From the thread 'Concept car' in p.b.i. you can see that many
people are interested in POV-Ray Quiz :) The one suggested
by Ken is more for POV-Ray developers rather than POV-Ray
users which I think is majority in POV-Ray community.
So here is a call for three different POV-Ray Quizes:
Quiz for POV-Ray Beginners
Quiz for POV-Ray Intermediate Users
Quiz for POV-Ray Advanced Users
Each quiz should have the questions and three or more possible
answers with just one correct answer. The answers can be
represented as images as well.
Here is just an example:
1. 'orthograhic' keyword belongs to:
a. light_source
b. camera.
c. radiosity
2. Where should you put 'orthographic' keyword:
a. right after 'camera' declaration
b. after camera coordinates
c. no matter
3.When you use 'orthographic' camera the object can disappear from view
if:
a. object is too far from the look_at point of the camera
b. object is too close to the look_at oint of the camera.
c. both a and b
Send you questions and answers to this thread.
Gena.
I agree that the hardcore Pover test is quite focussed on
programmer-characters among the POV-Ray users but i also think a multiple
choice quiz is not adequate for POV-Ray. POV-Ray is not a multiple choice
program after all - there are no dialogs with checkboxes for adjusting
settings.
There are a lot of things that can't be asked in form of a multiple choice
question without making things really easy and if you are able to answer a
lot of those questions you are not necessarily very competent in using
POV-Ray.
Last updated 28 Feb. 2003 _____./\/^>_*_<^\/\.______
4. Where you can enter the matrix?
a. in camera modifiers because this effect changes view of movie
b. in object modifiers because it should change designed reality
c. in texture modifiers for those who like distorted pigments
d. in search field of your help engine with loaded POV manual
e. all above
f. none above
ABX
I guess it's for advanced users :) So please define category
next time.
Gena.
> e. all above
> f. none above
> ABX
> settings.
I think that the answer to any question which really has the answer
can be represnted as a choice from multiple answers. Give me any
question which cannot have a choice of answers :)
> POV-Ray.
I usually use quizes just to define holes in my knowledge. It also helps
and stimulates to learn the subject.
Gena.
I would rather like to know, where I can get out of the Matrix! :)
/Ib
Just '...don't let machine do what you can do yourself...'
Not sure if that's correct quotation from first 'Matrix' :)
Gena.
> Gena.
Are you referring to "Never send a human to do a machine's job." by Agent
Smith?
Daniel.
> settings.
For the advanced user, the quiz will consist of things like
'write a computer-vs-computer chess game in POV-SDL which
renders each move' or 'with such-and-such settings and the
following scene, what would the approximate number of rays
shot (scientific notation, 2 significant figures), WITHOUT
running it through POV yourself'...he heh he
Tim Cook
Version: 3.12
> Smith?
You are right. It has absolutely different meaning :)
Gena.
translate x*2 is the same as:
a. translate 2
b. translate 2*x
c. translate <2, 0, 0>
d. translate <2, 1, 1>
e. translate <4/2, 0, 0>
f. b, c and e
Parsing time will be shorter if you use:
a. separate trasnformation operations - scale, rotate and translate
b. one transformation block - transform{scale x*n rotate y*m translate z*k}
c. matrix
> c. matrix
Have you actually measured which of those is fastest?
> c. matrix
The answers are vaguely worded, so it is unclear what exactly they mean,
and the topic...there won't be enough of a difference to matter.
Christopher James Huff <cja### [at] earthlink net>
POV-Ray TAG: chr### [at] tag povray org
http://tag.povray.org/
> Well, I don't want to post answers here :) I only measured difference between a
> and b.
> For b and c I rely on documentation - 6.3.4 Transform Identifiers (see bottom
> part).
In case of c) it would be more correct to say:
c. separate matrix for scale, rotate and translate.
Because I think one combined transformation matrix should have the same
performance as 'transform'. Please correct me if I'm wrong :)
Gena.
Feel free to correct, add and modify everything :)
Do you mean that just one category will be enough?
Gena.
I think that he meant that the difference in parsing time between the
given transformation syntaxes are so minimal that in practice it isn't
a big deal. (And as we know, the difference in rendering time, which is
usually the most important issue, is non-existent.)
I posted some sources to p.b.s.-f. newsgroup (transform test). Try to
render that scene with two different macros: 'tomtree.inc' and 'tomtreet.inc'
The only difference between these two macros is 'transform'. The scene which
uses macro with 'transform' (tomtreet.inc) renders 6-7 times faster.
Gena.
On Wed, 04 Jun 2003 18:56:49 -0700, Gena Obukhov <obu### [at] mail com> wrote:
>> and b.
>> part).
Simple transformation written directly in modifiers, as
scale 2
translate x
means 4 tokens to be parsed, while enclosed by transform
transform{
scale 2
translate x
means 7 tokens to be parsed, while written as matrix
matrix <2,0,0,0,2,0,0,0,2,1,0,0>
means 26 tokens to be parsed. So all together difference might be not that
simple as it may look. They are rather other benefits from using one method or
another.
