POV-Ray : Newsgroups : povray.general : POV Benchmark Windows ME - big difference between command line and GUI Server Time
5 Nov 2026 11:25:23 EST (-0500)
  POV Benchmark Windows ME - big difference between command line and GUI (Message 1 to 15 of 15)
Subject: POV Benchmark Windows ME - big difference between command line and GUI
Date: 20 Nov 2000 18:34:59
Message: <3a19b523@news.povray.org>
Just got a new computer with Windows ME and was trying the POV benchmark
(skyvase.pov).  I ran it two ways using the Standard download of v3.1g with
the following results:
1) Windows ME command line   34 sec
2) POV  GUI                             43 sec
Quite a large difference!
The command line used in 1) was run from a DOS window in the bin directory.
The command line was:
pvengine -i skyvase.pov +v1 +ft -x +mb25 +a0.300 +j1.000
+r3 -q9 -w640 -H480 -S1 -E480 -k0.000 -mv2.0 +b1000 > results.txt
In 2) the command line section was modified per POVBench instructions:
Edit settings/Render (or press Alt+C) and pasted:
+v1 -d +ft -x +a0.300 +r3 -q9 -w640 -h480 -mv2.0 +b1000
into the "Command line options" box.  Skyvase.pov was already loaded (and
was the only file loaded),
I also set the GUI priority to lowest and the Render priority to highest.
Anybody got any ideas why the difference was so large?
Jim
Subject: Re: POV Benchmark Windows ME - big difference between command line and GUI
Date: 21 Nov 2000 04:15:46
Message: <3a1a3d42@news.povray.org>
Did you try with the MSVC compile of povray?
Date: 21 Nov 2000 04:38:08
Message: <3A1A427F.5843FFB8@ij.net>
> 2) POV  GUI                             43 sec
	The usual answer is the difference is the overhead of running a windows
OS. About 25% and a bit high but that may be the new ME. It runs so many
things as cycle consuming processes that you have to expect this sort of
thing.
	Object oriented. The entire GUI screen is an object. That little PPS
number in the bottom right is a daughter process. The entire screen is
updated for that little change. I didn't make it that way, Gates did.
When roads are removed from national parks it
discriminates against the handicapped.
	-- The Iron Webmaster, 146
Date: 21 Nov 2000 07:43:25
Message: <3a1a6dec@news.povray.org>
>> 2) POV  GUI                             43 sec
> thing.
Was the first run in a dos window or in Dos (ie, restart computer in Dos
only mode)?  Also, was the image displaying?  I've found that image display
takes up a large chunk of time for no reason that I can see, so I've taken
to turning it off and only doing spot checks.
Geoff
Date: 21 Nov 2000 08:10:15
Message: <slrn91kt1o.dgt.ron.parker@fwi.com>
Is not.
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 21 Nov 2000 09:03:07
Message: <3A1A7F49.67C5DCF1@my-dejanews.com>
Can you also cite a benchmark between the new and old PC's, along with chip
type & speed, and RAM?
> 2) POV  GUI                             43 sec
Date: 21 Nov 2000 12:55:11
Message: <3a1ab6ff$1@news.povray.org>
I ran it in a DOS window under Windows ME.  I did not reboot to DOS.
Jim
"Geoff Wedig" <wed### [at] darwinepbicwruedu> wrote in message
news:3a1a6dec@news.povray.org...
benchmark
with
> >> 2) POV  GUI                             43 sec
windows
> > thing.
PPS
display
> Geoff
Date: 21 Nov 2000 12:56:06
Message: <3a1ab736$1@news.povray.org>
I used the standard downloaded executable from povray.org.  I did not
compile the source code.
Jim
news:3a1a3d42@news.povray.org...
Date: 21 Nov 2000 12:56:41
Message: <3a1ab759$1@news.povray.org>
Both runs were from the same (new) PC, one right after the other.
Jim
"Greg M. Johnson" <gre### [at] my-dejanewscom> wrote in message
news:3A1A7F49.67C5DCF1@my-dejanews.com...
chip
> > 2) POV  GUI                             43 sec
Date: 21 Nov 2000 13:47:28
Message: <3A1AC1EF.7391EC80@my-dejanews.com>
Yes I figured, but could you run it on your old PC and then tell us specs
for old & new PC?
Date: 21 Nov 2000 14:58:14
Message: <wnaqnavryffbasnyhaznvygryvnpbz.g4elew2.pminews@news.povray.org>
>2) POV  GUI                             43 sec
There's much happening "under the hood" in messagepassing operating systems.
Each time the statistics are updated on screen, Windows needs to do a few
messagepasses, clipping, etc.
In addition, Windows was designed to enhance visual feedback rather than
application performance.
....but OTOH, with a multitasking system, I find that raytracing _seems_ to
go faster than with a singletaksing system (In reality, it never will),
mainly because I can do other things while it's working. In addition, WinPov
will let you see a render window so you can see it something has gone wrong
with the scene.
With newer version of Windows, the overhead will just get larger. Either get
used to it, or boot "plain DOS" and render your large scenes using MS-DOS
versions.
 /j
Date: 21 Nov 2000 16:33:17
Message: <chrishuff-A6093C.16334021112000@news.povray.org>
In article <3A1A427F.5843FFB8@ij.net>, Matt Giwer <jul### [at] ijnet>
You posted another message lately blaming object-oriented programming
for large application sizes...do you have any actual data to back up
your claims? Do you even know what OOP is? I doubt it...and the more
likely explanations for large size and slow response are poor design,
the ability to more easily and quickly add features in an OOP framework,
and lack of incentive to optimize for speed and space because of
computers fast enough and with enough memory that these problems
disappear.
Christopher James Huff
Date: 21 Nov 2000 21:36:04
Message: <3a1b3114@news.povray.org>
On my 400 MHz NT v4 SP5 machine the results are:
Command Line Box:  75 sec
From POV GUI         90 sec
news:3A1AC1EF.7391EC80@my-dejanews.com...
> for old & new PC?
Date: 22 Nov 2000 08:00:12
Message: <3a1bc35c@news.povray.org>
"Matt Giwer" <jul### [at] ijnet> wrote in message
news:3A1A427F.5843FFB8@ij.net...
    Er, no, only the status bar window should update and repaint when the
PPS display changes - if that's not the case then you can't blame Mr Gates
and the author of the GUI is at fault.
Scott Hill.
Software Engineer.
E-Mail        : sco### [at] innocentcom
PGP Key       : http://pgpkeys.mit.edu:11371
Pandora's Box : http://www.pandora-software.com
*Everything in this message/post is purely IMHO and no-one-else's*
Date: 22 Nov 2000 08:47:43
Message: <3a1bce7f@news.povray.org>
Jim Kress <kre### [at] kressworkscom> wrote:
: I used the standard downloaded executable from povray.org.  I did not
: compile the source code.
  You don't have to. You can download the MSVC compile from povray.org.
