POV-Ray : Newsgroups : povray.general : Sort Server Time
26 Oct 2026 10:27:00 EDT (-0400)
  Sort (Message 1 to 18 of 18)
Subject: Sort
Date: 1 Jan 2001 17:46:44
Message: <3a5108d4$1@news.povray.org>
I've been trying to do a simple sort, but it doesn't seem to be working as I
remember. What am I doing wrong?
 #declare R1 = seed(321321);
 #declare Spread = array[6]
 /// populate
 #declare I = 0;
 #while ( I < 5 )
  #declare Spread[I] = rand(R1);
 #declare I = I+1;
 /// verify
 #declare I = 0;
 #while ( I < 5 )
  #debug concat(str(Spread[I],2,2), "\n")
 #declare I = I+1;
 #debug "\n"
 /// sort
 #declare I = 0;
 #while ( I < 5 )
 #declare First  = Spread[I];
    #declare P = I+1;
    #while (P < 5)
      #declare Second = Spread[P];
       #if ( Second < First )
       #declare Storage = First;
       #declare First   = Second;
       #declare Second  = Storage;
    #declare P = P+1;
 #declare I = I+1;
 /// re-display
 #declare I = 0;
 #while ( I < 5 )
 #declare I = I+1;
Subject: Re: Sort
Date: 1 Jan 2001 17:55:01
Message: <jh225t4ivlaot2qftvtduc1f8ipi5cj1dt@4ax.com>
On Mon, 1 Jan 2001 17:46:47 -0500, "Bill Dewitt" <bde### [at] cflrrcom> wrote:
Not putting in comments to tell us what is going on!
dav### [at] hamiltonitecom
http://hamiltonite.com/
Subject: Re: Sort
Date: 1 Jan 2001 17:58:11
Message: <3a510b83@news.povray.org>
I
[code snipped]
The mistake comes in trying to use the First and Second variables as if they
were pointers (i.e. your code assumes modifying these two variables will
modify the original array members you declared them to).  If you change the
code not to use these variables:
#declare I = 0; #while ( I < 5 )
   #declare P = I+1; #while (P < 5)
      #if (Spread[P] < Spread[I])
         #declare Storage = Spread[I];
         #declare Spread[I]   = Spread[P];
         #declare Spread[P]  = Storage;
   #declare P = P+1; #end
#declare I = I+1; #end
you should find it works as expected.
Subject: Re: Sort
Date: 1 Jan 2001 18:25:15
Message: <3a5111db$1@news.povray.org>
< Slaps head > Thanks...
Subject: Re: Sort
Date: 2 Jan 2001 06:01:43
Message: <3a51b517@news.povray.org>
By the way, that's one of the slowest way of sorting an array...
Subject: Re: Sort
Date: 2 Jan 2001 06:47:52
Message: <3a51bfe8@news.povray.org>
But bubble sorting is the easiest for a lot of people to understand and
write :)
My brother gave me a big lecture about different array sorting methods, like
binary search tree etc...
How easy is it to implement something like that with POV-Ray?
Lance.
http://come.to/the.zone
Subject: Re: Sort
Date: 2 Jan 2001 07:13:46
Message: <slrn953dpg.f4e.steve@zero-pps.localdomain>
A slap head with false teeth! Don't sound much like a Viking to me.
 11:05am  up 14 days, 22:27,  3 users,  load average: 1.39, 1.22, 1.10
Subject: Re: Sort
Date: 2 Jan 2001 07:30:16
Message: <3a51c9d8$1@news.povray.org>
news:3a51b517@news.povray.org...
    Well... being as how I am only sorting 6 things....
    But if you would like to publish an array sorting macro, I will use it
with great happiness and thanks.
Subject: Re: Sort
Date: 2 Jan 2001 08:09:28
Message: <3a51d308@news.povray.org>
Lance Birch <-> wrote:
: But bubble sorting is the easiest for a lot of people to understand and
: write :)
  Actually insertion sort is a lot more intuitive than bubble sort.
  If you ask someone who doesn't know anything about sorting to make a
sorting algorithm, he will most probably make an insertion sort (or a very
close variant), not a bubble sort.
  Bubble sort is just awful. It's slow even for an O(n^2) algorithm.
Insertion sort is also an O(n^2) algorithm (that is, very slow), but quite
faster than bubble sort.
  O(n^2) algorithms are hopelessly slow when there are even a slight amount
of items (like 1000 or so). If one wants a good sorting algorithm, it's
necessary to use an O(n*log n) algorithm. Those beat O(n^2) algorithms 10-0
with large amount of items.
  A merge sort might be the easiest to implement in povray.
Subject: Re: Sort
Date: 2 Jan 2001 08:18:26
Message: <3a51d522@news.povray.org>
OK, I can see how an insertion algorithm is just as easy to make (and why
it's more intuitive).