ABX
In article <3ede847e@news.povray.org> , Warp <war### [at] tag povray org> wrote:
>> c. matrix
Does it matter? ;-) If you want, I can make any of these the fastest! ;-)
Thorsten
e-mail: tho### [at] trf de
> The scene which
You don't mean it parses 6-7 times faster?
> > The scene which
Yes, it looks like parsing time is almost the same :) So, where is the
advantage of 'transform' - parsing or rendering time? According
to doc it's parsing time (6.3.4 Transform Identifiers). According to this
test it's rendering time. I'm confused :(
Gena.
On 5 Jun 2003 10:21:53 -0400, Warp <war### [at] tag povray org> wrote:
> > The scene which
When you apply transform to CGS each scale, translate, rotate etc. cause
separate calculation of transformation matrix and applying it to all children of
this object. So if you have union of 100 objects, and you rotate and then scale
this union it cause 202 calls to Transform_Object (for each child + parent). If
you enclose scale and rotate within transform{} it is first parsed into one
matrix within Parse_Objects_Mods and 101 calls to Transform_Object is executed.
The difference is not small and increases with number of transformations.
ABX
> According to this test it's rendering time. I'm confused :(
Internally only one type of transformation matrix is used. Every
transformation you write with the POV-Ray SDL is stored in this internal
transformation matris, regardless of their syntax or amount.
There's one additional thing, though:
A transformation matrix is not always applied to an object. If the object
does not need any transformation matrix, then none is used in it. This
naturally speeds up rendering because the ray doesn't need to be multiplied
by the matrix when rendering.
There are some primitives which have an optimization built into them:
For example, if you translate or rotate a sphere, only its center point
will be modified, but no transformation matrix will be assigned to it.
Similarly if you scale the sphere uniformly, only its radius will be modified.
(If the sphere has a texture, the a transformation must be applied to the
texture itself, though.) Only if you scale the sphere non-uniformly, a
transformation matrix will be applied to it.
Now, this may explain the difference in rendering speed. If the tree
consists solely of primitives which have these built-in optimizations
(such as spheres, boxes, cylinders and cones, AFAIK) and you only use
transformations which are optimizable away (such as translates), POV-Ray
will not generate any transformation matrix for the whole tree structure.
However, if you use a transformation not included in the optimizations
(such as the 'transform' block seems to be the case), matrices will be
applied to all objects in the tree, thus causing a penalty in render time.
To test that this theory is correct, try your test with non-uniform
scaling (such as "scale <1,1.5,1.2>") in additions to the translates.
If the theory is correct, the render time should be identical no matter
what transformation syntax you use.
<1,1,3>hollow}text{ttf"timrom""Warp".1,0translate<-1,-.1,2>}// - Warp -
> in the optimizations (such as the 'transform' block
> seems to be the case), matrices will be applied to
> render time.
Couldn't it be tested for a transform block if it could be optimized to
a rotation, a translation and a uniform scaling? Shouldn't it be enough
to test if the transformation matrix is an orthogonal one? And if it is,
isn't it always possible to do the desired optimization?
Rune
rune|vision: http://runevision.com (updated Oct 19)
POV-Ray Ring: http://webring.povray.co.uk
I suppose so, and I suppose that no-one bothered when implementing the
transform block code... :)
> when implementing the transform block code... :)
Well, it only makes for a render speed difference of 6-7 times anyway...
Rune
For pure yellow background you can use:
a. #include "colors.inc"
background {Yellow}
b. #include "colors.inc"
background {color Yellow}
c. #include "colors.inc"
background {color rgb Yellow}
d. #include "colors.inc"
background {Red + Green}
e. background {<1, 1, 0>}
f. all above
On Thu, 05 Jun 2003 15:58:29 +0200, "Thorsten Froehlich"
Without handicapping the other two?
Peter Popov ICQ : 15002700
Personal e-mail : pet### [at] vip bg
TAG e-mail : pet### [at] tag povray org
>this object.
Are you sure about that? IIRC the logic behind CGS is that when a ray
is traced, it is first reverse-transformed by the CSG transformation,
and then for each child that has a transform, it is
reverse-transformed by the child transformation. Or am I wrong?
> > this object.
Well, I did not debuged it but ...
void Parse_Object_Mods (OBJECT *Object)
CASE (TRANSLATE_TOKEN)
Parse_Vector (Local_Vector);
Compute_Translation_Transform(&Local_Trans, Local_Vector);
Translate_Object (Object, Local_Vector, &Local_Trans);
END_CASE
and ...
void Translate_Object (OBJECT *Object, VECTOR Vector, TRANSFORM *Trans)
Translate(Object, Vector, Trans);
and ...
#define Translate(x,y,z) ((*((x)->Methods->Translate_Method)) (x,y,z))
and ...
static void Translate_CSG (OBJECT *Object, VECTOR Vector, TRANSFORM *Trans)
OBJECT *Sib;
for (Sib = ((CSG *) Object)->Children; Sib != NULL; Sib = Sib->Sibling)
Translate_Object(Sib, Vector, Trans);
Recompute_BBox(&Object->BBox, Trans);
and intersection tests for CSG seems not contain transforming of ray.
ABX
