POV-Ray : Newsgroups : povray.general : Flower power Server Time
21 Oct 2026 21:49:41 EDT (-0400)
  Flower power (Message 1 to 24 of 24)
Subject: Flower power
Date: 22 Oct 2003 02:41:24
Message: <3F962693.84387F65@Rapidnet.com>
Does anybody know how to design a flower using an IsoSurface? (Is this
even possible?)
I only need the flower itself, not the stem.
Anthony D. Baye.
Subject: Re: Flower power
Date: 22 Oct 2003 09:24:36
Message: <3f968514$1@news.povray.org>
"Anthony D. Baye" <ban### [at] Rapidnetcom> wrote in message
news:3F962693.84387F65@Rapidnet.com...
> even possible?)
How elaborate a flower? Unrealistic daisy is simple. Realistic rose much
more difficult. At least from what I'm thinking it would be.
The daisy could be a radial pattern, like so:
function {
 pattern {
  radial
  scallop_wave frequency 6 // shape and number of petals
  rotate 90*x
Then used as:
isosurface {
 function {
  (x*x+y*y+z*z) // sphere shape
  FlowerPattern(x,y,z)
 contained_by {
  box {<-1,-1,-0.1>,<1,1,0.1>} // middle slice
        spherical
            color_map {
                [0.75 color rgb <1,1,1>]
                [0.8 color rgb <1,1,0>]
Bob H.
http://www.3digitaleyes.com
Date: 22 Oct 2003 17:41:19
Message: <3F96F97F.FB04E35D@Rapidnet.com>
I was thinking, like a rose or something.
                                            Anthony D. Baye
> > even possible?)
> function {
>  pattern {
>   radial
>   rotate 90*x
> Then used as:
> isosurface {
>  function {
>  contained_by {
>     pigment {
>         spherical
>             color_map {
> Bob H.
Date: 22 Oct 2003 20:08:42
Message: <3f971c0a$1@news.povray.org>
news:3F96F97F.FB04E35D@Rapidnet.com...
Suspected so, and although maybe there's some way to cobble together some
patterns I would expect a mathematical formulation could ultimately be the
answer you're looking for.
I'm probably not going to be the one who might provide that, sorry. I did
get an ugly rose-like thing using the onion pattern, having frequency of 4
and scaled larger in one direction; also turbulated a little.  :-)
I had thought this might be something already done by someone before but I
sure can't locate anything concerning a isosurface flower. I suppose I'm
thinking of meshes.
Bob H.
Date: 22 Oct 2003 20:33:09
Message: <cjameshuff-EEBD5F.20310222102003@netplex.aussie.org>
In article <3f971c0a$1@news.povray.org>,
> thinking of meshes.
I did this a *long* time ago, when I was first playing around with
isosurfaces. It was basically an extremely distorted sphere function,
and looked a bit like a fat rose. A mesh certainly seems like a better
choice, however.
http://tag.povray.org/
Date: 22 Oct 2003 23:48:22
Message: <MPG.1a00fb8641b5c8e6989901@news.povray.org>
In article <cja### [at] netplexaussieorg>,
cja### [at] earthlinknet says...
> > thinking of meshes.
> choice, however.
In theory:
http://mathworld.wolfram.com/StarrRose.html
However, since they don't actually provide the equations for it, but
simply assume you know how to derive it from the 2D calcs in:
http://mathworld.wolfram.com/Rose.html
It isn't very helpful. Especially since I can't figure out what 'a' needs
to be or do to make Rose calcs work right either....
In my case I am trying to do something like:
N = 5 * rnd
vdelta = 2 * PI * rnd
vector = a * sin(N * vdelta)
X = cos(vector) * 30
Y = sin(vector) * 30
The problem is all I get is a dang circle... It is driving me batty. If
it was for something in POV, it would be driving me even more nuts. But
man would the StarrRose make a real nice Isosurface. Sigh...
