I did this once, but no telling which version I had at the time. I thought
there was a /tile command for DTA, but I can no longer find it in the
documents.
I have 16 images at 256x256x256 res. ands would like to tile them to a
1024x1024x256 res. image in a 4x4 array. Does anyone have an idea what the
command for this is?
Grim
> documents.
> Grim
In version 2.2.7 the tiling command is -
(Tiling)
/TILE# Tile images # by #
/TILEX# Tile images horizontally, # per picture
/TILEY# tile images vertically, # per picture
(Geometrical transformation options)
/CL#,#[,#,#] Clip the input picture. The first two numbers
specify the top-left, and the other two numbers
control the width and depth.
/CLP#,#[,#,#] clip from top-left (after scaling)
/LOC#,#[,#] specify where to place image (default is 0,0)
The final number specifies time
/LT Make /LOC base vertical coords from the top edge
instead of the center.
/LB Make /LOC base vertical coords from the bottom edge.
/LL Make /LOC base horizontal coords from the left edge
/LR Make /LOC base horizontal coords from the right edge
/ROT#[,#] rotation... first number represents angle, second
is for time
/SC[#,#[,#]] rescale pictures to screen res. or specified size
/SCF[#,#[,#]] fast, but dumb, rescale
I am not sure these options are still available in v3.0 but you can
try. If not then I still have the earlier version I can send you
along with the docs for it.
If you need 2.2.7 go to: www.teleport.com/~dearmad I house it there.
2.2.7 is much better than the v3.0 DOS version which wiped out some
critical features- I use it over 3.0 all the time.
link for the lazy: http://www.teleport.com/~dearmad
Thanks guys! :)
Grim
"Dearmad" <dea### [at] teleport com> wrote in message
news:3A57F3FA.40D09430@teleport.com...
Yabutt... v3.0 putsout AVI's which is kinda kool. :)
GrimDude wrote:
> Thanks guys! :)
You are welcome. Check your clock. It's off a bit.
By the way... The v3.0 Alpha4 version you have on your site is obsolete.
You dissapeared a while back and I had to come up with a new link to DTA.
After floundering about for a couple of weeks I finally hunted down Dave
and he was kind enough to compile a final (no Alpha) release of v3.0 for
me. I have made it available, with Dave's permission, on the ftp server
at pvoray.org - ftp://ftp.povray.org/pub/povray/utilities/dta/
You may wish to update your site with the latest and last version
Dave plans to make available.
Cheers,
It'll only go off again. Overclocking I think... if not something in bios...
Grim
"Ken" <tyl### [at] pacbell net> wrote in message
news:3A57F85C.6FAF15BC@pacbell.net...
> GrimDude wrote:
> > Thanks guys! :)
> Ken Tyler - 1400+ POV-Ray, Graphics, 3D Rendering, and Raytracing Links:
Yeah true... and darn good ones at that- I sometimes use Bink for my AVI
needs though. Depends upon which folder I find myself in sometimes. :o)
I keep both around, and the WIN version too.
I replaced it I thought- I know I d/l'ed the latest version
(non-alpha). Maybe didn't update the link or the text on the page- I'll
check that this evening. Got too much animation in front of me that
needs plotting at the moment.
I've got three versions in my \windows\command directory, because one
supports gif, the second tiles and more functionality (now), and the third
avi's.
Anal...
Grim
news:3A58A444.D1954CBC@teleport.com...
