POV-Ray : Newsgroups : povray.general : Povray trivia Server Time
5 Nov 2026 13:03:16 EST (-0500)
  Povray trivia (Message 1 to 18 of 18)
Subject: Povray trivia
Date: 6 Nov 2000 14:23:21
Message: <3a070528@news.povray.org>
For the first time in my life I got this error from povray:
error: numeric expression expected but . (period) found instead.
  Trivia: Can you guess what causes this (ie. can you generate this error
from povray)?
Subject: Re: Povray trivia
Date: 6 Nov 2000 14:30:45
Message: <3A07073A.E0AFE4DB@pacbell.net>
> from povray)?
Give me something hard next time...
sphere{0,1 translate .}
Date: 6 Nov 2000 14:34:29
Message: <3A0707C5.B3E9AA22@schunter.etc.tu-bs.de>
> from povray)?
'rotate .' for example (i think every time a pure . is used)
It usually does not occur to me, because i usually use leading zeros.
Date: 6 Nov 2000 15:06:43
Message: <3a070f53@news.povray.org>
It happened to me when I wrote a number in the form "..2" by mistake.
Date: 6 Nov 2000 15:19:56
Message: <3a07126c@news.povray.org>
Ken <tyl### [at] pacbellnet> wrote:
: Give me something hard next time...
  Ok. Try to get this:
error: 2D-Vector expected but something bigger found.
Date: 6 Nov 2000 17:39:14
Message: <3a073312@news.povray.org>
news:3a07126c@news.povray.org...
    Haven't tried it but something like
lathe {
              linear_spline
              5,
            <2, 0>, <3, 0>, <3, 5>, something bigger, <2, 0>
Date: 6 Nov 2000 23:43:47
Message: <3A078831.7AA9844A@faricy.net>
I do stuff like that. A little too much. ;)
Date: 7 Nov 2000 00:55:35
Message: <3a079957$1@news.povray.org>
Warp wrote in message <3a07126c@news.povray.org>...
A quick search through the source code reveals that it requires an
unofficial version of POV-Ray.  Searching through the source code for
SuperPatch 3.1g indicates that it is probably a feature of MegaPOV.
Mark
Date: 7 Nov 2000 14:14:43
Message: <3a0854a3$1@news.povray.org>
LOL
Great, now I have to clean my lunch off of my monitor.  :)
Richard.
"Bill DeWitt" <the### [at] earthlinknet> wrote in message
news:3a073312@news.povray.org...
> lathe {
>               linear_spline
>               5,
Date: 8 Nov 2000 04:13:25
Message: <3a091935@news.povray.org>
Bill DeWitt <the### [at] earthlinknet> wrote:
:     Haven't tried it but something like
: lathe {
:               linear_spline
:               5,
:             <2, 0>, <3, 0>, <3, 5>, something bigger, <2, 0>
  Nope. This produces:
error: numeric expression expected but undeclared identifier 'something' found
instead.
Date: 8 Nov 2000 23:51:53
Message: <3A0A2D1A.423D546E@faricy.net>
> : lathe {
> :               linear_spline
> :               5,
instead.
YKYBRTTL if you can quote the error message exactly without running the code. :-)
Date: 9 Nov 2000 18:54:10
Message: <u8em0tc1qbr232m66uov851imej24ggm90@4ax.com>
>from povray)?
One I liked was;
too large function.  parser got bored
dav### [at] hamiltonitecom
http://hamiltonite.com/
Date: 10 Nov 2000 01:39:40
Message: <3a0b982c@news.povray.org>
David Wilkinson wrote in message ...
>>from povray)?
>One I liked was;
This one's from the isosurface function parser, and occurs when an
isosurface function contains more than (I think) 200 tokens.
Mark
Date: 10 Nov 2000 03:56:28
Message: <3a0bb83c@news.povray.org>
Warp <war### [at] tagpovrayorg> wrote in message news:3a07126c@news.povray.org...
A quick hunt through the megapov source code and a little experimentation
reveals that the following produces your error
#init_spline {"My_Spline",<0,1,0>,<1,-3>,<2,2>,<3,0>}
Gail
* gsh### [at] monotixcoza              * System.dat not found.         *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k  *
* If at first you don't succeed, call it version 1.0               *
Date: 10 Nov 2000 08:47:06
Message: <3A0BFAAD.1332429E@attglobal.net>
That's cheating!  You should be experimenting until you get the error,
not look at the source code.
Francois Labreque | My workload has become so bad that I
     flabreq      | don't have an in-basket anymore, it's
        @         | an in-filing-cabinet
  attglobal.net                       - a coworker
Date: 10 Nov 2000 08:53:05
Message: <3a0bfdc1@news.povray.org>
Francois Labreque <fla### [at] attglobalnet> wrote in message
news:3A0BFAAD.1332429E@attglobal.net...
All the source code revealed was that the error had something
to do with splines.
and I'm just using resources at my disposal <grin>
Gail
Date: 10 Nov 2000 09:42:22
Message: <3A0C094F.11BF33C@schunter.etc.tu-bs.de>
> to do with splines.
That's about as far as i proceeded, but i gave up, because i'm not very
experienced with splines :-)
Date: 10 Nov 2000 16:44:21
Message: <o1ro0toiglmmt74i2jfpss9vas674bjiae@4ax.com>
On Fri, 10 Nov 2000 01:39:48 -0500, "Mark Wagner" <mar### [at] gtenet> wrote:
>>>from povray)?
>>One I liked was;
Yes, I know, I got it with big function :-)