But then again there's no real need to have it super fast anyway if it's
going to be just on the parse phase...
I understand all the stuff about O(n^2) and O(n*log n) too, he talked for a
fair while, hehe, actually I'm amazed I remember most of it... I wasn't
really paying attention at the time... hehe
Lance.
Subject: Re: Sort
Date: 2 Jan 2001 14:43:37
Message: <3A52302F.EDC9DB8@datacomm.ch>
Here is an implementation of the quicksort algorithm in pov. It uses
recurisve macro calls.
It sorted 10000 numbers in less than a minute. With megapov it goes
about twice as fast.
Hope it is of some use.
- Micha Riser
-------------- begin code ------------------------------
#declare a=array[10000]
#macro Quicksort(L,R)
  #local i=L;
  #local j=R;
  #local c=a[int((L+R)/2)];
  #while(i<j)
    #while(a[i]<c) #local i=i+1; #end
    #while(a[j]>c) #local j=j-1; #end
    #if (i<j)
      #local tmp=a[i];
      #declare a[i]=a[j];
      #declare a[j]=tmp;
      #local i=i+1;
      #local j=j-1;
  #if (i=j)  #local i=i+1;  #local j=j-1; #end
  #if (L<j) Quicksort(L,j) #end
  #if (i<R) Quicksort(i,R) #end
#declare my_seed=seed(0);
#local i=0;
#while(i<10000)
#declare a[i]=rand(my_seed)*10000;
#local i=i+1;
#debug "starting quick sort\n"
Quicksort(0,9999)
#debug "finished.\n"
#local i=0;
#while(i<10000)
#debug str(a[i],3,3)
#debug "\n"
#local i=i+1;
Subject: Re: Sort
Date: 2 Jan 2001 16:09:01
Message: <3a52436d$1@news.povray.org>
hehe ... ever tried to implement BOZO-Sort ???
I've heard about it and laught...
Goes like this:
1) test if the array is in the order.
2) if not then
3) a=rand(Arraysize)
4) b=rand(Arraysize)
5) swap(a,b)
6) goto 1
7) else ready
... the one who told me about that said also something that prooves, the
termination of the algorithm' if a GOOD! randomizer is used ...
I don't really know, but I think it has a kewl runtime ;-)
Jan Walzer
Subject: Re: Sort
Date: 2 Jan 2001 18:58:14
Message: <3a526b16$1@news.povray.org>
"Micha Riser" <mri### [at] datacommch> wrote in message
news:3A5### [at] datacommch...
    Not bad! It sorted in ~15 sec.s on my computer (400mhz) so I increased
it by a factor of 10 and it did it in 195 seconds.
    Takes -way- longer to display the debug info than to do the sort...
    This may be very useful, but not for what I was doing, I finished that
yesterday. It turned out that I spent much longer figuring out the sort than
I would have spent just typing in some "random" numbers...
Subject: Re: Sort
Date: 2 Jan 2001 21:46:27
Message: <3A529176.A451A3DF@faricy.net>
Of course. It's in Windows, in a tiny scrolling frame, with a tile behind it...
Subject: Re: Sort
Date: 2 Jan 2001 23:58:45
Message: <3a52b185$1@news.povray.org>
news:3A529176.A451A3DF@faricy.net...
it...
    Eh... even with messages turned off, it takes way longer.
Subject: Re: Sort
Date: 3 Jan 2001 05:22:46
Message: <3a52fd75@news.povray.org>
Jan Walzer <jan### [at] lzernet> wrote:
: ... the one who told me about that said also something that prooves, the
: termination of the algorithm' if a GOOD! randomizer is used ...
  I have the feeling that it's not possible to make algorithmically a
random number generator that is so good that the array gets sorted in a
finite time for any finite array size. I might be wrong, of course.
: I don't really know, but I think it has a kewl runtime ;-)
  Even with a perfect random number generator it sounds like the average
runtime would be infinite... Weird.
Subject: Re: Sort
Date: 3 Jan 2001 05:46:10
Message: <3a5302f2$1@news.povray.org>
"Bill Dewitt" <bde### [at] cflrrcom> wrote in message
news:3a526b16$1@news.povray.org...
than
Well, the 3 virtues of the programmer are: laziness, hubris and impatience.
Put this one down to hubris (and you've got yourself some re-usable code).
Subject: Re: Sort
Date: 4 Jan 2001 15:39:40
Message: <3a54df8c$1@news.povray.org>
hehe ... sounds kewl:
the average! runtime is infinite ... (of course, I think so) but:
this would mean, that if there are cases with runtime < oo then there have
to be other cases with a runtime > oo, but what is greater than oo ??? Yes
there certain qualities of infinity, but if you think the normal way and not
in such a mathematically weird way *g*
Jan Walzer ...
