POV-Ray : Newsgroups : povray.general : Help Creating parabolic mirrors Server Time
2 Nov 2026 06:10:20 EST (-0500)
  Help Creating parabolic mirrors (Message 1 to 21 of 21)
Subject: Help Creating parabolic mirrors
Date: 7 Aug 2003 14:15:37
Message: <3F32970D.2020305@comcast.net>
If anyone has the time I could sure use some help creating three objects
First an annular parabolic mirror.
-Made of solid glass or hollow
-Having an adjustable parabolic curve in order to change the focal length
It would look like a clear or hollow  parabolic torus cut in half with
its interior surface mirrored, interior media clear or hollow and its
exterior opaque.
Second a parabolic mirror
-Made of glass and hollow
It would look like a parabolic bowl with its interior surface mirrored,
interior media clear or hollow, and its exterior surface opaque
Third an omni-directional mirror
-Having an semitransparent external mirror coating while the interior
would be fully transparent
It would look like a cone with a rounded apex with its exterior surface
  coated with a semitransparent mirrored interior surface fully transparent
Thanks
Subject: Re: Help Creating parabolic mirrors
Date: 8 Aug 2003 03:14:35
Message: <3f334ddb$1@news.povray.org>
You can create paraboloids using the quadric object.
Here's a mirror as it is used in a Newton reflector-telescope:
#default {
	pigment { color rgb <1,1,1> }
	finish { ambient 0.5 diffuse 0.5 }
#declare focal_length = 10;
#declare ms = 1/4/focal_length;
#declare mainMirror = difference {
	cylinder { <0.01,0,0>,<-ms,0,0>,1 }
	quadric {
		<0,1,1>,<0,0,0>,<1,0,0>,0
		scale <ms,1,1>
		finish { ambient 0 diffuse 0 reflection 1 }
plane { y,-2 pigment { checker } }
light_source { <-100,100,0> color rgb <1,1,1> }
camera { location <-3,1,-3> look_at <0,0,0> }
object { mainMirror }
Date: 10 Aug 2003 13:26:21
Message: <3f36803d@news.povray.org>
Wouldn't it be easier to use a lathe with _quadratic_
spline for the parabolic mirror?
Wolfgang
Date: 10 Aug 2003 14:31:00
Message: <cjameshuff-02BCEE.13281510082003@netplex.aussie.org>
In article <3f36803d@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
The easiest way would be to use an isosurface, a quadric is probably the
most efficient way. I wouldn't use a lathe, though it would work.
There are paraboloid shapes based on the quadric primitive in
shapes_old.inc.
http://tag.povray.org/
Date: 10 Aug 2003 15:03:27
Message: <3f3696fe@news.povray.org>
A paraboloid is essentially y=x^2 rotated around the Y axis (isn't it??)
So, using a quadratic spline and modelling just that y=x^2 curve
seems to me the most natural approach to me.
Why should I use a quadric? Is it really faster than a lathe?
Wolfgang
Date: 10 Aug 2003 17:54:07
Message: <3f36beff$1@news.povray.org>
I hope this isn't a patronizing question, but I fear you may be expecting a
raytracer to do something it cannot.  I once spent a weekend trying to use
CorelDream3D to make my own "spotlight":  a parabolic mirror with a light
source in it.  It don't work.
You'll need to use photons if you want to make "optical" use of such a
surface.
Date: 10 Aug 2003 18:09:43
Message: <3f36c2a6@news.povray.org>
  A quadric will be mathematically accurate (inside the limits of
floating point accuracy), while a lathe will only be an approximation.
  As for speed, the quadric is probably faster.
Date: 10 Aug 2003 18:10:40
Message: <3f36c2e0@news.povray.org>
  POV-Ray can make perfectly parabolic mirrors and reflect light from
them. It's far from impossible.
Date: 10 Aug 2003 18:44:09
Message: <cjameshuff-213C69.17411010082003@netplex.aussie.org>
In article <3f3696fe@news.povray.org>, Wolfgang Wieser <wwi### [at] gmxde>
A more precise description would be "y = x^2 + z^2", though it is
equivalent to sweeping a 2D curve as you described.
A quadric would be a paraboloid, while a lathe would just look like one.
As for speed, a lathe is a far more complex object. I would expect
slower rendering and much higher probability of artifacts. Also,
although there is a quadratic spline, it may not give the expected
result, and would be a bit more awkward to control...splines are
generally not used for precise mathematical curves. A lathe *can* be
used for this, but it is certainly not the best tool for the job. An
isosurface or quadric would be a perfect match for this task. A quadric
is more difficult to use than an isosurface, but the isosurface will be
less precise. Either one may be faster, it depends on the situation.
And finally, there are already predefined paraboloid quadrics in the
includes...
