POV-Ray : Newsgroups : povray.general : Problem trying to bound a sphere Server Time
25 Aug 2025 16:44:11 EDT (-0400)
  Problem trying to bound a sphere (Message 1 to 10 of 13)
Subject: Problem trying to bound a sphere
Date: 1 Nov 2000 15:00:58
Message: <3a00767a$1@news.povray.org>
I am trying to remove all infinite objects from my source, but one object
keeps showing as infinite (found by commenting the code) which is a large
sphere that the entire scene and camera are inside.  I have tried to use
bounded_by statements but it still shows infinite.   Anybody know what I am
doing wrong?  I am trying to eliminate all the infinite objects to assist in
using the photon feature in Megapov.
#declare Globe =
object
   sphere {<0,0,0> , 2000.0
            image_map {
               tga "img0053.tga"
               map_type 1
               interpolate 4
          finish {ambient 1 }
      hollow
    //  bounded_by {sphere{<0,0,0>, 2000}}
object {Globe
Subject: Re: Problem trying to bound a sphere
Date: 1 Nov 2000 16:58:36
Message: <3a00920c@news.povray.org>
"Patrick Dugan" <pat### [at] usticom> wrote in message
news:3a00767a$1@news.povray.org...
I haven't tried it, but could it be that your bounding sphere is the same
radius as the globe - a coincident surface type problem?
Try making the bounding sphere a unit bigger? Also, shouldn't your globe be
"inverse"?
WARNING - I'm usually wrong.
Date: 1 Nov 2000 17:06:19
Message: <MPG.146aa3cb1a864ad2989830@news.povray.org>
On Wed, 1 Nov 2000 21:59:32 -0000, Tom Melly wrote...
> "inverse"?
You may be here, 'cos I think  the bounding sphere is commented out in
the code he posted there...
Oh, and I have no idea what the problem may be, since I tried a similar
scene through Moray and MeagPOV 0.6a, and nothing I did could get MegaPOV
to tell me the sphere was infinite...
<grasping at straws>
Maybe it's something to do with the image mapped texture?
</grasping at straws>
Bye for now,
     Jamie.
Date: 1 Nov 2000 17:45:44
Message: <3a009d18@news.povray.org>
"Jamie Davison" <jam### [at] dh70qdu-netcom> wrote in message
news:MPG.146aa3cb1a864ad2989830@news.povray.org...
I don't think so - one version is commented out, but he's declared his globe
as an object and bound that.
Date: 1 Nov 2000 18:34:23
Message: <3a00a87f@news.povray.org>
am
in
POV-Ray will often report large spheres as infinite objects (after a quick
test, it seems anything over 1356 units in radius).  I'm not sure what (if
any) effect this has on the rendering, as the size you have is certainly
well below the upper visibility limit.  If the infinity of the sphere is
causing problems, a fix might be to reduce the radius to 1355 units...
Date: 1 Nov 2000 19:22:28
Message: <chrishuff-4DE987.19253501112000@news.povray.org>
In article <3a00920c@news.povray.org>, "Tom Melly" <tom### [at] tomandlucouk>
Bounding shapes don't check depth, they simply test whether an
intersection is possible or not. Kind of a visibility test. It might be
possible for a problem to occur at the edges if a ray happens to just
graze the sphere(something which is practically impossible and unlikely
to produce a visible artifact if it does), but in the center of the
bounding sphere it wouldn't be a problem.
In this case, a bounding sphere that surrounds the camera, lights, and
any transparent/reflective objects should as well as a sphere
surrounding the whole sphere.
> Also, shouldn't your globe be "inverse"?
Or hollow. Inverse would make more sense, but neither is actually
necessary unless you are using media or fog.
Christopher James Huff
Date: 2 Nov 2000 01:14:42
Message: <3a010652@news.povray.org>
Patrick Dugan wrote in message <3a00767a$1@news.povray.org>...
in
Any object where the volume of the bounding box is larger than 2.0x10^10 is
considered to be an infinite object.
Mark
Date: 2 Nov 2000 08:25:15
Message: <3a016b3b@news.povray.org>
Just out of curiousity, is there any point in bounding a sphere in this
context?
Date: 2 Nov 2000 10:59:54
Message: <3a018f79@news.povray.org>
Chris Huff <chr### [at] maccom> wrote:
: Or hollow. Inverse would make more sense, but neither is actually
: necessary unless you are using media or fog.
  I think there's a third case where there's difference between an inverted
and non-inverted sky sphere: If it has (for some reason) ior.
Date: 2 Nov 2000 11:01:42
Message: <3a018fe6@news.povray.org>
: which is a large
: sphere that the entire scene and camera are inside.
  This is what's making povray to treat the sphere as infinite.
  And for a good reason. You will get no benefits from making povray to
believe that it's not infinite (povray has to test for the sphere in each
ray anyways).
