POV-Ray : Newsgroups : povray.general : Negative diffuse settings? Server Time
26 Oct 2026 11:23:01 EDT (-0400)
  Negative diffuse settings? (Message 1 to 4 of 4)
Subject: Negative diffuse settings?
Date: 30 Nov 2000 16:40:30
Message: <3a26c94e$1@news.povray.org>
I am working on a planet earth model, and I found this cool map of the
cities at night (Thanks Jon Berndt! for the reference). I am using it as a
mostly transparent shell 0.000001 bigger than my earth image map sphere.
Now, the question. I of course want to only see the city lights on the unlit
side of earth. The easy unelegant way is to cut the sphere in half and make
sure that the city lights are applied only opposite the sun, but that
requires a knowledge of where the sun is, and more calculations than I care
to do.
Then I came up with a briliant (I thought) Idea: Set the ambient of the
shell to 0.5, then the diffuse to -0.5. My thinking is that a negative
diffuse setting means that the more light you hit it with, the darker it
gets. So a full light hitting normal to this shell should result in a total
effect of 0.5 Ambient+(-0.5 Diffuse)=0 light.
This kinda works, but not as well as I had hoped. It seems as though diffuse
is constrained to be >0. Does anyone know if this is true? Does anyone have
any better ideas?
Chris Jeppesen
Subject: Re: Negative diffuse settings?
Date: 30 Nov 2000 23:53:57
Message: <3a272ee5@news.povray.org>
Why?  Can't you use layered textures?
unlit
make
care
> to do.
I did it using a slope-dependant texture, but of course you need the
position of the sun for this...
total
I once did something similar...  A negative diffuse didn't work, I think,
but a very large negative highlight did!
I can't check it right now, but I think the following code gives more or
less the result you're after...
 location -z*5
 look_at 0
light_source {
 <500,500,-500>
 rgb 1//<0,0,1>
sphere {
 0,1
  pigment {rgb <1,1,0>}
  finish {diffuse 0 ambient 1}// specular 1 roughness .01}
  pigment {rgbt <-2,-2,0,1>}
  finish {diffuse 1 specular 1 roughness 1 metallic}
ZK
http://www.povplace.be.tf
Subject: Re: Negative diffuse settings? (ATTN: POV-Team)
Date: 1 Dec 2000 01:02:54
Message: <3a273f0e@news.povray.org>
Chris Jeppesen wrote in message <3a26c94e$1@news.povray.org>...
diffuse
>any better ideas?
A quick perusal through the POV-Ray source code reveals that yes, diffuse is
currently constrained to being greater than 0.  For anyone who cares to, the
fix is to replace the line in function Diffuse() in lighting.c that reads :
      if (Finish->Diffuse > 0.0)
with
      if(Finish->Diffuse != 0.0)
This will get rid of the limitation.  Additionally, to get rid of the
related limits on phong, specular, and irid, replace the lines that read:
        if (Finish->Phong > 0.0)
        if (Finish->Specular > 0.0)
      if (Finish->Irid > 0.0)
with
        if (Finish->Phong != 0.0)
        if (Finish->Specular != 0.0)
      if (Finish->Irid != 0.0)
respectively.
There are probably other places where settings are unnecessarily constrained
to be greater than zero.
Mark
"The derivative of sin(2x) is cos(2x)"  - Matt Giwer
Date: 1 Dec 2000 17:19:37
Message: <3A2823FA.EF6D4372@spiritone.com>
I prefer more complicated, slower methods of doing this sort of thing. In fact I
wanted to try out that very thing you suggest. I would use a radial pigmentment
map that blends between the two. I'm sure it's inelegant and very slow, though.
Josh
> to do.
> any better ideas?
> Chris Jeppesen
eng### [at] spiritonecom