void main () {
  If Schrödingers_cat is alive
    call functional_code()
  else
    call crash_windows();
Date: 23 Oct 2003 02:04:26
Message: <KwnOiDA022l$EwP5@econym.demon.co.uk>
>N = 5 * rnd
I think that N should be a constant (it's the number of petals or half
the number of petals depending on whether it's odd or even) and X and Y
should be cos(vdelta)*vector and sin(vdelta)*vector. "a" is a scaling
factor, the maximum radius of the whole shape
So:-
#version 3.5;
global_settings {assumed_gamma 1.0}
camera {location  <0,0,-10> look_at <0,0,0> angle 50}
background {rgb 1}
light_source {<-30, 100, -30> color rgb 1}
#declare rnd=0;
#declare N = 5;
#declare a=3;
#while (rnd < 1)
  #declare vdelta = 2 * pi * rnd;
  #declare vector = a * sin(N * vdelta);
  #declare X = cos(vdelta) * vector;
  #declare Y = sin(vdelta) * vector;
    sphere {<X,Y,0>,0.2 pigment {rgb <1,1,0>}}
  #declare rnd = rnd + 0.001;
If we bung the significant bit "vector = a * sin(N * vdelta)" into an
isosurface it looks like this "a * sin(N * f_th(x,z,y))", which doesn't
do anything useful on it's own but suggests something like this:-
#version 3.5;
camera { location  <-1, 1, -6> look_at <0, 0, 0> angle 50}
background {rgb 1}
#include "functions.inc"
#declare n = 5;
#declare a = 2;
isosurface {
  function { a * sin(n*f_th(x,z,y)) * f_sphere(x,y,z,a) + 0.1}
  max_gradient 20
  contained_by{sphere{0,a}}
  pigment {rgb .9}
  finish {phong 0.5 phong_size 10}
Date: 23 Oct 2003 02:04:29
Message: <KwmOyHAw32l$EwvN@econym.demon.co.uk>
That could be made a little more realistic, like:-
#version 3.5;
camera {location  <-1,0,-2> look_at <0,0,0> angle 50}
background {rgb 1}
light_source {<-10, 10, -30> color rgb 1}
#declare FlowerPattern =
function {
 pattern {
  radial
  rotate 90*x
isosurface {
 function {
  (x*x+y*y+z*z*20) // sphere shape
  + f_noise3d(x*6,y*6,0)*0.5
 contained_by {
  box {<-1,-1,0>,<1,1,0.4>}
 open
 max_gradient 20
   cylindrical
   color_map {
     [0.2    color rgb <1,0.7,0.7>]
     [0.25  color rgb <1,1,1>]
   rotate x*90
Date: 23 Oct 2003 08:40:01
Message: <web.3f97cb44a022f3b88062416c0@news.povray.org>
Patrick Elliott wrote:
>In theory:
You can extend 2D polar functions to 3D in a variety of ways.  One is via
spherical products.
See:
http://news.povray.org/povray.binaries.images/32476/
for a few examples.  I use Ingo's "param.inc" and turn everything into
meshes, since it's faster, but you could also use the "parametric" object
from POVRay.
I don't know if this will give you what you want, but it does give some
rather interesting "3D mathematical flowers."
Dave Matthews
Date: 23 Oct 2003 12:41:45
Message: <3F9804C7.2CC33998@Rapidnet.com>
Does anyone know where I might find a dxf or obj model of, say, a
lotus?  I don't understand half of the math that was just thrown around
here, and I can't afford the one patch modeller I've been able to find
for the Mac.
A.D.B
> even possible?)
> Anthony D. Baye.
Date: 23 Oct 2003 13:01:45
Message: <rd7WpEAGW7l$EwZc@econym.demon.co.uk>
>In theory:
They do give the method for producing the Maurer Rose
http://icl.pku.edu.cn/yujs/MathWorld/math/m/m108.htm
which can be achieved in POV like this. My guess is that the Starr Rose
just uses some other stepping algorithm, but I can't guess what. I think
the 3d effect of the Starr is an optical illusion, and that it's
actually flat like the Maurer.
This doesn't seem to be moving in the direction of isosurface flowers.
#version 3.5;
camera {location  <0,0,-9> look_at <0,0,0> angle 50}
background {rgb 1}
// The parameters a, n and d are the same as those on
// http://mathworld.wolfram.com/Rose.html
// and
// http://icl.pku.edu.cn/yujs/MathWorld/math/m/m108.htm
// i.e. a = scale
//      n = petal number
//      d = step length in degrees
// Lines = number of lines to be drawn
// Width = width of line
#macro Maurer(a,n,d,Lines,Width)
 union {
 #local rad=radians(d);
 #local T=0;
 #while (T < 2*pi)
  #local r=a * sin(n*T);
  #local X=r*sin(T);
  #local Y=r*cos(T);
  #local r2=a * sin(n*T+rad);
  #local X2=r2*sin(T+rad);
  #local Y2=r2*cos(T+rad);
  #if (X!=X2 | Y!=Y2)
    cylinder {<X,Y,0>,<X2,Y2,0>,Width}
  #local T=T+2*pi/Lines;
object {Maurer(2.1,4,120,360,0.005)
   pigment {rgb 0}
   translate -2*x
object {Maurer(2.1,6,72,360,0.005)
   pigment {rgb 0}
   translate 2*x
Date: 23 Oct 2003 17:31:02
Message: <MPG.1a01f4943b4461b8989906@news.povray.org>
In article <KwnOiDA022l$EwP5@econym.demon.co.uk>,
nos### [at] econymdemoncouk says...
