POV-Ray : Newsgroups : povray.general : Bump map disables smoothing of heightfield? Server Time
18 Aug 2025 07:18:33 EDT (-0400)
  Bump map disables smoothing of heightfield? (Message 1 to 8 of 8)
Subject: Bump map disables smoothing of heightfield?
Date: 4 Jun 2003 07:26:24
Message: <3EDDD765.9090800@hotpop.com>
   I've been making some renders and I realized that whenever I add a
bump_map to a height field, the smoothing of the heightfield disapears
and I get a very rough polygonized(?) surface...
Anyone know how I can have a bump_map plus a smooth heightfield?
Thanks,
   Xilo
Dedicated to audio/visual and interactive artwork.
http://www.geocities.com/simonlemieux/
Subject: Re: Bump map disables smoothing of heightfield?
Date: 4 Jun 2003 09:05:34
Message: <3eddee9e@news.povray.org>
In article <3ED### [at] hotpopcom> , Xilo Musimene <xil### [at] hotpopcom>
You can't.  Both effects depends on modifications of the surface normal.
    Thorsten
e-mail: tho### [at] trfde
Date: 4 Jun 2003 11:23:45
Message: <3ede0f01$1@news.povray.org>
Couldn't/Shouldn't the bump map just modify the smoothed normal instead of
the original surface normal?
 - Slime
[ http://www.slimeland.com/ ]
Date: 4 Jun 2003 12:07:55
Message: <3ede195b$1@news.povray.org>
In article <3ede0f01$1@news.povray.org> , "Slime" <slm### [at] slimelandcom> wrote:
Actually, I have been wondering if this would work, too.  However, I am
skeptical if this would have the desired effect because the "smooth" effect
depends on the surface normal and averaging it would most likely undo the
"smooth" effect.  It might be worth trying with different contributions,
though...
    Thorsten
Date: 4 Jun 2003 12:34:47
Message: <cjameshuff-684433.11273004062003@netplex.aussie.org>
In article <3ede0f01$1@news.povray.org>, "Slime" <slm### [at] slimelandcom>
That's what I'm wondering...the height field normal code handles the
smoothing, and shouldn't interact with bump mapping, which is just a
normal pattern. Do other normals do this? I can't find anything in the
source that would explain it.
http://tag.povray.org/
Date: 4 Jun 2003 18:21:31
Message: <cjameshuff-7C1CD8.17141504062003@netplex.aussie.org>
In article <3ede195b$1@news.povray.org>,
> though...
Just use the smoothed normal as input the the bump_map() function. It
should be perturbed just like any other normal. If the normals line up
seamlessly before being perturbed, they should remain seamless
afterwards. Of course, the perturbing pattern itself will be evaluated
over the flat surface of the triangle, which can probably give visible
effects in some odd cases, but my feeling is that this will be rare.
I'm not sure what averaging you're speaking of, or how it could undo
smoothing. It should "just work".
BTW, where is the code that does this?
Date: 4 Jun 2003 20:52:44
Message: <3EDE9466.3070508@hotpop.com>
I found something strange when rendering the image again, povray tells me:
Warning: Converting PNG image map to 8 bits/sample from higher bit depth.
I've rendered my height field with povray, specifying I wanted a PNG
with 16 bit per color.  But even if my image is grayscale, povray
outputs a RGB image of 48bpp;  is there a way to force the resulting
image to grayscale instead of RGB and is there a way to read such a
48bpp image for my heightfield...
I think this is The problem I have, I don't think bump_map has to do
with it... now I render the image without bump_map and the same uglyness
appears...
Thanks for any input, btw, I'll post images and code shortly, possibly
within the next 12 hours... ;)
Thanks,
   Xilo
Date: 4 Jun 2003 21:24:56
Message: <cjameshuff-876B60.20174204062003@netplex.aussie.org>
In article <3ED### [at] hotpopcom>,
Specify hf_gray_16 in global_settings and POV will generate a 16-bit
grayscale image.
> appears...
So I've been running around the source code looking for a way to fix a
problem that doesn't exist?