Date: 10 Aug 2003 18:47:39
Message: <3F36CCF5.F8EB095E@pacbell.net>
If it looks like a duck and it quacks like a duck...
Ken Tyler
Date: 10 Aug 2003 19:34:08
Message: <3f36d670@news.povray.org>
  If it's not a mathematically perfect paraboloid you might get some
bumps or other unwanted distortions.
Date: 11 Aug 2003 03:37:23
Message: <3f3747b3$1@news.povray.org>
Well, I think it's *nearly* impossible to simulate optical instruments
like telescopes with POV-Ray. Of course you could place the camera at
the focal-point of the lens or mirror and get the magnification effect,
but you can't simulate other effects.
For example, I once tried to simulate how saturn would look if being
viewed through a telescope with different mirror-diameters (the larger
the mirror, the sharper the picture) - but it didn't work. If anybody
has ever managed to simulate such things with POV-Ray I'd be interested...
Date: 11 Aug 2003 05:49:57
Message: <3f3766c5$1@news.povray.org>
Some things can be simulated, but I think (based on what I have found with
my experiments) that the resolution of the image being "magnified" is the
problem- it breaks into big fuzzy blocks.
Cheers!
Chip Shults
Date: 11 Aug 2003 09:45:03
Message: <3f379ddf$1@news.povray.org>
Thanks to all for the clarification.
Any human eye objects-models out there?
Michael
news:3f36d670@news.povray.org...
one.
x]
Warp -
Date: 11 Aug 2003 10:01:33
Message: <3f37a1b3.8511418@news.povray.org>
On Mon, 11 Aug 2003 09:46:43 -0400, "Michael" <mji### [at] netscapenet> wrote:
>Michael
The site is down as I write but try
http://www.3dcafe.com/asp/freestuff.asp
Regards
Date: 11 Aug 2003 11:14:47
Message: <cjameshuff-00E4F3.10113611082003@netplex.aussie.org>
In article <3f3747b3$1@news.povray.org>,
Telescopes could be done even without photons. A reflecting telescope
could be done in any version of POV that supported reflection, a
refracting one in any version supporting refraction.
>  Of course you could place the camera at the focal-point of the lens
You can put the camera at the eyepiece, as you would do with a
real-world camera and telescope.
You mean wave effects like diffraction? It is true you can't simulate
it, though you could fake it if you really wanted. POV is not designed
for optics simulations, but it is a lot more powerful than you seem to
think.
Well, with astronomical telescopes, you will just run into precision
problems. This has nothing to do with how well POV simulates optics.
Date: 11 Aug 2003 12:20:55
Message: <3f37c267$1@news.povray.org>
I was refering to another effect which makes objects appear blurry in a
telescope. I'm not sure what causes this effect, but I think it is
bacause the mirror (a paraboloid) will focus only parallel rays (the
object to be viewed must be either a point or ininitely far away). A
planet is neither of both, so not all the light from the planet will be
focused an the same plane, resulting in a blurry image. It gets better
if you use a larger mirror (I guess that's the reason why they use 8
meter mirrors in the VLT :-)
I'm not an astronomer, so I'm not sure about all this!
Maybe this effect can be simulated with POVs focal blur somehow, but I
didn't get it to work.
Date: 11 Aug 2003 13:21:33
Message: <3f37d09d@news.povray.org>
The main reason for using large telescopes (with large mirrors) is they
receive more light and so allow astronomers to study fainter and more
distant objects.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Date: 11 Aug 2003 13:54:06
Message: <grK00IAhe9N$Ew6j@econym.demon.co.uk>
>distant objects.
But there is also the effect of diffraction limited resolution.
Diffraction can cause two closely spaced light sources to appear to be a
single source. It's purely a wave effect, so a ray tracer (even one that
fires photons) won't naturally simulate the effect.
By the time the light from Saturn gets here, the wave fronts are
effectively planar. The wave fronts associated with two different points
on the surface of Saturn are at a slight angle to each other. To a first
approximation (further approximations get quite complicated[1]) for a
perfect mirror, if the angle is insufficient to cause the waves to be in
phase at one edge of the mirror and half a wavelength out of phase at
the opposite edge, then the two points cannot be resolved.
With a wider aperture, the angle between the waves that gives a half-
wavelength difference is smaller and so closer objects can be resolved.
[1]<http://www.pha.jhu.edu/~jlotz/aoptics/node2.html>
Mike Williams
Gentleman of Leisure
Date: 11 Aug 2003 21:05:07
Message: <3f383d43$1@news.povray.org>
Okay, make me a spotlight using  a parabolic mirror, while reflecting light,
and as clearly indicated from my context, not use photons...
Date: 12 Aug 2003 06:18:08
Message: <3f38bedf@news.povray.org>
> not use photons...
  Why not?
  You said that a raytracer couldn't do it. Of course it can do it.
Photon mapping is raytracing by all definitions of the word.