> >N = 5 * rnd
> So:-
> #version 3.5;
> background {rgb 1}
> #declare rnd=0;
> #declare N = 5;
> #declare a=3;
> #while (rnd < 1)
> #end
Heh! That works. Was screwed up on the correct way to convert polar to
rectangular. :p
> #version 3.5;
> background {rgb 1}
> #declare n = 5;
> #declare a = 2;
> isosurface {
>   max_gradient 20
>   pigment {rgb .9}
Yeah. I wondered about shoe horning a useful Z axis into that. The
StarrRose uses a, b and c as scales, which I think implies it already
accounts for z, but lacking the equations to define how those are used...
:p
Like I said though, my own problem wasn't for use in POV, I just thought
I would ask about it, since the two things are closely related, at least
with respect to the basic equations. I am actually designing an ActiveX
control that generates a 2D firework. The X and Y are used as velocity
vectors so that all the points starts at a central position and drift
outward, losing X velocity slightly and gaining Y velocity towards the
ground with each time is draws. Works nice for stuff I could make work
right, but I completely missed the obvious fact that with X = cos(Delta)
* r and Y = sin(Delta) * r, r was actually what I had as 'vector'.
Sigh... Shows you how much I know about math..
However, I stand by the statement that, as a reference sight for
equations, the fact that this site seem to be the 'only' one with a
decent list doesn't mean it is a complete or accurate one. I would love
to actually know how they got that StarrRose. :(
void main () {
  else
Date: 23 Oct 2003 17:38:14
Message: <MPG.1a01f6489951439d989907@news.povray.org>
In article <rd7WpEAGW7l$EwZc@econym.demon.co.uk>,
> >In theory:
Yeah. Someone that is a math wiz suggested that may be the case. I think
if you knew what you where doing you could fudge it though. Use one of
those calcs that produce:
for the z axis some how with the current radius from the center defining
where on that path the point lies. I have no clue how to manage it
though. However, I would think it would be possible. How well it
would works is another matter.
void main () {
  else
Date: 24 Oct 2003 01:04:56
Message: <Dx6cyEAP+Hm$EwGW@econym.demon.co.uk>
> I would love to actually know how they got that StarrRose. :(
If you feel strongly enough about it to go out and buy the book that
they got the equation from, then perhaps you could let us know.
Mike Williams
Gentleman of Leisure
Date: 24 Oct 2003 09:25:01
Message: <web.3f9927d7a022f3b88062416c0@news.povray.org>
>Mike Williams
No need, someone already has the book.
What's going on here is a simple parametric curve, "doctored up" to look 3D.
 But we can do something similar in PovRay.
The radius varies according to a set function:  2 + sin(At)/2, creating an
"opened-up" rose.
The twist is that the angle, rather than simply proceeding counter-clockwise
around the circle, backs up on itself, NewT = t + Sin(Bt)/C, so that we
have the modified parametric equations:
x = r(t)cos(NewT), y = r(t)sin(NewT).
All of the shading is done by connecting the origin to the edge of the
curve, then shrinking and superimposing repeated copies of the image on
itself.
We can get one version of this by letting the vertical (y) component vary
according to r(t).
//Starr Rose For PovRay
#version 3.5;
#global_settings { assumed_gamma 1.0 }
camera {        angle 50
                location <0, 50, 0>
                look_at <0, 0, 0>
light_source { <800, 1200, -500> color rgb <1, 1, 1> }
#macro Starr_Rose(A, B, C, N)
  #local Radius= function(Theta) {2 + sin(A*Theta)/2}
  #local AngleShift = function(Theta) {sin(B*Theta)/C}
  #local Angle = 0;
  #local Cycle = 2*pi;
  union {
  #while (Angle <= Cycle)
       #local X = Radius(Angle)*cos(Angle + AngleShift(Angle));
       #local Z = Radius(Angle)*sin(Angle + AngleShift(Angle));
       #local Y = 2 - Radius(Angle) ;
       cylinder { <0, 0, 0>, <X, Y, Z>, 0.05 }
    #local Angle = Angle + Cycle/N;
object { Starr_Rose(6, 18, 18, 500) texture { pigment { color rgb <1, 0, 0>
                                    scale 5}
/////////////////End of Code
I'm guessing that one of you with more experience at POVRay can do up a
better version, but this gives the idea.
