through a mirror...
Date: 11 Jan 2001 06:32:50
Message: <3a5d99e2@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: with the interior_texture feature
  Is the bug about this feature, which I reported long ago, already fixed?-)
Date: 11 Jan 2001 07:55:50
Message: <chrishuff-3EB52D.07573311012001@news.povray.org>
In article <3a5d99e2@news.povray.org>, Warp <war### [at] tagpovrayorg>
>   fixed?-)
Hmm, probably not...I remember looking at the lighting code, but
couldn't figure it out. It was some problem with filtering textures,
right?
