POV-Ray : Newsgroups : povray.general : Scaling macros? Server Time
22 Oct 2026 02:04:34 EDT (-0400)
  Scaling macros? (Message 1 to 15 of 15)
Subject: Scaling macros?
Date: 29 Jul 2003 13:05:37
Message: <3F26A95E.4D3834F1@hotmail.com>
Let's say I design a scene using centimeters.  You design a model using
meters, or some English unit.
Who would find a set of relatively automatic scale converters
useful?
The way I envision them, the scene builder calls one macro early in
the scene:
  ExpectMeters()
while the model maker calls another macro in their code:
union {
  sphere { pHere,rSize }
  // etc
  UseCentimeters()
The two macros work together to make sure that the latter item is
scaled properly (in this example, by 1/100).
Except for models using IK, the macros are pretty easy to do.  Any
takers?
John
PS:  Pardon me if this has been done.
Subject: Re: Scaling macros?
Date: 29 Jul 2003 13:41:45
Message: <cjameshuff-DE318D.12414529072003@netplex.aussie.org>
In article <3F26A95E.4D3834F1@hotmail.com>,
> useful?
What I do is just define cm, mm, m, km, etc at the beginning of the
scene. Then I just do something like "15.7*m" when specifying a
dimension. A macro version could also work, something like: "km(45)"
I do use lowercase identifiers here, but I don't think a collision is
likely for these and it helps separate them from the rest of the code.
> union {
>   // etc
>   UseCentimeters()
I think this is a bit harder to read, putting the units separate from
the values, and it might slow things down by forcing transformations to
be evaluated unnecessarily, especially in the case of CSG.
union {
  sphere { pHere*cm, rSize*cm }
  // etc
union {
  sphere { pHere, rSize scale cm}
  // etc
http://tag.povray.org/
Date: 29 Jul 2003 15:40:00
Message: <web.3f26cd289c12b5437196f5900@news.povray.org>
>dimension.
What a simple, convenient, smart, clean way to do things.  How come I don't
think like that?
As long as others do, and I copy your ideas, I guess I'm ok.
Thanks for the tip.
I'll be using it a lot.
Dave Matthews
Date: 29 Jul 2003 17:05:01
Message: <web.3f26e01d9c12b543a0c272b50@news.povray.org>
>useful?
>the scene:
>  ExpectMeters()
>union {
>  // etc
>  UseCentimeters()
Well, being UScentric, I have been using (usually) 1 pov unit = 1 Ft.  I
don't usually use other people's models so haven't had a problem, but as my
model collection grows I've been thinking about posting some of them to the
Pov-Ray object library, so I suppose others might find that useful.
I usually do basically what Chris described, defining my units at the start
of the file like #declare Ft = 1; #declare In = Ft/12; etc and using
something like 'translate x*14.25*Ft' or '#declare Rad = 5.5*In'.  Not sure
how your macro would handle that.
But this is something I have been wondering myself, how others deal with
different scalings and unit sizes.  I've tried to keep all of mine together
and right at the top of the file so if someone wanted to do their own
conversion it shouldn't be too difficult.
How do all you POV masters handle your units?
RG
Date: 29 Jul 2003 17:53:22
Message: <cjameshuff-BD125F.16532229072003@netplex.aussie.org>
In article <web.3f26e01d9c12b543a0c272b50@news.povray.org>,
You could also base them all off of one value:
#declare m = 1;
#declare cm = m/100;
#declare mm = m/1000;
#declare km = m*1000;
#declare in = m/0.0254;
#declare ft = in*12;
#declare yd = ft*3;
#declare mi = km/1.607347;
This way, you only have one constant to change...the number of units in
a meter, in this case. If everyone uses the same unit names, all you
have to do is change that value. (or just remove it and place it
elsewhere, such as in a "units.inc" file)
Date: 29 Jul 2003 20:03:40
Message: <pan.2003.07.30.00.07.09.69031@THISSHOULDBEREMOVEDhotmail.com>
Hmmm... Are you sure about this Christopher ?
Tor Olav
Date: 29 Jul 2003 20:11:54
Message: <cjameshuff-2BF323.19115429072003@netplex.aussie.org>
In article
<pan### [at] THISSHOULDBEREMOVEDhotmailcom>,
 "Tor Olav Kristensen" <tor### [at] THISSHOULDBEREMOVEDhotmailcom>
Ah...I guess that should be multiplication, shouldn't it...
Date: 29 Jul 2003 20:45:13
Message: <pan.2003.07.30.00.48.41.771613@THISSHOULDBEREMOVEDhotmail.com>
On Tue, 29 Jul 2003 19:11:54 -0500, Christopher James Huff wrote:
> In article
Yes (Unless you have very long inches in the US)
Tor Olav
Date: 30 Jul 2003 04:59:39
Message: <3F2788FA.1050401@spam.fr>
Cool thread, it's always interesting to see how others handle common
problems.