Date: 24 Oct 2003 16:58:18
Message: <MPG.1a033e55a2de90bd989909@news.povray.org>
In article <web.3f9927d7a022f3b88062416c0@news.povray.org>,
dma### [at] wrmnwestmnscuedu says...
> >Mike Williams
> "opened-up" rose.
> itself.
> according to r(t).
> #version 3.5;
> camera {        angle 50
>                 location <0, 50, 0>
>                 look_at <0, 0, 0>
>   #local Angle = 0;
>   union {
>   #end
> #end
>                                     scale 5}
Oooh! Nice! Now if someone could find a way to tweak it so it makes the
petals more petal like. But that is way more than I could have ever
managed. lol
void main () {
  else
Date: 24 Oct 2003 18:34:19
Message: <cjameshuff-BB159D.18321124102003@netplex.aussie.org>
In article <3F9804C7.2CC33998@Rapidnet.com>,
> for the Mac.
One? MeshWork is $30 shareware: http://codenautics.com/meshwork/
PatchDance is free: http://www.patchdance.com/
jPatch is free:
http://jpatch.sourceforge.net/?page=platforms
Other modellers (free):
Mondfarilo: http://userpages.itis.com/philip/
Art Of Illusion: http://www.artofillusion.org/
And more...
If you have OS X, you can also run most Linux modellers.
Date: 24 Oct 2003 23:45:30
Message: <RoQIUCAntem$Ew0Z@econym.demon.co.uk>
>managed. lol
Now we have the formula, we can turn that into a parametric isosurface.
Then we can do things like adding noise to make it less perfectly
symmetrical.
#version 3.5;
#declare A=6;      // Number of petals
#declare B=3*A;    // Ripple frequency
#declare C=B;      // Ripple strength (inverse)
#declare Approx = true; // true = use Ingo's param.inc approximation
                        // false = use parametric isosurface
#declare Noise = 0.3;   // Amount of noise
camera {location  <0,0,-10> look_at <0,0,0> angle 40}
background {rgb 1}
#declare Radius = function(Theta) {2 + sin(A*Theta)/2}
#declare AngleShift = function(Theta) {sin(B*Theta)/C}
#declare Fx = function(u,v) {Radius(u) * cos(u + AngleShift(u)) * v}
#declare Fy = function(u,v) {Radius(u) * sin(u + AngleShift(u)) * v}
#declare Fz = function(u,v) {2 - Radius(u) +
f_noise3d(u*10,v*5,0)*Noise}
#if (Approx)
  #include "param.inc"
  #if (Noise = 0)
    #declare U=500;
    #declare V=1;
  #else
    #declare U=200;
    #declare V=20;
  object {
    Parametric(Fx,Fy,Fz,<0,0>,<2*pi,1>,U,V,"")
    pigment {rgb x}
#else
  parametric {
    function {Fx(u,v)}
    function {Fy(u,v)}
    function {Fz(u,v)}
      <0,0>,<2*pi,1>
    max_gradient 2
    contained_by{box{<-2.6,-2.6,-0.5><2.6,2.6,0.5>}}
    pigment {rgb x}
Date: 25 Oct 2003 01:57:01
Message: <93SzzCAtBhm$EwAC@econym.demon.co.uk>
And how about this for a Dahlia?
I've removed the option to use a real parametric isosurface because it
was taking too long to render - it now requires Ingo Janssen's
param.inc.
