POV-Ray : Newsgroups : povray.general : Multiple enquiries Server Time
22 Oct 2026 07:00:12 EDT (-0400)
  Multiple enquiries (Message 1 to 13 of 13)
Subject: Multiple enquiries
Date: 8 Jun 2003 18:22:08
Message: <3EE3B70F.30303@hotpop.com>
   I was wonder about a few things:
-I need to import a model from Poser4 into povray, I've check the
conversion utilities and they do not seem to import the texture, only
the wireframe, any suggestions for this?
-I need to have a piece of cloth floating in the wind.  I could possibly
program this myself but I think it has already been made, I just don't
know what to look for?
-I'd need some plants also, like small trees and bushes, if there are
any macros that can handle this I'd prefer using them!
Thanks a lot for any clarification concerning these 3 questions!
   Xilo
Dedicated to audio/visual and interactive artwork.
http://www.geocities.com/simonlemieux/
Subject: Re: Multiple enquiries
Date: 8 Jun 2003 18:57:09
Message: <3ee3bf45@news.povray.org>
PoseRay.  Works like a charm.
Tim Cook
Version: 3.12
Date: 8 Jun 2003 19:26:49
Message: <3ee3c626.56066659@news.povray.org>
3dWin4 works as well and it has a batch function. But IMO PoseRay outputs better
textures. So if you have a series or animated model you can tweak the 3dWin4
textures using the setting from PoseRay. I wish PoseRay had a batch function
(hint).
Regards
Date: 8 Jun 2003 19:28:16
Message: <3ee3c690$1@news.povray.org>
www.oyonale.com (Gilles Tran) has a nice include for
trees and grass, though no plants.
And Christoph Hormann has written a MechSim Patch
for Povray, with which you can create physical interaction
between objects and cloth (but I have no clue on how
everything is set up etc).
Tim Nikias v2.0
Email: Tim### [at] gmxde
> Hi,
>    Xilo
Date: 8 Jun 2003 19:59:49
Message: <3EE3CDF5.40400@hotpop.com>
Ok thanks a lot!  I'll check it out as soon as possible!
Thanks,
   Xilo
Date: 8 Jun 2003 20:00:50
Message: <3EE3CE32.30200@hotpop.com>
> (hint).
Ok, I will try PoseRay, I only need one or two models for a still image...
Thanks,
   Xilo
Date: 8 Jun 2003 20:03:33
Message: <3EE3CED5.4080005@hotpop.com>
Ok, it should be fine, at least, I did not think about grass but now I
think it's a very good idea to have some!  Even if there's no plants...
  the place would look a bit more deserted i think which is pretty good
for my scene...
I'll check that out for sure!  I'll see if I can simulate some wind!
Thanks a lot!
   Xilo
Date: 9 Jun 2003 05:26:18
Message: <3ee452ba$1@news.povray.org>
 Hi.
I think the "phase"-keyword is what you need. Look it up in the
documentation.
I hope that I was helpful.
Date: 9 Jun 2003 05:55:56
Message: <3ee459ac$1@news.povray.org>
Phase is only for transponing (if thats the correct
word) color-maps of pattern definitions. But you
were probably trying to tell him how to simulate
the look, but not actual cloth, right?
Tim Nikias v2.0
>  Hi.
> documentation.
Date: 9 Jun 2003 07:48:46
Message: <3EE47424.7050207@hotpop.com>
> documentation.
I looked and found out that phase has to do with texture or actual
pigments like color_maps...
But I really need to have a deformed object floating in the wind...
Thanks,
   Xilo
Date: 9 Jun 2003 07:49:51
Message: <3EE47465.5000701@hotpop.com>
In any way, this is not at all how I could simulate my floating cloth,
because of the camera angle and everything, it must be a deformed object...
Thanks,
   Xilo
Date: 9 Jun 2003 12:28:32
Message: <cjameshuff-39EDCD.11195909062003@netplex.aussie.org>
In article <3ee459ac$1@news.povray.org>,
You could use the phase feature in a pattern used to displace a mesh or
isosurface, or use that pattern to generate a height field. It wouldn't
really be that useful though...I'd use a custom function in its place.
Translating a f_noise3d() function weighted so the side towards the pole
doesn't ripple would work. Or you might be able to use the cloth
simulation patch.
http://tag.povray.org/
Date: 13 Jun 2003 21:11:11
Message: <3EEA7630.8000202@hotpop.com>
> simulation patch.
Hmmm, I did not think of making a heightfield but I thought making a
mesh with another home-written program of mine...
I'll check what the simulation patch and the f_noise3d() (and others)
can do!
Thanks,
   Xilo