I use to define all my models in meters. And when it is not appropriate
I define the object in centimeters for example and then I scale the
whole model to meters. I do the same with models I get from outside.
JC
> useful?
> the scene:
>   ExpectMeters()
> union {
>   // etc
>   UseCentimeters()
> takers?
> Regards,
> John
Date: 30 Jul 2003 21:06:20
Message: <3f286b8c@news.povray.org>
> #declare m = 1;
I strongly suggest to use MUCH larger values if possible; see my
thread "Small is NOT BEAUTIFUL" in p.g, 11 Feb. 2003. Especially
transparency, almost-coincident surfaces and shadows are highly
problematic. For indoor scenes of "normal" scale I suggest to
use 1 POV-unit = 1 mm or less.
   Sputnik
P.S. If the sphere in the second "Small is NOT BEAUTIFUL" demo scene
     is removed, then all errors are reduced by about three orders
     of magnitude -- try with scale 0.004!
Date: 31 Jul 2003 02:46:40
Message: <Xns93C91C153F90Etomatimporg@204.213.191.226>
John VanSickle <evi### [at] hotmailcom> wrote in
news:3F26A95E.4D3834F1@hotmail.com:
Sonya Roberts did it in 1997 ;)  From micrometer to lightyear
http://www.imp.org/media/archives/units.zip
Tom
_________________________________
The Internet Movie Project
http://www.imp.org/
Date: 31 Jul 2003 20:10:07
Message: <p08jivktnf5qlirl72lvq9uaumf37fi1qf@4ax.com>
Also sprach Christopher James Huff <cja### [at] earthlinknet> -- Tue, 29 Jul
2003 12:41:45 -0500:
I do a similar thing.
#declare inches=1;
#declare inch=1;
#declare feet=12*inches;
#declare foot=feet;
which makes it nice to say
#declare blah=6*feet+4*inches;	// super American dumbkopf mode of measuring.
One of the important things (to me) in modeling is to remember to scale
*everything*.
This construct is guaranteed to cause trouble:
#declare mysize=4*inches;
difference {
	box {
		<-mysize/2,-mysize/2,-mysize/2>
		<mysize/2,mysize/2,mysize/2>
	cylinder {
		z*-mysize/2-1, z*mysize/2+1			// <-- evil plus and minus 1
		1*inches
I always used +/- 1 (or 100) when doing CSG, to avoid coincidence.
When i started rescaling my objects (#declare feet=1; #declare inch=1/12;)
these +/- 1s really bit me in the butt.  It's important to say
		z*-mysize/2-1*inch, z*mysize/2+1*inch
I also have a couple of non linear predefines:
#declare pi2=pi*2;
#declare rot180=pi;
#declare rot90=pi/2;
#declare rot45=pi/4;
which are useful in sin and cos.
dik
Date: 1 Aug 2003 05:30:36
Message: <pan.2003.08.01.09.30.31.726050.352@gte.net>
On Tue, 29 Jul 2003 14:01:39 -0700, gonzo quoth:
I've got a file that I include called "units.inc" that defines assorted
units of measurement in terms of each other.  It defaults to 1 cm = 1 POV
unit, but if I change the definition of a centimeter before including the
file, it adjusts all units accordingly.  This way, I can mix inches,
centimeters, feet, and light years without any trouble.
Mark
Date: 1 Aug 2003 14:20:01
Message: <web.3f2aae259c12b543a0c272b50@news.povray.org>
>In article <web.3f26e01d9c12b543a0c272b50[at]news.povray.org>,
>#declare m = 1;
>#declare yd = ft*3;
Yes, that is what I meant.  I define Ft = 1 unit, then everything else is
based on Ft.  So far I haven't used much past yards though... guess I need
to expand my horizons to get into light years ;-)
RG
Date: 1 Aug 2003 14:40:00
Message: <web.3f2ab1339c12b543a0c272b50@news.povray.org>
>Mark
Thanks all for the comments & insights!  I hope John got the info he needed
from this thread, but even if he didn't I certainly found it informative!
This was something I had recently been running up against since my
"architecture" IRTC entry. That one pretty much demanded a standardized
method of scaling, so I started using feet since most building specs (at
least here in the US) are in feet.
Once I started using that though, I found I had problems with earlier models
where I had hard coded numbers or used arbitrary unit sizes. Some were so
bad it was easier to build a new model than to convert the old one!
So now I have my unit standard, and it sounds like enough people are using a
system similar enough that conversion shouldn't be a major issue. (And I
should have some good objects to share in my surreal IRTC entry, as long as
I get it done in time...)
Thanks again!
RG