//Dahlia
#version 3.5;
#declare W=4;           // Winding number
#declare A=9.4;         // Number of petals per wind
#declare B=2*A;         // Ripple frequency
#declare C=B*2;         // Ripple strength (inverse)
#declare WW = 2*pi*W;
#declare Q=WW*1.5;
background {rgb 1}
#declare Radius = function(Theta) {2 + sin(A*(Theta-pi/2))/2}
#declare AngleShift = function(Theta) {sin(B*(Theta-pi/2))/C}
        cos(u + AngleShift(u)) * v *(1-u/Q)}
        sin(u + AngleShift(u)) * v *(1-u/Q)}
         + f_noise3d(u*10,v*5,0)*Noise - u/WW}
#if (Noise = 0)
  #declare U=500*W;
  #declare V=1;
#else
  #declare U=200*W;
  #declare V=20;
object {
  Parametric(Fx,Fy,Fz,<0,0>,<WW,1>,U,V,"")
  pigment {onion
   colour_map {
     [0.5 rgb <1,1,0>]
     [0.8 rgb <1,0,0>]
   scale <2.5,2.5,2>
Date: 25 Oct 2003 11:02:40
Message: <3F9A908E.A34F163A@Rapidnet.com>
Either there's a newer version of Param.inc than the one that I found in
the news group or there's something else going on, because I can't get it
to render.
A.D.B.
> param.inc.
> //Dahlia
> #version 3.5;
> #declare Q=WW*1.5;
> background {rgb 1}
> #if (Noise = 0)
>   #declare U=500*W;
>   #declare V=1;
> #else
>   #declare U=200*W;
>   #declare V=20;
> #end
> object {
>   pigment {onion
>    colour_map {
>      [0.5 rgb <1,1,0>]
>      [0.8 rgb <1,0,0>]
>    scale <2.5,2.5,2>
Date: 25 Oct 2003 11:33:51
Message: <ivu01BAcepm$Ewjy@econym.demon.co.uk>
>to render.
I believe he changed the syntax sometime early in 2002 to make it more
like 3.5 syntax. You can get the latest version from
        <http://members.home.nl/seedseven/>
You need the "Meshmerizing Mesh Maker Macros" file, and from the zip you
need param.inc and makemesh.inc.
Mike Williams
Date: 25 Oct 2003 15:30:26
Message: <MPG.1a047b4117720b7098990a@news.povray.org>
In article <93SzzCAtBhm$EwAC@econym.demon.co.uk>,
Hmm. That actually works better than the StarrRose, which really needs to
bend inward to form more of a bell shape. Wish I had any where near as
much understanding of the math as you...
void main () {
  else
Date: 27 Oct 2003 08:15:01
Message: <web.3f9d1a24a022f3b88062416c0@news.povray.org>
Very Nice.
Dave Matthews
Date: 28 Oct 2003 19:28:29
Message: <3f9f09ad@news.povray.org>
Here is a blank for a parametric object include file:
// Parametric variable form
#declare uMin = 0; // Minimum u value
#declare uMax = pi; // Maximum u value
#declare uNum = 45; // Number of points in u direction
#declare uWrap = 0; // u wraps around if != 0
#declare uSeed = 7335; // Random number seed for u parameter
#declare vMin = 0; // Minimum v value
#declare vMax = radians(359); // Maximum v value
#declare vNum = 360; // Number of points in v direction
#declare vWrap = 1; // v wraps around if != 0
#declare vSeed = 2252; // Random number seed for v parameter
#declare IsRnd = true; // True if random number used
#declare IsUV = false; // True if object is to be UV-mapped
#declare Smooth = 0; // Smooth flag
#declare Detail = "Partial"
/* Detail values
  Verbose = Line by line details
  Partial = Operations only
  Other = Filename only
/* For all macro functions
 i = Current value of u parameter
 j = Current value of v parameter
 p = Current value of u variance (0...1)
 q = Current value of v variance (0...1)
 vc= Current 3D point
// Optional variables and subfunctions
// point function
#macro pnt(i, j, p, q)
 #local xp = sin(i)*cos(j);
 #local yp = pow(cos(i)+1, 2);
 #local zp = sin(i)*sin(j);
 #local pt0 = <xp,yp,zp>*(1+0.1*q);
 pt0
How would a rose be defined using this format?  The include file may contain
#declare and #local variables as well as other #macros.
"Dave Matthews" <dma### [at] wrmnwestmnscuedu> wrote in message
news:web.3f9927d7a022f3b88062416c0@news.povray.org...
> >Mike Williams
3D.
> "opened-up" rose.
counter-clockwise
> itself.
> according to r(t).
> #version 3.5;
> camera {        angle 50
>                 location <0, 50, 0>
>                 look_at <0, 0, 0>
>   #local Angle = 0;
>   union {
>   #end
> #end
0>
>                                     scale 5}
