For the first time in my life I got this error from povray:
error: numeric expression expected but . (period) found instead.
Trivia: Can you guess what causes this (ie. can you generate this error
from povray)?
> from povray)?
Give me something hard next time...
sphere{0,1 translate .}
> from povray)?
'rotate .' for example (i think every time a pure . is used)
It usually does not occur to me, because i usually use leading zeros.
Christoph Hormann <chr### [at] gmx de>
It happened to me when I wrote a number in the form "..2" by mistake.
Ken <tyl### [at] pacbell net> wrote:
: Give me something hard next time...
Ok. Try to get this:
error: 2D-Vector expected but something bigger found.
"Warp" <war### [at] tag povray org> wrote in message
news:3a07126c@news.povray.org...
Haven't tried it but something like
lathe {
linear_spline
5,
<2, 0>, <3, 0>, <3, 5>, something bigger, <2, 0>
I do stuff like that. A little too much. ;)
David Fontaine <dav### [at] faricy net> ICQ 55354965
My raytracing gallery: http://davidf.faricy.net/
Warp wrote in message <3a07126c@news.povray.org>...
A quick search through the source code reveals that it requires an
unofficial version of POV-Ray. Searching through the source code for
SuperPatch 3.1g indicates that it is probably a feature of MegaPOV.
Mark
LOL
Great, now I have to clean my lunch off of my monitor. :)
Richard.
"Bill DeWitt" <the### [at] earthlink net> wrote in message
news:3a073312@news.povray.org...
> lathe {
> linear_spline
> 5,
Bill DeWitt <the### [at] earthlink net> wrote:
: Haven't tried it but something like
: lathe {
: linear_spline
: 5,
: <2, 0>, <3, 0>, <3, 5>, something bigger, <2, 0>
Nope. This produces:
error: numeric expression expected but undeclared identifier 'something' found
instead.
> : lathe {
> : linear_spline
> : 5,
instead.
YKYBRTTL if you can quote the error message exactly without running the code. :-)
>from povray)?
One I liked was;
too large function. parser got bored
dav### [at] hamiltonite com
http://hamiltonite.com/
David Wilkinson wrote in message ...
>>from povray)?
>One I liked was;
This one's from the isosurface function parser, and occurs when an
isosurface function contains more than (I think) 200 tokens.
Mark
Warp <war### [at] tag povray org> wrote in message news:3a07126c@news.povray.org...
A quick hunt through the megapov source code and a little experimentation
reveals that the following produces your error
#init_spline {"My_Spline",<0,1,0>,<1,-3>,<2,2>,<3,0>}
Gail
* gsh### [at] monotix co za * System.dat not found. *
* http://www.rucus.ru.ac.za/~gail/ * Reformat hard drive Y)es O)k *
* If at first you don't succeed, call it version 1.0 *
That's cheating! You should be experimenting until you get the error,
not look at the source code.
Francois Labreque | My workload has become so bad that I
flabreq | don't have an in-basket anymore, it's
@ | an in-filing-cabinet
attglobal.net - a coworker
Francois Labreque <fla### [at] attglobal net> wrote in message
news:3A0BFAAD.1332429E@attglobal.net...
All the source code revealed was that the error had something
to do with splines.
and I'm just using resources at my disposal <grin>
Gail
> to do with splines.
That's about as far as i proceeded, but i gave up, because i'm not very
experienced with splines :-)
On Fri, 10 Nov 2000 01:39:48 -0500, "Mark Wagner" <mar### [at] gte net> wrote:
>>>from povray)?
>>One I liked was;
Yes, I know, I got it with big function :-)
